![]() | #21 |
Quarry Creeper Join Date: Sep 2017 Location: South Africa
Thanks Brake Weight! Thats why I am considering the 1080. It should be all that, lol. The wheels: http://s.aliexpress.com/R3iMJbmy Had a coupon that covered the shipping cost too. Could not resisit. Sent from my iPhone using Tapatalk |
![]() | #22 | |
| ![]() Quote:
Ahhh. 5 luggers, too. | |
![]() | #23 |
Shafts and Wheels rocked up today. ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk |
![]() | #24 | |
Moderator ![]() Join Date: Sep 2008 Location: PA
| ![]() Quote:
Wow. Those wagon wheels look a helluva lot better than RC4WD's. The metal seems thicker. Do you know if this is true? And I like how the front and rear holes are different sized so there isn't an alignment issue and slight overhang with the holes like on the RC4WD wheels. | |
![]() | #25 | |
| ![]() Quote:
They’ve gone up $5 since I bought my second one. It looks a lot like the HW1060. The motor looks to be rebuildable and it has bearings on both ends. https://www.banggood.com/540-Motor-6...-1187553.html? ![]() ![]() Specs ![]() ![]() | |
![]() | #26 | |
| ![]() Quote:
The motor appears to be the generic Chinese motor sold by a bunch of different vendors. | |
![]() | #27 |
| ![]() Correct. It's not on par with the 1080 at all but for a light rig or test gear it'll do.
![]() | #28 |
| ![]() ![]() ![]() ![]() The wheels measure just over 1mm thick. ![]() Sent from my iPhone using Tapatalk |
![]() | #29 |
![]() | #30 |
![]() | #31 |
RCC Addict Join Date: Jun 2006 Location: Durham, NC, USA
good job on the Chinese build
![]() | #32 |
Got the other axles. Prepped and waiting. ![]() Sent from my iPhone using Tapatalk |
![]() | #33 |
Got the spare wheel rim and tow hitch today. ![]() ![]() Should have the 1st set of tires in the week. Sent from my iPhone using Tapatalk |
![]() | #34 | |
RCC Addict Join Date: Apr 2009 Location: LA
| ![]() Quote:
![]() | #35 | |
| ![]() Quote:
The suggested program card is also the one that programs their brushless ESCs. It works with both the brushless and brushed. | |
![]() | #36 |
Got the china Mud Countries today. They feel sticky. I’m quite happy with how they look and feel. ![]() ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk |
![]() | #37 |
Tried to do some math... The axle has the following gears: 13t running a 20t and then a 14t running a 37t. That equates to basically a 4:1 ratio? My gearbox is a 5:1 transfer case 2:1. Thats 40:1? And I’m sitting with a 45t motor... Dead slow! Sent from my iPhone using Tapatalk Last edited by HugoBiermann; 03-05-2018 at 10:05 PM. |
![]() | #38 |
![]() | #39 |
The rest rocked up! Just waiting on the spare tires. Chassis: ![]() Austar D90 effort. Cheap as chips and mad nice and thick. All included screws and hardware is 100%. The completed chassis: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() The Austar 45t motor got donated to the FY03. The only other motor I had lying around that would give me better wheel speed was a Tamiya Sort Tuned. It seems to be happy in there. Huge lift on tue suspension to accommodate the big tires on the wide axles. The 10kg Blue Bird servo has enough power to turn the wheels even if I wedge it into a shitty spot. Surprised... The wheel weight and probably the axles gives a good enough low center of gravity to allow me to do quite a steep side hill. F/R weight is probably around 55/45. No noticeable torque steer. Top speed is a slow leisurely walking pace. It feels stupid slow, LOL, but its got loads of control. Very accurate. Will have it out sometime an try to take some video. I’m happy thus far. Just need to finish off with some accessories. Sent from my iPhone using Tapatalk |
![]() | #40 |
Been messing with it every gap I get. Moved the servo up on the mount... Where it should be. Got the shocks as good as I can with what Ive got. They’re not perfect but they get the job done. Need more spring options. The Tamiya Sport Tuned seems ok for now, it does get hot too often though. I have a china ‘serviceable’ 21t on the way to help with getting the motor rpm down slightly when its cruising around asI think its because I’m just over revving the poor 540 too much? I’m getting around 45-50min on an 3300 NiMh pack atm. Thats on grass, stormwater gutters and tree roots around my house. Still getting used to how slow this thing is, lol. Will see if I can get a 5000mAh sometime. Another 5 weeks till the last accessories should he here. Saw some China Landie Beadlocks that looks promising on Aliexpress. Sent from my iPhone using Tapatalk |
Custom D90 pickup nearly finished | J55TTC | Scale Videos! | 0 | 09-02-2017 02:13 PM |
Scx10 custom us army truck and custom scx10 d90 landrover | marc323 | Videos! | 2 | 08-09-2014 03:51 AM |
