02-20-2018, 09:37 PM | #1 |
Newbie Join Date: Feb 2018 Location: Alabaster
| SCX10 II Kit Build Thread (First Kit Build&First Crawler) |
02-20-2018, 10:05 PM | #2 |
RCC Addict Join Date: Apr 2009 Location: LA
| Re: SCX10 II Kit Build Thread (First Kit Build&First Crawler)
I recommend either replacing the stock shocks with trx-4's or else at least rebuilding with green slime and thicker shock oil. Also, a longer 3Racing metal servo arm will give you more steer if you don't have a 180deg servo and programmable transmitter to run it. ;)
02-20-2018, 10:13 PM | #3 |
I appreciate your advise. I will definitely look into these attributes. I was going to do shocks next anyways as I can tell they inhibit travel pretty dramatically. So you recommend the trx4 shocks? What are they like 100mm? I was debating 100 or 110mm shocks. The stockers are fairly smooth so far but definitely too short, I did green slime and machine the piston mildly. As far as the steering goes, I have the Servo connected and by manually turning the tires I think I have max steering articulation. The tires about hit the frame rails, though that doesn't necessarily mean the servo will drive them that way if it's not 180 degrees. It came with multiple servo horns.. I think it may be a good idea to keep this plastic as I would rather strip the horn vs the servo if things get sketchy lol |
02-20-2018, 10:48 PM | #4 |
More Pictures. Im still waiting on a few parts for this build but man has it been fun so far.. In one of these pictures you will see how i modified the front bumper for a better approach angle, and it look better under the body.. yall let me have some instructive critisism.. mild droop setup right now. pretty good flex for mostly stock suspension.. what should i do next?? im thinking DRIVE IT haha |
02-20-2018, 10:57 PM | #5 |
Also i forgot to ask, since i already have this rig weighing over 7 lbs without a battery should i go light battery or go all out with a 1 lb 5000mah 50c 3s? thatll put me in middle weight with an scx10? what do yall think? also the hobbywing wp1080 has a built in bec capable of 6 volts, this servo makes peak torque of 499 in/oz at 6 volts, so do i need an external bec or am i good? the built in bec is sequential. Thanks again |
02-20-2018, 11:47 PM | #6 |
I have run both types of batteries... I prefer the light weight 2200Mah 3s... 499 oz is a lot of tq... I recomend a external bec. My understanding is the HW1080 is good for about 300 oz tq servos. Castle bec is my go to. |
02-21-2018, 04:55 AM | #7 |
I couldn't find the trx-4 shock length info, but the ever-popular super-smooth Traxxas big bore 2662 are 101mm eye to eye extended (best deal is qty 8 for $60 shipped on eBay in the 4962 pack). I too use the 3s 2200mah lipo batteries (Turnigy $12 from Hobbyking) and recommend the $20 castle 10amp BEC for your massive-torque servo. |
02-21-2018, 06:09 AM | #8 |
Thanks for the recommendation of the 2662. Y'all have helped me make my decision. That shock comparison pictures leads me to believe that shock length will be perfectly suitable for this application. I will use the factory axial springs with the stock oil and give those a try. As soon as they come in. Any idea if beef tips shock collar would fit the shock link? For some added weight? their website doesn't give dimension. And also about the esc, I was planning to run this esc but have yet to order it. Due to wiring simplicity and cleanliness I would prefer not to have to worry about running an external Bec. Is there an esc that is capable of handling this servo from a built in Bec? Or is this an absolute necessity? Thanks again guys for your help and recommendations. Money is not really an issue. I mainly want the best run times possible. That's why I was considering a larger battery, what is a typical run time for a brushed application such as this with low speed crawling only? Last edited by KrAwLeRFiNaTiC; 02-21-2018 at 06:12 AM. |
02-21-2018, 07:56 PM | #9 | |
| Re: SCX10 II Kit Build Thread (First Kit Build&First Crawler) Quote:
The BEC is necessary to protect your ESC from burning out, and is easily wired using an adapter like this: https://holmeshobbies.com/electronic...s-adapter.html Not sure if the shock collars will fit; sorry. :( | |
02-25-2018, 09:30 AM | #10 |
Well I installed all my electronics yesterday. I opted for the HW 80 Amp ESC, RC4WD 45 Turn Closed Endbell, Savox 1230 SG, Venom 5000 Mah 30c, and an external BEC. Something can't be right the motor didn't have any power it couldn't even spin the tires if I held the bumper on a smooth surface. I ran it for about 10 minutes maybe, and the motor burned out. I went through the programming on the ESC to ensure it was on lipo mode. And everything seemed good to go? I didn't want wheel speed, but I fully expected it to have enough torque to spin the tires over and not just lock up and smoke the motor. I also double checked the drivetrain, no binding and smooth. Any recommendations on what the issue might be? Gearing? Do I need to gear down more for more torque? Wiring? Perhaps that 10 dollar motor couldn't handle 3s? Maybe just bad luck? I'm going to get a little bit more extensive of a motor this time.. see if it was just that.. thanks ahead |
SCX10 II Kit Build Thread (First Kit Build&First Crawler) - Similar Threads | ||||
SCX10 II Kit Build Thread (First Kit Build&First Crawler) | KrAwLeRFiNaTiC | 1.9 Scale Rigs | 0 | 02-20-2018 09:02 PM |
My SCX10 II Kit Build w/ Pics (First Ever Kit Build) | KrAwLeRFiNaTiC | 1.9 Scale Rigs | 0 | 02-20-2018 08:54 PM |
Jayn Kit Build Thread | Jayn | Axial Yeti XL | 43 | 12-17-2015 07:32 AM |
Axial AX-10 Scorpion 1/10 Rock Crawler Kit Build, Chapter 2 "The Mod Build" | JAM MaxAmps.com | Axial AX-10 Scorpion | 42 | 06-06-2008 10:00 PM |
