Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: 1969 Chev Prerunner
Old 05-29-2019, 12:37 AM   #1
Default 1969 Chev Prerunner
I realise I like to go fast so I'm building another semi go fast rig.
But I still want it to be a crawler when required so eschewing the usual independent front suspension for a solid axle.
Designing the whole thing in Tinkercad. With the body, cage, skid, interior and axles all 3d printed. The body was designed by Alexby with a remix for the wider pumped guards.
Axles will be ar44 based with SSD Pro axle centres. The front will be a offset pumpkin.
Building it around 4.19 tyres. Probably BFG KM3 Predators.
SSD Champion wheels will be used, with a custom bronze coating.
I have the capabilities to braze cages, but the learning from Brocky, my first brazed tube chassis, that the extra weight is such a detriment to crawling
Will be hoping to run it in C2.
May have two rear suspension setups. Long travel with trailing arms and a crawler setup with 4 link. Should be easy as swapping the skid.
Tempted to go real old-school and use a dual RC4WD Ohlins shock setup.
But details like that will come as they do.
Sent from my LYA-L09 using Tapatalk
nedmo is offline   Reply With Quote
Old 05-29-2019, 12:42 AM   #2
Default Re: 1969 Chev Prerunner
Subbed. Here’s a little inspiration, too.
https://www.google.com/search?q=67+7...iw=375&bih=553
Brake Weight is offline   Reply With Quote
Old 05-29-2019, 09:27 AM   #3
Crawlers can still use in independent front suspension!
jonnywachter is offline   Reply With Quote
Old 05-29-2019, 07:02 PM   #4
There was also be I saw the other day on crap book that they did a fender flare sides with 3D printing on the clod and a twin I beam front end. It was pretty sweet looking
hipkatgreaser is offline   Reply With Quote
Old 05-29-2019, 07:04 PM   #5
Old 05-30-2019, 06:28 AM   #6
Got the interior cage, roof lights and front bumper designed
Old 05-30-2019, 06:32 AM   #7
Originally Posted by hipkatgreaser View Post
Yeah that's awesome. Would love to see a scale 4wd twin traction beam!
Old 06-28-2019, 12:53 AM   #8
Bit more progress on the designs. I'm diy building a new 3d printer so can't actually start printing anything til that's done.
I also decided to try my hand at designing a transmission.
25% overdrive, both axles spin the same direction.
Chevron cuts gears. Going to see how they go strength wise printed.
1969 Chev Prerunner - Similar Threads
Chev SSR? Arnel 1.9 Scale Rigs 15 04-06-2014 10:29 PM
Mudin chev Chevytrucks Micro Scale Rigs 3 07-01-2012 10:42 PM
beater chev Gear.Head 1.9 Scale Rigs 5 07-04-2010 04:32 PM
Chev Crewcab Brenan 1.9 Scale Rigs 36 06-13-2008 09:26 AM
The Beater Chev Craig cw 1.9 Scale Rigs 3 06-03-2008 05:16 PM
