08-21-2017, 09:43 AM | #41 |
I joined the Band! Join Date: Mar 2009 Location: Right Here
| Re: Barbie hits the rocks....
Barbie got herself into a bind and lost the pin for the left front CVD...she's in 3wd till I can borrow one from another MST project Sent from my iPhone using Tapatalk |
08-21-2017, 11:17 AM | #42 |
Turns out a standard wheel hex pin fits so Barbie is back to 100% Sent from my iPhone using Tapatalk |
08-24-2017, 05:08 PM | #43 |
Quarry Creeper Join Date: Sep 2015 Location: Bakersfield
Good to know a standard hex pin works
09-02-2017, 03:51 PM | #44 |
| Re: Barbie hits the rocks.... More bad luck for Barbie, she lost both CVD pins and another front driveshaft. I think I need to limit the steering and get some 2 stage foams cuz the tires fold up and get wedged against the link and axle housing in the rocks. Sent from my iPhone using Tapatalk |
09-03-2017, 01:05 AM | #45 |
Are the pins breaking, or just falling out?
09-03-2017, 06:55 AM | #46 |
| Re: Barbie hits the rocks.... |
09-05-2017, 06:29 AM | #47 |
Interesting. I'm going to keep a close eye on mine.
09-05-2017, 03:13 PM | #48 |
09-10-2017, 08:49 AM | #49 |
I fixed the driveshaft... I installed an 8-32x2" screw in the female half of the driveshaft. I "machined" the head down to fit under the ball. Here's my redneck lathe... Sent from my iPhone using Tapatalk |
09-10-2017, 11:59 AM | #50 |
| Re: Barbie hits the rocks.... My wife and I took Barbie and Blazy to the river today.... It's just a half mile away and really low so lots of rocks Sent from my iPhone using Tapatalk |
09-11-2017, 12:59 AM | #51 |
You live in a beautiful place. I'm in a relatively featureless desert. Dirt and tumbleweeds. I drive an hour into the mountain to play with my toys.
09-17-2017, 06:27 PM | #52 |
First comp for Barbie... Sent from my iPhone using Tapatalk |
09-19-2017, 10:51 AM | #53 |
| Barbie hits the rocks.... Barbie (who signed up as Ryan to avoid the paparazzi) finished 11 out of 20 at her first comp.... Sent from my iPhone using Tapatalk |
09-19-2017, 10:59 AM | #54 | |
| Re: Barbie hits the rocks.... Quote:
Yes, we are very fortunate, we have many places to play. It does get cold and grey in the winter..... Sent from my iPhone using Tapatalk | |
09-19-2017, 06:30 PM | #55 | |
We're just now getting into our "season" for doing this. During the summer, it's over 100 before noon. Gets old quick. I still made a few trips a month to my favorite spot. | |
09-19-2017, 09:55 PM | #56 |
I had to run C2 because no CMS and my tires were .1" too big. If I compete again, I want to run C1. I'm gonna try to rotate the motor and trans to the right and install the servo on the left. Sent from my iPhone using Tapatalk |
09-22-2017, 09:58 AM | #57 |
| Re: Barbie hits the rocks.... I found these smaller barbies at the store and they seem to fit much better. The full size Barbies heads are above the roll bar and their feet go all the way to the shock mounts which limited the space for a CMS. Sent from my iPhone using Tapatalk |
09-22-2017, 05:51 PM | #58 |
| Re: Barbie hits the rocks.... More drama, this time the pin walked out halfway and bound up till the axle snapped.... Don't tell my kid, but I'm gonna borrow his axle so my wife and I can go trailing this weekend Sent from my iPhone using Tapatalk |
09-22-2017, 06:16 PM | #59 |
| Re: Barbie hits the rocks.... Good thing I broke the axle so I could discover this.... Sent from my iPhone using Tapatalk |
09-22-2017, 06:21 PM | #60 |
| Re: Barbie hits the rocks.... I think the reason I keep throwing pins is that I have too much steering throw and I keep messing with the end points. I also noticed that the tie rod is low so I will solve both problems by using and different hole in the pitman arm, trimming the excess, and putting the tie rod on top of the knuckles... Sent from my iPhone using Tapatalk |
Barbie hits the rocks.... - Similar Threads | ||||
the barbie willys | jeepcj578 | Large Scale Rigs | 34 | 10-24-2013 05:30 PM |
Can you say Barbie Jeep!!! | rottenbelly | Paint and Body | 54 | 05-30-2011 02:37 PM |
Barbie Escape | marmech | Chit Chat | 3 | 04-26-2009 10:46 PM |
Barbie goes 4wd | NissanNut | 2.2 Scale Rigs | 13 | 03-17-2009 09:44 AM |
Gonzo Hits The Rocks | 4XADICT | Videos! | 2 | 08-15-2005 01:30 AM |
