01-08-2018, 08:25 PM | #81 | |
Rock Crawler Join Date: Dec 2014 Location: Union Bridge, MD
| Re: Matzilla Crew Cab F-350 Angus Quote:
Sent from my XT1585 using Tapatalk | |
01-09-2018, 06:53 AM | #82 |
I wanna be Dave Join Date: Dec 2009 Location: Outside DC
I'm loving the stance in post #76 and all the scale touches. The only thing that drives me nuts is the body holes. There's two ways of thinking...it's necessary and a given, or 1:1s don't have three four inch holes in the body. Now that I point it out it may bug you too or not. Some of the best builds out there have them, but if you're chasing scale and go to great lengths...I'd rig a set of magnets and do away with them. More thinking, and more engineering, but that's part of the fun. Not to mention you can pop your body off quickly and get to the innards.
01-09-2018, 07:39 AM | #83 |
That is what the diamond plate is for. I'm going to add rocker panel cover along the bottom to cover the holes and use magnets on the body. You and I think alike. I don't know if you have seen the aluminum diamond plate but is is very, very thin. It will cover the holes, match the truck, and make it look even tougher. I was also going to use the diamond plate on the back of the cab. The body is molded in black and I don't want to do the body work because that will force me to paint it. I'm really struggling with the tinted glass covering the interior details. It just looks so cool. As for the stance that will be real close to what I want. I have some soft and medium springs coming for the RSDs. I am hoping they will give me what you see. Currently I removed the hard springs that come with them and put stock Ascender bottom springs on. This gave me the ride height but they are to short. It does give me about a 60% droop which should work well. Thanks for the compliments. Last edited by SHOme; 01-09-2018 at 07:48 AM. Reason: addition |
01-09-2018, 06:55 PM | #84 |
Giddy up! Sent from my XT1585 using Tapatalk |
01-11-2018, 04:03 PM | #85 |
Look what Mamma got me. Awesome! Sent from my XT1585 using Tapatalk |
01-11-2018, 04:06 PM | #86 |
A little dashboard detail you will probably never see behind tinted glass. Sent from my XT1585 using Tapatalk |
01-12-2018, 04:13 PM | #87 |
A custom truck should have a custom grill.(especially if you need clearance for a bigger winch) Sent from my XT1585 using Tapatalk |
01-13-2018, 05:44 PM | #88 |
The touches are definitely bringing it all together. Keep rockin!!! |
01-13-2018, 06:29 PM | #89 |
Instead of a "how to" I'll show you how I do. I'm sure others have posted this technique but in case this is the first time looking at a build... I use magnets as clamps all the time they are very handy. One on either side of styrene to clamp or prop. In this case my body has to be flexed "open" at the bottom to install it. If I were to bond the cab back I wouldn't be able to install it because I would loose the flex in the rear. I still need to cover the back of the cab though. So I am attaching the diamond plate to the cage. Yes there will be the slightest of gaps. The truck is black and the interior is black so the gap will be hidden in the darkness. Additionally Lue's work is so good there is barely any gap anyway. I will probably attach a small flexible foam to cover if there is to much gap. Back to the magnets. I used a thick, stiff paper to make my pattern so I don't screw up good diamond plate. I used the magnets to hold it to the cage so I could trace the cage on to the paper. Then test fit and subsequently transfer to the diamond plate. Here are some pics. I will post finished product when it's complete. Sent from my XT1585 using Tapatalk |
01-13-2018, 08:40 PM | #90 |
Magnets can hold while glue sets too. Sent from my XT1585 using Tapatalk |
01-14-2018, 06:44 AM | #91 |
Finished product. Now on to mounting dash windshield and interior details. Sent from my XT1585 using Tapatalk |
01-19-2018, 03:28 PM | #92 |
Installed electronics and took her out for a mini shakedown. Sent from my XT1585 using Tapatalk |
01-20-2018, 10:27 PM | #93 |
Newbie Join Date: Jan 2015 Location: North
Where did you get the black diamond plate at? That's a really cool detail
01-20-2018, 10:50 PM | #94 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
You are doing a good job putting it all together, Cary. Are you happy with the shake down run? It is a little different than your ascender so remember it is going to tune differently. I just about have my ascender portals designed, machined and put together. Ernie Last edited by CODYBOY; 01-21-2018 at 01:41 PM. |
01-21-2018, 06:10 AM | #95 | |
01-21-2018, 06:15 AM | #96 | |
01-21-2018, 07:36 AM | #97 |
Some more details. Sent from my XT1585 using Tapatalk |
01-22-2018, 05:16 PM | #98 |
A few more details. Sent from my XT1585 using Tapatalk |
01-22-2018, 07:49 PM | #99 | |
| Re: Matzilla Crew Cab F-350 Angus Quote: Sent from my XT1585 using Tapatalk | |
01-22-2018, 09:10 PM | #100 |
| Re: Matzilla Crew Cab F-350 Angus |
Matzilla Crew Cab F-350 Angus - Similar Threads | ||||
Crew Cab F-350 | bigdodge88 | 1.9 Scale Rigs | 44 | 11-12-2009 09:00 AM |
AI F-350 Crew Cab Two | ALTERED IMAGE | 2.2 Scale Rigs | 4 | 04-28-2009 07:15 AM |
f-350 crew cab | super pig | General Crawlers | 1 | 09-22-2008 12:18 PM |
f-350 crew cab help | super pig | General Scale Talk | 4 | 09-20-2008 08:27 AM |
