11-16-2017, 04:57 PM | #21 |
| Re: OS's 1.9 Junkyard Yota
Well, decided to cut it up. Since I've got the agressive tire look, thought the body should match. Bodywork is not my thing at all, but it's coming along ok so far. More by luck than skill! Got a little crazy with the styrene while waiting for the filler to dry. Wanted something unique compared to the other yota's rolling around out there. Scoop is functional (kinda....) Sits over the motor...doubt I'll got much airflow at 5mph, but I know it's there. Tacky but I like it anyway. Filled, primed, ready for some more sanding. Started the interior..not sure what the final color will be - thankfully crap brown goes with everything. |
11-20-2017, 08:17 PM | #22 |
Well, painting season is pretty much done here in the northeast (my paint booth is the backyard) so the body paint will have to wait a while. I flat blacked the hood and bed just in case I get a few trail runs in - kind of gives it that work in progress look....which it is! Interior is in...the tamiya driver is way tall! Just painted it and installed it for now, any further detail work will be done after the body is painted. Bed came out pretty good! Just need to put the taillights back on and get some kind of bumper back there. Changed the wheels again..I was going to offload these wheels since I bought them for a TRX4 that never shipped, but I put them on the truck on a whim and loved the look. Think I'm finally done the wheel and tire roulette Dying to get this out on the rocks to do some testing. So glad I tore down the deadbolt - loving the way this came together. |
11-26-2017, 08:38 AM | #23 |
It lives! Gimped out into the backyard and took the Yota for a test run. Very happy so far with how it performed. The gearing was pretty much spot on with the 35t motor and the suspension overall was a bit on the soft side, but definitely in the ballpark. I did have a little torque twist (I expected it) but I've got a plan. Kinda. Stalking in the grass.. Out on the remains of my test course. Started moving the rocks to another spot in the yard, but there's still a few here to play on. My hardest climb. Semi smooth rock at a pretty good angle. Most of my 1.9's struggle here - No problem! Grip from the Gmade tires is very good - they continue to exceed my expectations. Somehow unthreaded a link after about 30 minutes. Fun while it lasted, but that's the nature of new builds and test runs... Not all was rosy though. That aluminum trans mount is a boat anchor in the middle of the chassis. Need to think about it. Also, seemed a bit tippy - think the suspension is unloading too quickly - might go with some heavier oil all around. Last edited by OSRC; 11-26-2017 at 08:41 AM. |
12-05-2017, 06:11 AM | #24 |
Thought I'd give this a try to help with torque twist...Boom makes a set of links with an integrated swaybar. Thought it was worth a try and would keep the back end looking clean. Bolted right on, no issues. Not sure how well that swaybar is going to stay secured, I might have to grind some flats in for the setscrews. Feels good once it's all installed. Time will tell! |
12-07-2017, 01:51 PM | #25 | |
| Re: OS's 1.9 Junkyard Yota Quote:
Me too! | |
12-13-2017, 07:09 PM | #26 |
| Re: OS's 1.9 Junkyard Yota Technically, they are for the SCX10, but I'm sure it would work with most other chassis with a bit of tinkering. They have 4 set link lengths as well....which is interesting. I measured my links before ordering, and it was spot on the the shortest setting.
03-03-2018, 02:15 PM | #27 |
IT LIVES! (And I found a Gopro I got a few years ago.) Can't wait for spring, itching to get this out on a trail. |
03-14-2018, 12:09 PM | #28 |
Fitting name to this project since you're using such a variety of brands. Nice test spot you got as well. Looks good. I'm sure it will "rock" out on on the trail. I'll second the "Can't wait for spring" part! We don't get crap for snow so it's time to dry out and give us some warm weather. Will it be blue and silver before its first trail run? |
03-14-2018, 02:32 PM | #29 |
Rock Stacker Join Date: Mar 2014 Location: Siskiyou County
Man,that was like a 70º climb,well done. I often wondered why people weren't putting the round headlight bruiser grill on the TF2 to make it like an early snub nose. |
03-15-2018, 12:16 AM | #30 |
Quarry Creeper Join Date: Jan 2011 Location: Woody point
great build up.
