11-24-2017, 05:32 PM | #21 |
Pebble Pounder Join Date: Oct 2015 Location: Greensboro
| Re: XXL Yota Build Thread
Got the frame extensions/ battery and electronics mount almost done today.. Sent from my iPhone using Tapatalk |
11-28-2017, 07:17 AM | #22 |
Well, cyber Monday cleaned out my wallet for the week on this build, a lot of vanquish, SSD,RC4wd, and locked up rc parts should be headed this way by this afternoon...
11-29-2017, 01:50 PM | #23 | |
| Re: XXL Yota Build Thread Quote:
Really not that bad. Since I used aluminum it maybe only added a few ounces. But it's well worth the sacrifice to be able to hide all the electronics and battery under the bed. Not sure if I totally like the design yet. May try another route but going to continue with mock up and see if it grows on me. May look better after whole chassis is sprayed with bedliner. Sent from my iPhone using Tapatalk | |
11-30-2017, 05:08 PM | #24 |
I guess this was a good way to come home after working 50 hours in 4 days.. too bad gotta go back into work again tomorrow I'd spend the day mocking up axles and links.. Sent from my iPhone using Tapatalk |
12-17-2017, 04:12 PM | #25 |
Well, I've been working crazy hours and had 2 sick kids for the last couple weeks but was finally able to work on a few things today. Finished up the grill and assembled my rear axle. Sent from my iPhone using Tapatalk |
12-23-2017, 01:56 PM | #26 |
Front and rear axles are finally complete... Sent from my iPhone using Tapatalk |
12-23-2017, 01:56 PM | #27 |
| Re: XXL Yota Build Thread Sent from my iPhone using Tapatalk |
12-23-2017, 06:49 PM | #28 |
So far this has been a productive day, axles are done, links have been mocked up, suspension is being tuned. Need to build a set of rear shock hoops to correct shock angle for ride height since I ditched the original frame extensions. Sent from my iPhone using Tapatalk |
12-23-2017, 07:47 PM | #29 |
Pebble Pounder Join Date: Jan 2014 Location: Archdale
lookin good what kind of wheelbase you gonna end up with ?
12-24-2017, 07:33 AM | #30 |
| Re: XXL Yota Build Thread |
01-01-2018, 07:39 PM | #31 |
| Re: XXL Yota Build Thread So my hood fell off today... should have some parts here from BowhouseRC.com tomorrow to help with this situation... Sent from my iPhone using Tapatalk |
01-13-2018, 08:30 AM | #32 |
Been really busy at work again, so been jumping around with this build some more. Mainly been doing some test fitting and a little fab work. Ended up finding a awesome deal on a new set of RC4wd bumpers so I will sell mine that i built. This way all the powder coating matches, also I'm lazy and this saves me from having to build a rear bumper... I did get the 4bt motor test fitted, As well as started mounting up the old tires on the new wheels. Been working on interior a little as well. Adding a few "chrome" details. Hopefully will be able to knock out some sliders and rear shock mounts today or tomorrow. Sent from my iPhone using Tapatalk |
01-13-2018, 09:15 AM | #33 |
RCC Addict Join Date: Jan 2012 Location: Vancouver
Are those rc4wd wheels or the knockoff ones?
01-13-2018, 12:07 PM | #34 |
01-13-2018, 12:09 PM | #35 |
Trying to piece together the body braces, hood mount, radiator supports from BowhouseRC.. parts only needed a little sanding. Hopefully the CA glue in using gets these attached with no problems... Sent from my iPhone using Tapatalk |
01-13-2018, 12:56 PM | #36 |
Well waiting on glue to dry, I want to finish up mounting the new wheels, but what do you do when the stock foams are too soft?? Easy way is order a set of CI foams but I didn't want to wait so I'll do what I've done in the past and it also is "free". Use some closed cell foam tape from work, black electrical tape and a little patience you can have yourself a dual rate foam.. Sent from my iPhone using Tapatalk |
01-13-2018, 02:06 PM | #37 |
All 4 done... it's kinda sad that I'll have 3 sets of tires and wheels just for this one rig... Sent from my iPhone using Tapatalk |
01-13-2018, 03:21 PM | #38 |
Gluing in the Bowhouse RC under hood brackets... Sent from my iPhone using Tapatalk |
01-13-2018, 10:38 PM | #39 |
Quarry Creeper Join Date: Nov 2015 Location: Walkerton
Just seen this build for the first time. Amazing! Like how you're taking it over the top.
01-14-2018, 07:50 AM | #40 |
| Re: XXL Yota Build Thread Radiator support glued in. I may have to trim it a bit to clear the chassis.. Sent from my iPhone using Tapatalk |
XXL Yota Build Thread - Similar Threads | ||||
jeeper_05's Vuckin Yota build...Now Hotwheels000's Vuckin Yota! | jeeper_05 | 1.9 Scale Rigs | 264 | 09-28-2015 12:17 AM |
Imthatguy's Yeti XXL Kit Build | imthatguy | Axial Yeti XL | 29 | 04-17-2015 01:59 PM |
Dual Dingo build thread-My first build thread | juswin24 | Axial SCX-10 | 205 | 09-19-2013 12:42 PM |
nick's crappy busted yota thread | mygolfisslow | RC4WD Trail Finder 2 | 38 | 04-01-2013 07:31 AM |
