12-13-2017, 12:05 PM | #41 |
Newbie Join Date: Nov 2017 Location: Virginia Bch
| Re: Ordered new custom Truggy Chassis
How do you like the f9's under it? I have a set and cant decide if I want ti use the f9's or go with AR44's. I ordered a chassis form the same builder but I got the tundra version like the one pictured in the thread.
12-14-2017, 09:39 AM | #42 | |
| Re: Ordered new custom Truggy Chassis Quote:
That said, the F9's look freak'n awesome under this chassis IMHO. (or any chassis really!) They also feel and roll really smooth! | |
12-14-2017, 09:58 AM | #43 |
Well, this whole build went a bit quicker and smoother than I thought! The finished rig with all the accessories and a 3s 5000mah pack weighs in at 8lbs 7ozs. So, not too bad. I got the interior prepped, painted and installed last night. I was able to hide the switch for my lights inside the cab on the interior floor pan. I can easily reach it on the underside of the chassis for quick and easy access. (it's hidden pretty well in there since the switch is black and so's the interior.) I was thinking I might paint it up OD Green like an ammo can and ad the Rifle in back from an Axial parts tree. I also added an aluminum extension plate on the back of the cab. I didn't like how exposed it looked with the drive-line tunnel back there. The plate clamps down to the bolts I used to mount the spare gas can holders inside the cab, so pretty clean. Should help to keep some additional debris out as well. I also finally got the stance where I want it. That may change when I run it and shake it down. Thinking I may need to go to the Firm springs up front since so much of the weight is forward on this rig. Should be good out back with the Mediums. Anyways, cannot wait to get this thing under its own power and thrash on it! |
12-14-2017, 12:36 PM | #44 |
Got the lighting fired up. Used my old BR-XL and spare receiver to test it out. Still need to get the taillight set up hooked up.
12-14-2017, 01:07 PM | #45 |
Pebble Pounder Join Date: Oct 2011 Location: Wichita
Looks awesome man. One of the guys I run with just put the new Holmes revolver motor in his crawler. It’s super smooth even though it’s sensorless and it sounds pretty cool too. Sent from my iPhone using Tapatalk |
12-14-2017, 01:11 PM | #46 |
| Re: Ordered new custom Truggy Chassis Thanks! Cannot wait to get it out and scuff it up. I did the HH PullerPro Stubby 3300kv sensored with the BLE ESC. It should be potent from what I hear! |
12-18-2017, 09:47 AM | #47 |
Got the rear lights installed and hooked up last night. Spent some time tidying up the runs under the body as well. Definitely ready for some night trailing now! |
12-18-2017, 01:07 PM | #48 |
I wanted to incorporate a bit more of the brushed aluminum I've been using like on the fuel cell shelf and at the back of the cab by the Trans Tunnel. I went ahead and trimmed up a piece to use on the roof rack as decking. I think it cleans up the look of the rack a bit and helps further hide the LED wires.
12-25-2017, 12:57 PM | #49 |
Got the HH Puller Pro Stubby 3300kv installed today. All I can say is WOW! This motor and esc combo exceeded my expectations. Great low speed bandwidth, insane torque and wheel speed. This is going to be a heckofa fun RIG!
12-25-2017, 03:08 PM | #50 |
My fave Yota Truggy build, sir! Love the color and graphics, Gearhead RC Ute wheels and lights. I've got the 4" front and rear bars and the CAC 2.2 wheels in Delrin from them for my Bomber - which, strangely enough, is awaiting Olive Drab body and Matte Black hood paint on the aluminum panels. Seriously kickass machine you got there... |
12-25-2017, 04:39 PM | #51 | |
12-28-2017, 06:17 PM | #52 |
So, the rig got its first battle scars today courtesy of Jamesthe1v indoor crawler course. Tubes are good and scraped up, the F9's are scraped up, the cab took some hits and scrapes, and driver's side window is cracked. She's definitely starting to look the part now! ! Anyways, his place is freak'n awesome with a lot of super technical lines that were beyond this rig. (I think he's got me talked in to building a shafty!) Big shout out to jamesthe1v for inviting me out to shake this sucker down. Nothing like crawling in a heated, indoor environment when it's 12 degrees outside! I definitely needed some different foams, which I bought from "Jim" while I was there. The rig, with all the scale elements is also a bit top heavy for crawling as technical as what is at Jim's place. I think it would be perfect for basic trailing as it is now, but I'm going to do some tweaking and get it even better on the rocks. All in all I was very pleased with its maiden run. Rear driveshaft pin came loose, but luckily I found it. I also had an upper link come loose, other than that, no major issues and the HH Puller Pro Stubby and BLE worked awesome. |
12-30-2017, 11:17 AM | #53 |
Got her out in the snow today to mess around a bit. Wasn't great because the snow is a bit deep! I did make a few adjustments including new CI dual stage foams. Soft outer up front, medium outer out back. I also put firmer springs in the shocks up front. The forward weight bias was overwhelming the springs I had up there. Hard to tell how these changes will work out due to the snow. Hopefully we get a melt off soon and I can check them out more thoroughly.
12-30-2017, 05:37 PM | #54 |
Quarry Creeper Join Date: Jul 2013 Location: Maple Ridge B.C. Canada
How did those tires do in the snow. Did they stay packed or did it always try and work it’s self out to keep the treads clear?
12-31-2017, 06:58 PM | #55 |
| Re: Ordered new custom Truggy Chassis |
12-31-2017, 07:30 PM | #56 |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
That is a tight looking rig. It turned out beautiful! The truggy cage really has a somethin’, somethin’ going on that is quite unique. Personally I find my tires just freeze in winter, and traction goes to hell. I doubt they put the silicon in Rc tires like they do in 1:1 winter tires |
01-01-2018, 06:56 AM | #57 | |
I agree - The best I could say about these PitBulls is that they at least unloaded the snow. But like I said, it was really powdery, dry stuff. I assume they would just load up in wet, packable snow. | |
01-07-2018, 12:51 PM | #58 |
Picked up some new Locked Up RC wheels. I went with the Iconic in black, and Mirror bead locks. Spooned on a set of RC4WD Compass tires with CI foams. I wanted to try something just a bit taller than the Pitbull RockBeasts and these seem to fit the bill well. Compound on these tires is very tacky and I think they'll be a good all arounder. |
01-07-2018, 09:01 PM | #59 |
Well the truck looks great! Can’t wait to see what you add next
01-08-2018, 10:16 AM | #60 |
Ordered new custom Truggy Chassis - Similar Threads | ||||
first truggy build custom chassis what yall think | pstroke666 | 2.2 Scale Rigs | 6 | 04-09-2011 08:47 PM |
