03-26-2017, 03:36 PM | #21 |
RCC Addict Join Date: Nov 2010 Location: nashville
| Re: KJ's Toyzuki Bronco
Worked on the floorpan and fenders for it today. I wanted all this to tuck up into the body as much as possible and I think it does well. Gonna need a drop mount for a bumper but that's not that bad. A quick mock up of ride height and 12.3 wheelbase. Interior is all painted. Just need to start adding scale accessories. Sent from my HTC6535LVW using Tapatalk |
03-26-2017, 08:13 PM | #22 |
Things got a little out of hand. Before I knew it this had a 16t crawlmaster pro and brxl , my set of curries under it. Just need to build some shocks and Connect the driveshafts and install a servo. Sent from my HTC6535LVW using Tapatalk |
03-26-2017, 08:25 PM | #23 |
RCC Addict Join Date: Dec 2012 Location: Crookston
Awesome looking build. |
03-26-2017, 08:33 PM | #24 |
Thanks. I'll could having it running tomorrow. Needs a custom front and rear bumper. I can't wait to see how it crawls.
03-28-2017, 08:31 AM | #25 |
Built some new icon shocks last night. Luckily I had a extra set of nitrate coated to put in there. Axial is slacking on the new icons. Single rate springs. Wth. But I got everything lined up and the wheelbase set. Drive shaft just misses motor at full collapse. Need to RE-center the servo horn over one spline but it runs and drives. Shimmed the spur to take away some the slack only problem so far is the front inner fenders. I misaligned the the inner front bumper so it hangs out a little under the grill. Sent from my HTC6535LVW using Tapatalk Last edited by King James; 03-28-2017 at 06:56 PM. |
03-28-2017, 08:49 AM | #26 |
RCC Addict Join Date: Jan 2012 Location: Vancouver
One sick bronco and love the murdered out look
03-28-2017, 09:01 AM | #27 |
Thank ya sir. The next body will be a little colorful. Sent from my HTC6535LVW using Tapatalk |
03-28-2017, 10:50 PM | #28 |
Reworked the front inner fenders and the chassis position to allow a front bumper. Not sure which one I'm gonna get but gonna get something soon Also put on the .225 hubs and tf2 hexes in the back to narrow it up. It's close to tucking in the back. Need to find a light weight driver and some accessories for the back and I'll be ready to take it out. Sent from my HTC6535LVW using Tapatalk Sent from my HTC6535LVW using Tapatalk |
03-31-2017, 07:18 PM | #29 |
I wanted to do something different for the driver in this on. I was walking through toys r us with my son and saw this and immediately though how well he'd fit in the drivers seat. It's hollow so it doesn't effect my weight much. Sent from my HTC6535LVW using Tapatalk Last edited by King James; 04-02-2017 at 05:39 PM. |
04-01-2017, 05:28 PM | #30 |
Mocked up a bumper that I may use. It's either this or a rock armor one my buddy taking off a rig tomorrow, hopefully the rock armor will mount to this chassis. Having a hard time finding a bumper that mounts. Changed up the spool on the servo winch to a lower profile locked up spool to allow for more suspension travel up front. Lastly, I picked up another set of wheels and tires. 1.9 methods with pitbull a/t I had enough locked up black scale hardware to do 2 of the rings. Need to order some for the other 2 still. Sent from my HTC6535LVW using Tapatalk Last edited by King James; 04-04-2017 at 08:46 PM. |
04-05-2017, 05:26 PM | #31 |
I received my second battery tray today and went ahead and installed it. Wiring for the most part is done. Need to make an adaptor to run 2 3s 2200s up front like saddle packs. I should be getting the front and rear bumpers tomorrow. Hoping that I can make them work. If not I'll run the bumper I have on it now. Sent from my HTC6535LVW using Tapatalk |
04-08-2017, 07:08 PM | #32 |
Mounted up the front bumper. Looks perfect on the truck. Unfortunately the matching rear bumper didn't work out. So I used it on my f250. Still need to get a winch hook and give everything a good once over. But I think it's ready to rock. Sent from my HTC6535LVW using Tapatalk |
04-08-2017, 08:33 PM | #33 |
| Re: KJ's Toyzuki Bronco |
04-09-2017, 02:48 PM | #34 |
Yay!! It's officially not a shelf queen lol. Took it out for a little testing on a rock while my son played at the park. Works really well. These little tires will hook up. Probably gonna go back to the tsls. I like the look better with the tsls. But it crawled great Sent from my HTC6535LVW using Tapatalk |
04-15-2017, 07:54 PM | #35 |
Took this out today for some testing. Preforms great. I need to swap to a 11 tooth pinion. 13/56 is a little high and I had to watch my motor temp a lil. It almost makes me want to build another Toyzuki lol. Talk about balance Sent from my HTC6535LVW using Tapatalk |
04-30-2017, 03:59 PM | #36 |
Took the 2 fords out yesterday and had some fun. The bronco works flawlessly. Crawled anything I tried. Sent from my HTC6535LVW using Tapatalk |
06-08-2017, 05:28 PM | #37 |
So I made a few changes lol. The Toyzuki chassis was swapped to a stock scx10 chassis. And it lost it top in the process. New floorpan and new wheels. It also allows me to swap to the 4runner body with no modification. The Toyzuki chassis was needed for the proline 66 bronco. I was so excited when I first saw this body and knew I had to have one. I'm thinking ar60 or xr width axles and big 1.9s. Probably the new proline krawlers. Need to order some black paint. Well really everything but the chassis and body lol. But I'll try to get it painted up this weekend. Sent from my HTC6535LVW using Tapatalk |
06-08-2017, 05:32 PM | #38 |
Ar60 is too wide for any 1.9 (except proline boggers ) imo.
06-08-2017, 05:45 PM | #39 |
I've got a set of those if I go that route. It was my original intention to get a set of wraith f9 curries and run the boggers. But I don't like the servo on the axle setup and need to look into panhard mounts for the cms, Sent from my HTC6535LVW using Tapatalk |
06-22-2017, 09:11 AM | #40 |
So this happened last night Sent from my SM-G955U using Tapatalk |
KJ's Toyzuki Bronco - Similar Threads | ||||
KJ's JK Rubicon | King James | 1.9 Scale Rigs | 9 | 03-05-2017 04:13 PM |
Kj's Jk8 | King James | 1.9 Scale Rigs | 83 | 04-05-2015 07:50 PM |
KJ's Hilux | King James | 1.9 Scale Rigs | 22 | 01-12-2013 02:53 PM |
KJ's K5 | UNGLEWD | 1.9 Scale Rigs | 4 | 07-28-2008 04:46 AM |
Who says KJ's can't crawl.... | WRMorrison | General Crawlers | 32 | 09-18-2005 10:30 PM |
