12-21-2017, 12:14 PM | #1 |
Quarry Creeper Join Date: Jan 2013 Location: Athens
| LC 70 Hybrid chassis
Had a spare chassis when I got the defender d110 sometime back, I have the axles, had the SCX10 gear box. So ordered a center transfer case from aliexpress, links and skid plate. This one is gonna be a hybrid gelande rc4wd chassis setup with axial scx10 parts. Got the lc70 a year ago from rcmart but never got around to building it. That was a year ago.... This is a month back. Chassis assembled not too much modifications involved, just drilled a couple of extra holes on the chassis also the transmision of the motor is directly bolted on the chassis in front drilled out one hole there. and thats it. If anyone needs any additional photos with details just shoot glad to show them if i can. |
12-21-2017, 12:16 PM | #2 |
| Re: LC 70 Hybrid chassis |
12-21-2017, 12:38 PM | #3 |
Looks good. I’d like a closer look at the way you’ve got that trans bolted on.
12-21-2017, 12:46 PM | #4 |
RCC Addict Join Date: May 2015 Location: Price Twp.
12-21-2017, 03:03 PM | #5 | |
| Re: LC 70 Hybrid chassis Quote:
And looking from the bottom, hope this helps I had to drill out the front hole on the frame,then the alloy transmission is bolted on the frame only with 2 bolts and the motor just clears the body by 10mm but I had to trim some body stiffeners near the hood. I havnt drilled any holes on the trans just used the original holes as you were going to bolt it on the skid plate, only I bolted it sideways on the frame. Hope its clear. Last edited by STRAT; 12-21-2017 at 03:10 PM. | |
12-21-2017, 03:13 PM | #6 |
This is how it sits now |
12-21-2017, 03:14 PM | #7 |
I understand now. I’ve got a dual motor mount plate I saw for cheap years ago. I wonder if it would rotate the motor any more to center and away from the chassis.
12-21-2017, 03:22 PM | #8 | |
Just found that dual plate ! maybe it can be centered... Last edited by STRAT; 12-21-2017 at 03:26 PM. | |
12-21-2017, 03:42 PM | #9 |
couple of photos bottom side. battery moved to the rear |
LC 70 Hybrid chassis - Similar Threads | ||||
Hybrid chassis | himo | Tamiya Clod Buster | 22 | 08-15-2010 08:15 PM |
Hybrid chassis | turner3123 | Axial AX-10 Scorpion | 6 | 11-05-2008 09:28 PM |
