06-20-2018, 07:52 PM | #61 | ||
Quarry Creeper Join Date: Apr 2016 Location: Canada, Ottawa/Gatineau
| Re: D90 Winch Challenge Pickup Quote:
Thank you both. 1. The styrene sheet thickness I use most is 0.060" and 99% of the time I fuse the pieces using MEK instead of gluing, way stronger bond. I bought a 4'x10' a few years back for my 2-1-Charlie project (Slickrock 2-1-Charlie) have use less than 2 feet of it so far. I also use some 0.035" for small detail work and have to come around to and buy some 1/8" eventually instead of constantly laminating 0.060" sheet when I need thicker stock. 2. The vise mounted bending brake is from Princess Auto in Canada (https://www.princessauto.com/en/deta...ke/A-p8663775e), which is similar to Harbor Freight in the US, and is available for the 4, 5, 6 and 8" vises. D | ||
06-21-2018, 07:05 AM | #62 |
Been a while since I checked in to this thread - very well done sir! Truck looks great, and love that so many things are built not bought.
06-21-2018, 07:18 AM | #63 |
| Re: D90 Winch Challenge Pickup Thank you, I try and make as much of it as possible unless what I need is not available or not cost/time effective to do myself.
06-21-2018, 07:35 AM | #64 |
Update 35 – April 2, 2018 Took time to make my own clear stickers for project D90 Winch Challenge Pickup, I am happy enough with the results to leave them on. The layout is not the issue, it’s the OK results of printing your own clear labels. Even on a good quality home printer, it will never equate that of those commercially available. And if you look closely, you'll notice that I added a novelty sticker on the dash... I finally made an antenna for my CB, it’s a bit on the short side for its location to have proper range, but anything longer and it might become a disposable item during roll overs. D |
06-22-2018, 05:58 AM | #65 |
Update 36 – April 3, 2018 Started work on what should be the last scale item to go on project D90 Winch Challenge Pickup. I cut a couple of round blanks from a sheet of styrene, drilled a hole in the middle of them all, stacked them nice and tight with a bolts thru the lot, then proceed to round them off roughly with the help of my drill a collection of coarse hand files. I then super glued the stack and spent a good hour profiling the styrene blank to my liking. Tomorrow night, I should start work on the balance. D |
06-24-2018, 09:23 AM | #66 |
Update 37 – April 5, 2018 One more scale detail for the books, I finished what I started yesterday on project D90 Winch Challenge Pickup. Here is one tip when doing any sort of kits, albeit RC or plastic models, always keep some of the scree from the parts trees, those leftovers will come in handy in the future! On with the show, I laminated and shaped more styrene sheets, use a piece of scree in the process, recycled the copper core of single strand electrical wires into rigid lines, and you end up with a scale brake servo (or booster). And upon completion of said brake servo, realize that the custom battery and battery tray I made a while back are on the wrong side of the vehicle. Let’s face it, a brake servo on the passenger side is not very useful! After relocating my already relocated battery (it’s supposed to be in the crew compartment under the passenger seat) to the proper side of the vehicle, I mounted the brake servo and an oil catch can (made out of styrene scraps) to the firewall. For Reference, this is the 1:1 Land Rover Defender Puma brake servo: D |
06-26-2018, 05:12 AM | #67 |
Update 38 – April 10, 2018 I received one more set of tires for project D90 Winch Challenge Pickup, some RC4WD 1.9” Goodyear MT/R 4.19”. Here you can see a comparison with the other tires I had purchased for this project; on the left we have the 1.9” Boom Racing Hustler M/TX 4.19”, in the middle the 1.9” RC4WD Goodyear MT/R 4.19”, and on the right the 1.9” Boom Racing Hustler M/TX 4.45”. Side views of the tires, all are mounted with the provided foams. Installed on the truck with the actual measured overall diameter: • 4.095” (104 mm) for the Hustler’s 4.19”; • 4.213” (107 mm) for the Goodyear’s; and • 4.331” (110 mm) for the Hustler’s 4.45”. Funny how just a few millimetres on the diameter can make such a difference (Insert joke here!) to the overall look! Now I just need to decide which ones to use. D Last edited by valheru; 06-26-2018 at 06:46 AM. |
07-03-2018, 06:54 AM | #68 |
