Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: Alloy or Plastic?
Old 10-06-2017, 04:30 PM   #1
Default Alloy or Plastic?
building up a Hardbody JK. looking to get fenders.
there is 2 options that im considering.
Axial Poison Spyder AX80122 & AX80121 (original on SCx10 Jeep jk)
or
RC4WD Aluminum Fenders. (rep of the axial just CNC alloy)
is it worth getting the Aluminum for realism or stick with the plastic ones?
plastic would be less weight and being that hard body is heavy as is maybe a good idea.
on the other hand alloy would look so much better, cleaner, and more realistic after some scratches. your thoughts?
BombShellRC is offline   Reply With Quote
Old 10-06-2017, 04:36 PM   #2
spoo76's Avatar
Default Re: Alloy or Plastic?
Plastic IMO is just as realistic as metal. There are Plastic flat fenders available.
Sent from my SM-N900T using Tapatalk
spoo76 is online now   Reply With Quote
Old 10-06-2017, 07:25 PM   #3
I say go metal
ussprinceton2004 is offline   Reply With Quote
Old 10-07-2017, 04:05 AM   #4
I say it depends on how you're gonna drive it and are the plastic fenders hard plastic or flexible. If the fenders are hard plastic and you're rock crawling there's a chance they might crack or break. You won't have that problem with flexible plastic or metal. But if you just light trailing your rig. Any decision will do.
Sent from my VS995 using Tapatalk
Rickleo is offline   Reply With Quote
Old 10-07-2017, 08:48 AM   #5
My 1:1 jk has plastic fenders so either way would be realistic.
Sent from my SM-N910P using Tapatalk
Druxus is offline   Reply With Quote
Old 10-09-2017, 03:25 PM   #6
ordered the alloy ones. just sounds so much better. even though its a little more weight ..
Alloy or Plastic? - Similar Threads
Transmission case......Alloy or plastic? big_poppa49 Axial SCX-10 16 11-10-2016 10:51 AM
alloy transcase? SwampDawg Axial Wraith 10 09-07-2012 11:16 AM
Anyone know what alloy... Speed Metal Army RC4WD Bully 3 08-05-2011 11:28 AM
Need to know the best plastic on plastic friction reducer. TurboB18C Chit Chat 2 04-06-2005 05:28 PM
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