03-15-2018, 06:25 AM | #31 |
| Re: OS's 1.9 Junkyard Yota |
04-10-2018, 06:44 AM | #32 |
Finally got out on a real trail! Didn't get a full run since I had 5 trucks and was doing some testing and setup on them. Impressed with the little Yota. Oddly, the HPI trans/Axial t-case /Ascender axle combo is dead silent. I like a smooth quiet truck. Mechanical harmony in motion! Need to work on the suspension a bit. Didn't have a whole lot of flex which is sometimes good, but having the tires drop out a bit more would have helped. I thought with the rear shocks laid down I'd have a lot more travel, but the swaybar really tightened things up. Think I'll switch over to the soft bar ilo the medium. The Gmade tires really didn't like the cold weather...it was in the upper 30's, and they are already kinda stiff so I was seriously lacking in grip. I'll wait to run it in warmer weather before messing with anything though. Tore it down for some paint when I got back. Tired of the primer look... 70 degrees this week finally!! The outdoor paint booth is primed and ready to go! |
04-16-2018, 06:28 AM | #33 |
Anyone else noticing an unusually cool spring? Hasn't really even been in the 60's yet - then, we get a freak weekend - warmed up to 80 for 2 days, then back in the 40's/low 50's for the next 2 weeks. Cabin fever is setting in big time. No matter, it got warm enough to spray for at least 2 days and got some painting done. Thought it looked a little too plain, so I tried to age it a bit. Never tried this before, I prefer to let them age on the trail so to speak, but I decided to grab some 800 grit and see what I could do. Came out ok I guess...not a fan of the red poking through here and there. Kinda looks like a poorly repainted truck ....Which it is. |
04-16-2018, 09:39 AM | #34 |
Quarry Creeper Join Date: Jul 2015 Location: Moncton
nice! I love worn out looking bodies on scalers.
04-16-2018, 03:19 PM | #35 |
Actually, the body was pretty beat when I got it, so didn't have to do much. Then my hack paint job came along... Pretty much back together, still a few details to finish. I wasn't sure about the color, but now that it's back together, looks pretty decent. Just glad to at least have the taillights back in....progress!! |
04-23-2018, 06:55 AM | #36 |
2 days of trail runs, and got wheel time with 5 rigs this weekend. SO GLAD spring is finally here! Well, kinda. But I'll take low 60's and sunny any day. Got the Yota on a nice 4 hour run yesterday. Nothing fell off, broke, or otherwise caused issues. Super happy with this truck. Plenty of clearance with the Ascender axles and other than some squeaky driveshafts by the end of the run it was smooth and silent. It's quite zippy with the 35t motor - the Ascender axle ratio is so much taller than SCX axles. Need to think about what I want to do there though it's perfectly driveable. I did double duty, driving the Yota and my TRX4. I looked like 2 Gun Sam with radios hanging off everywhere. Fabbed up a hitch of sorts and pulled a trailer for the entire run. This was a pretty mild trail, so the trailer made a fun and unique twist. Only had 1 tricky spot where I lost the trailer. Used a 5mm ball joint to attach it so it could pop off if it was stressed too much. I did have quite a bit of weight in it so it was realistic pulling it. Definitely made the hill climbs more interesting! This was early in the run - once I got the hang of driving with it back there, never lost it again. Lots of scale rigs out today - A Cross something or other (HC4?), 2 TF2 based rigs, Hardbody Mog, and my junk of course. 2 TRX4's which weren't even trying very hard that sailed through, and a lone SCX10. Great trail run! Got some details to work on, and needs thicker oil in the rear shocks for sure. Still needs a rear bumper of some kind too. |
04-25-2018, 06:09 PM | #37 |
Rock Stacker Join Date: Oct 2009 Location: mitchill
OSRC, thanks for letting me know about this build. It is a nice build too. Is thee a link to the vid as it isn't working now? |
04-26-2018, 05:13 AM | #38 |
04-26-2018, 08:16 AM | #39 |
OSRC, that is a nice place. Thanks for the new link, sweet vid ! Your crawler looks like its handling well too. |
06-26-2018, 07:10 PM | #40 |
Was down in Bethany Beach, DE so the wife could spend a week at the beach (but never go in the water...it would be cheaper to build a big sandbox with an umbrella in the backyard, but anyway) and stopped by Coastal Hobbies again. Nice place! Picked myself up a little father's day gift - a new set of Pitbulls for my Yota. The owner had a set on his and I really liked the look. Not that there was a problem with the old tires, but I like the more scale tread pattern - and I'm sure the performance will be a bit better too. Mounted them on some old Axial 8 holes for now, I'll get some different wheels later. Too much black going on there. Tire size is spot on for the body. |
OS's 1.9 Junkyard Yota - Similar Threads | ||||
OS's Junkyard NB JK | OSRC | 1.9 Scale Rigs | 31 | 11-06-2017 01:36 PM |
OS's Junkyard C3 | OSRC | 2.2 Scale Rigs | 10 | 10-16-2017 02:07 PM |
OS's XR | OSRC | Axial XR10 | 21 | 11-09-2011 08:39 PM |
OS's Creeper | OSRC | Venom Creeper | 8 | 11-07-2011 10:06 PM |
vonclods rusty junkyard yota | vonclod | Videos! | 4 | 08-01-2011 04:49 PM |
