09-13-2016, 02:23 PM | #1 |
Quarry Creeper Join Date: Aug 2010 Location: Varese - Italy
| Rock Rat Project
Ladies and gentlemen...... The initial idea, thanks to my dear friend Giumik, was to develop a vehicle with a high level look and aesthetic / reproductive detail, but also a lot of performance. The goal over challenger was able to maintain a low center of gravity and a good negative suspension excursion. To do this, it was necessary to check collision points between frame and axles, and in this sense the 3d design was of great help. Tests frame shapes: Tests axle movements and interference with motor unit: Test in maximum compression: The first piece is the frame, low weight = carbon fiber The second piece, the body, a custom body, project 3d and special printing 3d 3d rendering of the front grille: 3d printing proofs of the front grille: |
09-13-2016, 02:33 PM | #2 |
Rock Stacker Join Date: Apr 2016 Location: Meriden, CT
| Re: Rock Rat Project
Subscribed. Looks awesome already. Sent from my XT1254 using Tapatalk |
09-13-2016, 02:43 PM | #3 |
Quarry Creeper Join Date: Dec 2015 Location: ossipee
Sick keep it coming !!!
09-13-2016, 02:49 PM | #4 |
Here is the transmission for the Rat Rock, carbon dishes and titanium shaft: The set of gear XR10 : Assembled with the Holmes Stubby: Total weight ( 5.7144 oz ) |
09-13-2016, 03:07 PM | #5 |
In this project i need a Big Block V8 Original drawing Chevy 572 engine : Conversion in 3d drawing : |
09-13-2016, 03:18 PM | #6 |
Motor printed 3d, high definition, very lightweight ... Installed in the hood, with the stock mounting |
09-14-2016, 02:12 PM | #7 |
A bit of color To install the small transmission at the position as low as possible, i dug the original skid Ascender to the base, i inserted a carbon fiber plate 2mm and resined on the bottom, on this i always fixed one carbon fiber counterplate but with a thickness of 1.2mm to which it is fixed the transmission. Then I realized the side plates and Rock Sliders. The bulkheads are made of carbon plate from 1mm in silhouette with the body so as to create the lower level where to stay Esc, receiver and battery and close the gap between the frame and door, on these i applied the Rock Sliders made from an aluminum tube. I was forgetting, the V8 still missing the intake manifold and air filter, now "breathes" |
09-14-2016, 02:31 PM | #8 |
Wow, very nice pieces and build!
09-14-2016, 03:38 PM | #9 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
I like where this is going, keep us updated. |
09-14-2016, 03:39 PM | #10 |
| Re: Rock Rat Project Thanks i follow your work, all wonderful For hood and drop bed I thought of using something a little 'more original Usually forex, but always with a watchful eye on weight and taste to build and shape something. I chose aluminum, thin sheets, ribbed, folded and riveted by hand and joined with rivets handmade 1.2mm in diameter In short, a folly for a vehicle that is intended to be used in the race, but so ..... Here the hood closed: Closed it but .... The zipper that lets you open the hood has been realized also in aluminum, creating half of the hinge directly from the hood so you do not see screws or rivets, the other half was created to be screwed from inside the engine compartment on the front grille support crossbar. |
09-14-2016, 03:45 PM | #11 |
| Re: Rock Rat Project |
09-14-2016, 05:06 PM | #12 |
Hard support to the frame of the panhard : Drop Bed has taken shape, it is a "beta" version that will probably not be the final but for now I'm satisfied, maybe because it all metal, aluminum sheets with thickness from 0.2 to 0.5mm. The door can be opened The writing on the the tailgate and hood were made by printing on adhesive aluminum one-tenth and then protected with matte varnish Detail : Tow hitch... Latches hatchback... |
09-14-2016, 05:10 PM | #13 |
Rock Crawler Join Date: Dec 2012 Location: Utah
WOW is all I can say!
09-14-2016, 09:34 PM | #14 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
Very nice work! 149 r/c worx team driver |
09-15-2016, 08:13 AM | #15 |
| Re: Rock Rat Project Thanks guys For this project I established a rather low target weight, about 2450 grams with lipo battery on board. Final details, all exclusively handmade Rollcage is made of aluminum in the drop bed: Taillights taken from indicator lights for electronic control units and supported by special shaped PVC base : Vehicle finished |
09-16-2016, 06:07 AM | #16 |
Turned out awesome! Can't wait for some pics out in its element. Sent from my XT1254 using Tapatalk |
09-19-2016, 03:43 PM | #17 |
Man... if RCC did a "Build of the Year" award, this would be a top contender. Amazing work |
09-19-2016, 05:23 PM | #18 |
Thanks guys Here we are, after finally tested Rock Rat I made a first definitely unconventional tests, finishing the assembly of the vehicle and must be prepared for a long hike, at 3:45 of the night between Friday and Saturday, after 3 hours of sleep I left for Recon G6 Italy. With half ever used off-road (only tried it in the house) and 3 talented fellow adventurers, the Recon G6 2016 along approximately 7km (so I was told) is literally blown away in 2 hours and 10 minutes, without a single problem and with great satisfaction in driving, especially in view of a still nonexistent setup. Same goes for the team competition the next day (Sunday) where Rock Rat It just got clean passages without effort and the top step of the podium With these results could not deny a gift to Rock Rat, and then return home the vehicle has found a new garage, more comfortable and in style |
09-19-2016, 10:03 PM | #19 |
Rock Crawler Join Date: May 2012 Location: Minneapolis
Great work man. Love the 3D printed parts. What electronics are you running. Saw the brushless outrunner. Sent from my iPad using Tapatalk |
09-20-2016, 11:23 AM | #20 | ||
| Re: Rock Rat Project Quote:
i have a good compromise between performance, control and lightness, i use 3s Lipo. | ||
Rock Rat Project - Similar Threads | ||||
UPDATE: project Mud Rat | turbodart | General Crawlers | 3 | 03-13-2005 09:09 PM |
project mud rat, my first tuber | turbodart | General Crawlers | 8 | 02-25-2005 06:18 PM |
