05-20-2017, 02:31 PM | #21 |
Pebble Pounder Join Date: Jan 2016 Location: Port Huron
| Re: Class 1 f350 build
The local points series started today. Not a lot of class 1 guys. Mostly class 2. But I did take first in class 1 today. But before I was running it I the house just watching and noticed the outside front tire rolling over themselves when turning. I don't think I have enough caster set on the axles. Can some of you guys post up a shot of your knuckle so I can compare to mine? Sent from my iPhone using Tapatalk |
05-20-2017, 03:21 PM | #22 | |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: Class 1 f350 build Quote:
Ernie | |
05-20-2017, 03:51 PM | #23 |
Crawler innovation lil novas Sent from my iPhone using Tapatalk |
05-22-2017, 06:56 PM | #24 |
Update on the rsd shocks: They puked oil out before I could even run them. I just left them nasty for the couple comps I've been in now. They did ok but kept sticking. I thought I had them leaned out too much at the top because my body mount and my inner fender pushed them out. So I ground the inside of the shock tower thinner but that didn't really help. I took them off and rebuilt them. Packed them full of green slime and switched the piston the the one with 2 slots instead of 4. Still using 30wt oil. They feel a ton better. I was looking at the top ball and its plastic. It smashed when I tightened everything up and wasn't allowing the top of my shock to pivot. I swapped them for some aluminum ones I had from an old sawback shock. Fit perfect. The shocks work so much better now. No more sticking. Sent from my iPhone using Tapatalk |
05-25-2017, 06:34 PM | #25 |
| Re: Class 1 f350 build Put some scale stuff in there to get the 6 points. Not gonna run a spare to save weight. Just gotta finish the interior sometime. Sent from my iPhone using Tapatalk |
06-25-2017, 09:18 AM | #26 |
Haven't really done anything to the truck except drive it. After rebuilding the rsd shocks again they haven't leaked. The piston with 2 holes is almost perfect. We had a local Crawler 4 Kids comp a couple weekends ago. I must have gotten something in my motor because it locked up before I even hit the course. Still took second with a smoking motor. But I realized I needed a smaller pinion. I bought a 12t and ran 3 hours yesterday on a Rc4wd 35t boost motor. Got a little warm so I bought a 10t pinion to try. I also got some ottsix 4.19 a/t to try. They are hard to clean out in mud but I bet they work amazing on dry rock. Sent from my iPhone using Tapatalk |
Class 1 f350 build - Similar Threads | ||||
Ascender Build | seth556 | Vaterra Ascender | 12 | 01-05-2015 03:13 AM |
Fresh off the machine! My next build another one of a kind. | ohboy221 | Axial SCX-10 | 22 | 12-22-2014 03:27 PM |
Different kind of Wroncho build | C_Money | Axial SCX-10 | 4 | 12-05-2013 09:31 AM |
Kind of gay, non RC build thread | Chris_The_Battery_Man | Chit Chat | 15 | 01-10-2011 02:13 AM |
Different kind of Hummer build | corkyjr05 | 1.9 Scale Rigs | 4 | 06-06-2008 10:58 PM |