Update 39 – May 9, 2018 While looking at the near end result of this build, I realised that the steering linkages were in a rather exposed condition, therefore I fabricated a bumper skid plate extension/steering guard to protect them. Can’t wait to try this build on the rocks, which should be very shortly at the monthly meeting of my local rock crawlers club. N.B. Yes there is missing hardware to fasten the skid, I ran out of M2 x 5 button head screws and an order was placed with my LHS. D |
07-09-2018, 08:23 AM | #69 |
| Re: D90 Winch Challenge Pickup |
07-09-2018, 08:26 AM | #70 |
Update 40 – May 16, 2018 First time with project D90 Winch Challenge Pickup on my home course in a while. I hadn’t run my truck since my first shake down run and figuring out that none of my current brushed motors were appropriate for a 13.5 lbs scaler. Post installation of a new Holmes Hobbies 550 27T brushed motor and the Goodyear Wrangler MT/R 1.9" 4.19" by RC4WD, the verdict is as follow: - She makes a solid “thud” with no bounce when rolling over or dropping onto obstacle. - The Goodyear MT/R are awesome (with the stock foams) and just work on every surface I threw at it; from wet and dry granite and limestone, mud, wet and dry wood, etc. - The HH 550 27T motor runs cool, has the perfect balance of top speed, torque and low end control for this beast! - And it is officially a baptised rock crawler with rock induced “patina”! D |
07-10-2018, 06:02 AM | #71 |
07-16-2018, 06:55 AM | #72 |
Update 42 – May 26, 2018 First scale crawl competition of the season and project D90 Winch Challenge Pickup exceeded all of my expectations. The 8274 winch is a beast, the Goodyear MT/R are the best performing and looking scale tires I’ve used so far, and we suffered no damages except for one lost shackle on the rear bumper... On a bummed note, the 1/16 Summit that my son normally uses for these comps (locked F/R diff, CC 10A BEC, Axial ESC and 45T 540 motor) suffered steering servo failure 5 minutes after the start of the event... Therefore he did the crawl with “Big Daddy” Wraith which as a tummy tuck and 5.75” tall tires; fun to use on any rocks, but very little challenge for such a vehicle at a scale event! On the bright side, the rain held off and we had minimal bugs, and the cage I made for the Wraith makes a good sandwich and juice box carrying platform for when you can’t decide if eating is more important than crawling! D |
07-23-2018, 10:31 AM | #73 |
Update 43 – July 7, 2018 The second scale crawl competition of the season is in the books and project D90 Winch Challenge Pickup, now known as “Big Blue”, is still exceeding what I thought a 14 lbs scale truck could do. I am now the official recovery vehicle of my team; with the impressive capabilities of the RC4WD 8274 winch and the sheer weight of the truck as an anchor, I can pull/drag any of the other scalers in my group with ease, as most only weigh half my weight. Only once was I forced to use a chain and the land anchor to hold Big Blue in place as to winch up my whole team up a bonus gate consisting of a 3 foot tall, 70 degree, smooth cement incline. Upon completion of pulling my team mates, I then proceeded to turn around, lower myself to the bottom of the hill before winching back up to make the bonus gate. Even on sketchy obstacles, such as a wire bridge designed for the track width of a TF2, the sheer weight of Big Blue just wrapped the tires around the wire and railed it all the way, but not before stretching the wires a bit! D |
02-05-2019, 01:32 PM | #74 |
Pebble Pounder Join Date: Jan 2019 Location: Douglas, MA
Amazingly clean build. You sir have some skills.
02-05-2019, 05:15 PM | #75 |
Rock Crawler Join Date: Dec 2005 Location: East Texas
Good thread bump Brian. I missed this build and am still working on a D90 PU myself. Wonderful build and thanks for sharing your outings Anytime the kids want to go RC'n just makes my day. Again, awesome build, please share if you have any updates. |
05-07-2019, 11:24 AM | #76 | |
| Re: D90 Winch Challenge Pickup Thank you Quote:
D | |
10-14-2019, 06:04 PM | #77 |
Newbie Join Date: Oct 2019 Location: Kalifornia
Kudos! Great build thread and learned so much - thanks for sharing.
D90 Winch Challenge Pickup - Similar Threads | ||||
From D90 to D110 pickup | Binnendoor | 1.9 Scale Rigs | 10 | 09-27-2017 01:44 PM |
D90 pickup | J55TTC | 1.9 Scale Rigs | 51 | 09-02-2017 01:05 PM |
1.7 D90 pickup | THEmicroRR | 1.5 Scale Rigs | 10 | 03-25-2014 11:00 PM |
