04-18-2018, 12:08 PM | #21 | |
| Re: Soze's HoBao DC1 Kit Build Quote:
The shock bodies are really sturdy looking. These shocks are more akin to the type of quality you see in the shocks of racing dirt buggies than the type of quality you see with the Axial Icon shocks if you know what I mean... | |
04-18-2018, 12:23 PM | #22 | |
I know exactly what you mean! I pulled my dad's shiny new SCX10 II RTR out of the box and the cardboard looked like a Harley Davidson had been sitting there. | |
04-19-2018, 06:20 AM | #23 |
Very stout looking truck. Almost overbuilt (that's a good thing imo) - I used to bash Ofna buggies back in the day, they were tough as nails for sure. Can't quite tell from the pics, but look like 4mm threading in the links ilo the usual 3mm? |
04-19-2018, 09:19 AM | #24 |
| Re: Soze's HoBao DC1 Kit Build |
04-19-2018, 10:28 AM | #25 |
| Re: Soze's HoBao DC1 Kit Build Steps 14-15: Shift linkage, Panhard, and Steering Servo mounting Here's a look at the shift linkage Shift mechanism mounted up Panhard mount Using the HoBao HB-5518MG 18.6kg servo my friend threw in. Not sure what rebranded servo this is... maybe another JX. Servo mounted up I'm using a Boom Racing 25T Low profile aluminum clamping servo horn for now, but the length of the hole isn't quite right when compared to the stock plastic one. The hole on the stock plastic one is in between the 2 holes on the Boom Racing horn. I'll take a deeper look when the steering rod and axles are mounted up. Last edited by soze; 01-26-2020 at 11:37 PM. |
04-19-2018, 11:17 AM | #26 |
RCC Addict Join Date: Feb 2016 Location: Princeton, North Carolina, USA
That shift linkage is the first somewhat sketchy looking piece so far. Will be interesting to see if it functions properly/consistently.
04-19-2018, 11:37 AM | #27 | |
The nice thing is that there is adjustability as far as those bushing/spring/brackets are concerned, and you aren't stuck with having servo adjustment only. | |
04-19-2018, 11:41 AM | #28 |
Shift linkage looks fine to me. They setup 1/8th scale buggy and truggy linkages like that. The metal plate on the outside of the plastic panhard mount for reinforcement is awesome. This truck impresses me more each time I see it. |
04-19-2018, 11:45 AM | #29 |
| Re: Soze's HoBao DC1 Kit Build That explains it. They have a background with 1/8th scale buggies after all.
04-19-2018, 11:49 AM | #30 |
04-19-2018, 01:00 PM | #31 |
RCC Addict Join Date: Jan 2012 Location: Vancouver
Very interesting. Wonder if or when individual parts will be available. What is the height of the chassis rails? Last edited by hillbillyrc; 04-19-2018 at 01:07 PM. |
04-19-2018, 01:55 PM | #32 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
In Europe they're widely available and priced lower or near Axial kits. But this looks so much better. The parts quality, I mean.
04-21-2018, 12:04 AM | #33 |
Pebble Pounder Join Date: May 2015 Location: UK
Will aftermarket SCX10 bumpers fit easily enough? I assume it will take most bodies with the right length posts.
04-23-2018, 11:12 PM | #34 |
| Re: Soze's HoBao DC1 Kit Build Steps 16-25 - Axles Alright, we're getting to the fun part and some "different" ways of doing things. Two bags for the axles. So here's the first "different" way of doing things.... axles use 3 piece housings. Parts for the gears, locker, and a diff gear mount/carriage? One side of the axle put together Diff assembly is a little different from others Diff assembly mounts/carriage The mount/carriage does make it easy to slide and secure the diff gear in there. Also if you look at the housing, you could easily swap the direction of the gear. Axle housing bolted up Front CVDs Steering knuckles. The steering link mount is a metal plate screwed into the knuckle. Steering knuckle, CHUB and CVDs all put together All mounted up to the axle housing Steering links added Rear axle put together Front axle mounted up to chassis Rear axle mounted up to chassis |
04-24-2018, 07:36 AM | #35 |
That's some solid looking parts. If you break anything on this one you are truly hardcore. Interesting that they did a separate punkin and diff cover, I've never seen that. Please continue, Sir |
04-24-2018, 09:26 AM | #36 |
Someone on reddit mentioned that these axles would look perfect for a 6x6 or military vehicle setup. Now that I think about it even more... I know we all scratch our head when it comes to that link mount on the axles... but you know.... that link mount may make it really easy to convert that over to some type of mount for a leaf spring setup. Imagine that! |
04-25-2018, 11:21 AM | #37 |
| Re: Soze's HoBao DC1 Kit Build Steps 26-28 - Shocks So again, we see some different way of doing things....at least as far as crawlers are concerned. Overall the shocks seem like good quality with a minor issue as far as the piston goes. The piston was a little too "sticky/snug" on two of them. I could probably fix it by sanding down the sides a little. Here is the instruction step showing what goes into building these shocks. I particularly like the bottom end with the flanged washers and o-ring setup. I think it'll help prevent leaks. The part I don't like as much is the piston. The piston is a disc with two cuts at the edges opposite each other rather than piston holes. Here's the body of the shock. Good material and metal caps. Ugh, I forgot to take a picture of the piston... but it's basically a disc with the edge chopped off on 2 sides. 1 shock put together. I feel like the springs are way too hard. I'll use them for now as they may compensate for a heavier body since the DC-1 has a body with a bunch of scale details on it. All 4 shocks put together. Alright... another different way of doing things. The shocks are mounted like a buggy. They're mounted from the front rather from the side like most crawlers do. Notice the front to rear mounting at the shock mount and the axle Same thing in the rear |
04-25-2018, 11:47 AM | #38 |
I like the shock mount methodology, seems more natural to the action of the shocks. I also think the edge-relieved pistons may not be such a bad thing, especially if they foresaw holes being blocked by the e-clips and impeding flow, like in the case of stock Ascender shocks, that generally require the outer perimeter to be modified to allow flow. |
04-25-2018, 11:53 AM | #39 | |
I'll have to take them apart later on and check it again. | |
04-25-2018, 12:22 PM | #40 |
RCC Addict Join Date: Feb 2017 Location: Surprise
That shock mount is different, i wonder what the advantages are ? More sturdier perhaps? Coming out great !
Soze's HoBao DC1 Kit Build - Similar Threads | ||||
Soze's GMADE GOM GR01 Build | soze | G-Made Crawlers | 69 | 08-20-2021 12:45 AM |
Soze's MST CFX-W Build | soze | Max Speed Technology CFX | 90 | 01-31-2019 01:02 AM |
Soze's Axial Yeti Kit Progress tracker. | soze | Axial Yeti | 31 | 03-09-2018 12:22 AM |
HoBao DC-1 | seedburns | General Scale Talk | 7 | 01-29-2018 06:39 PM |
