08-06-2017, 07:59 PM | #21 |
Rock Stacker Join Date: Apr 2015 Location: Tuscaloosa
| Re: Another New bright build
Dropped the truck off with @jabird he is going to machine down some links and 3D print body mounts for the jk Sent from my iPhone using Tapatalk |
08-06-2017, 08:02 PM | #22 |
| Re: Another New bright build [IMG]https://uploads.tapatalk-cdn.com/ Going to have to bend the top links to clear the trans case 20170807/37ef9762434e5c9675114088b7754af5.jpg[/IMG] Sent from my iPhone using Tapatalk |
08-06-2017, 08:03 PM | #23 |
| Re: Another New bright build Mock up Sent from my iPhone using Tapatalk |
08-06-2017, 08:04 PM | #24 |
Newbie Join Date: Jul 2017 Location: Carlisle
| Re: Another New bright build |
08-07-2017, 02:47 PM | #25 | |
| Re: Another New bright build Quote:
I got the shocks off eBay there are a few that look like they may be the same but this particular brand was the only one I had seen a review on. But search LNL shocks on eBay they should come up . yes I had the body completely painted and sanded then decided to add metal fender flairs . I messed the paint up pretty bad in the process so I sanded it back down . Sent from my iPhone using Tapatalk | |
08-08-2017, 08:45 AM | #26 | |
Just noticed you said strip the paint off . I just lightly sanded the the body to give the primer something to stick to . Then primed painted sanded and polished Sent from my iPhone using Tapatalk | |
08-09-2017, 03:40 PM | #27 |
What grit sand paper did you use? I'm seeing some posts where people used 400 for initial coat and then 1000 grit to smooth it out. Would you agree? Also, those fender flares you got from RC4WD. They require additional drilling or are they glue on? |
08-10-2017, 07:54 AM | #28 | |
I think 400 grit would be a good starting point for the paint. I cut off my bumpers and flares which left uneven edges. I used 150grit to smooth the plastic then worked my way back up . The RC4WD flares required about 4-5 small holes to be drilled for them to mount to . I really like the way metal flares look but I think I'd recommend going with axial plastic flares bc they have some flex to them that will hug the body lines much easier than the metal which will not give at all. Sent from my iPhone using Tapatalk | |
08-10-2017, 07:59 AM | #29 |
Here is a great link to perfect paint. Some of the really high grits may be a little excessive IMO but it did make the paint look like a real cars paint . The key has been using the rubbing compound, polishing compound and then good coat of wax for protection. Sent from my iPhone using Tapatalk |
08-10-2017, 08:00 AM | #30 |
08-10-2017, 02:30 PM | #31 | |
| Re: Another New bright build Quote: | |
08-10-2017, 10:30 PM | #32 |
08-13-2017, 03:00 PM | #33 |
Don't mean to hijack your thread, but wanted to share progress and ask for opinion. Should I be concerned about the sanding down the small details such as around door handles and door hinges etc ? Also, any other feedback as to what else I should do before applying primer would be helpful. Btw I do plan on cutting off the rear flares and get the RC4WD Plastic ones. Sent from my ONE A2005 using Tapatalk |
08-13-2017, 03:02 PM | #34 |
Looking good! I would at least scuff the pint so the primer will stick better Sent from my iPhone using Tapatalk |
08-13-2017, 03:05 PM | #35 | |
I am going to go over everything with 800grit sand. I don't plan on doing the roof because I'm leaving it black anyways. Sent from my ONE A2005 using Tapatalk | |
08-13-2017, 03:39 PM | #36 | |
What color are you planning to paint it? Sent from my iPhone using Tapatalk | |
08-13-2017, 03:53 PM | #37 |
Planning on silver and black top and black flares. Sent from my ONE A2005 using Tapatalk |
08-13-2017, 04:53 PM | #38 |
What brand / type primer did you use? Sent from my ONE A2005 using Tapatalk |
08-16-2017, 05:54 PM | #39 |
08-16-2017, 06:03 PM | #40 | |
I used rustoleum 2x coverage for plastic . Iv used it before on a golf cart restoration I did. it bonded to the plastic really good and when following the above method for sanding it come out looking like a professional paint job. Iv been really happy with it on plastic . Sent from my iPhone using Tapatalk | |
Another New bright build - Similar Threads | ||||
need help with a new bright tj build | Dezertdirt | General Scale Talk | 6 | 07-05-2016 08:02 PM |
New Bright Build so far | burmis | 1.9 Scale Rigs | 5 | 08-23-2013 01:22 AM |
new bright tj build | stanmondz | Tamiya XC/CC01 | 44 | 05-02-2013 08:09 PM |
Yet another New Bright TJ build | SFT2 | 1.5 Scale Rigs | 16 | 11-20-2011 02:16 PM |
Yet another New Bright JK build | mike_777 | Axial SCX-10 | 42 | 11-29-2010 03:46 PM |
