07-26-2017, 12:02 PM | #1 |
Quarry Creeper Join Date: Nov 2016 Location: Surrey
| RC4WD Gelande 2 turning circle?
Is there something that can be done to improve the turning circle on the G2. Although it's a G2 chassis I'm running the yota 2 ultimate scale axle. Any help appreciated Sent from my iPhone using Tapatalk |
07-26-2017, 03:14 PM | #2 |
Rock Crawler Join Date: Jan 2010 Location: [loh-key-shuhn]
| Re: RC4WD Gelande 2 turning circle?
I changed my TF2 over from a Yota 1 to a Yota 2 axle for increased steering. I removed the spacer on the bottom shock screw (and changed to a Traxxas rod end, but not sure that would matter). The screw was keeping my axles from full steering. I added the RC4WD XVD Axle for Ultimate Scale Yota II G2 Axle for max steering without modifications. You can take the axle shafts out of the axles and remove the steering link to see what limits it when you cycle the steering. The axles shafts, if stock, will be one limiting factor. With the XVD axles, you should get 45 degrees of steering angle. |
RC4WD Gelande 2 turning circle? - Similar Threads | ||||
Tamiya CC-01 Turning Circle | asimmd | Newbie General | 7 | 05-27-2017 06:00 PM |
RTR SCX10 II turning circle. | ogreCyques | Newbie General | 6 | 03-04-2017 05:19 AM |
Your turning circle? | Hardline | Axial AX-10 Scorpion | 29 | 04-05-2012 07:04 PM |
tightest turning circle | some_guy | General Crawlers | 8 | 04-04-2008 02:34 AM |
WK Turning Circle with Locked Diffs | birdie | Newbie General | 12 | 11-08-2007 04:14 PM |
