12-03-2018, 10:40 PM | #21 |
I wanna be Dave Join Date: Sep 2012 Location: Victoria, BC
| Re: Hardcore Sami
Such a kool build.
12-03-2018, 11:48 PM | #22 |
Quarry Creeper Join Date: Jun 2007 Location: Los Angeles
| Re: Hardcore Sami
Thanks!
12-04-2018, 06:37 PM | #23 |
| Re: Hardcore Sami
Not sold on the LED bar... |
12-23-2018, 08:00 AM | #24 |
I wanna be Dave Join Date: Aug 2004 Location: san jose
| Re: Hardcore Sami
Any update on this little guy?
12-23-2018, 12:02 PM | #25 |
| Re: Hardcore Sami |
12-25-2018, 03:12 PM | #26 |
| Re: Hardcore Sami
First shakedown cruise this morning! Not too many rocks to play with but I'll find a good spot tomorrow. So far the truck is pretty stable for a SWB rig, front bumper needs to be recessed at least 5mm (easy fix) and adding a rear bumper wouldn't hurt for climbing. I wish I could test the other chassis, it's so light with the Incision wheels! I might order one soon to try a different style of body (maybe Tamiya's FJ40) |
05-31-2019, 01:51 PM | #27 |
| Re: Hardcore Sami
Made a quick test with the Tamiya FJ40 body, fits really well but I'm not really sure I'll install it |
05-31-2019, 02:25 PM | #28 |
Newbie Join Date: Apr 2019 Location: Tacoma
| Re: Hardcore Sami
The mix of scale and technical CFRP is so nice, really great styling.
05-31-2019, 02:36 PM | #29 |
| Re: Hardcore Sami |
07-06-2019, 06:11 PM | #30 |
| Re: Hardcore Sami
Last session, I'm really impressed by the performance of this little rig. I haven't added any weight besides the brass knuckles, wheels are still plastic and I'm going back to the Axial axles (maybe with brass inserts) It's still not great at climbing on dirt though, but I have a few mods in mind to help a bit. |
07-08-2019, 02:58 PM | #31 |
Newbie Join Date: Nov 2017 Location: Greenville
| Re: Hardcore Sami
very cool! is there any where I could buy a set of the frame rails you designed?
07-08-2019, 10:01 PM | #32 |
| Re: Hardcore Sami
Love it. I'm using that same body on a cmx build right now, but I do like the more aggressive look with the wider axles.
08-06-2019, 08:08 AM | #33 |
| Re: Hardcore Sami
Some action from last weekend. I installed the rear Antirock sway bar in the rear, helped a little with climbing and added also front over drive gears (very subtle improvement as well) but overall I'm more and more impressed, there were maybe 2 lines at the end I was struggling with, following full size TRX4, Enduros and other great rigs fitted with brass bling. For now besides the suspension, the OD in the front and the SSD brass knuckles, everything is very close to stock (axles, driveshafts, chassis braces/mounts) Morning update: finally decided to install a Panhard in the front with a Locked Up RC HD mount This will create some space to maybe move the motor in front of the transmission. |
08-06-2019, 03:16 PM | #34 |
| Re: Hardcore Sami
Excellent shots! Love the look of this truck. Swaybar is a great idea, debating one for mine. |
08-06-2019, 04:14 PM | #35 |
| Re: Hardcore Sami
Thanks! There are still a lot of things I'd like to experiment with like an Enduro transmission for more front OD, a HH Snubnose to shave around 150g... and if I win the lottery, some VS4-10 axles (at least the front one). |
08-07-2019, 06:59 AM | #36 |
Newbie Join Date: Jun 2019 Location: Andover, United kingdom
| Re: Hardcore Sami |
08-14-2019, 09:32 AM | #37 |
| Re: Hardcore Sami
Just updated the entire power plant with the new Holmes Hobby Revolver Snubnose outrunner paired with a SW4. It's clearly not as fast as the Puller Pro Standard and it took me a while to decide between standard Revolver (which has a comparable torque to the Puller Pro I had) but I wanted to shave some weight and the Snubnose delivered: the Snubnose is 90 grams (with wires) and the Puller Pro 210 grams. I also replaced my old puffy 3S 2200mAh Lipo with a new Reedy Wolfpack 3s, and I kind of regret the purchase, it adds a lot of weight upfront. I might stick with lower mAh packs in the future and keep running the old one for now. On the rocks, I could barely feel any improvements, but I only drove it with the Reedy battery, I'll test the new setup with the old battery this weekend. I also changed the shocks oil, from 30WT to 15WT (I can already feel the improvement) Next on my list are tires. I'm thinking of a set of Hyrax Predator, Element wheels. What foam would you suggest, the rig is below 5 pounds. End of day poser shot |
08-14-2019, 12:10 PM | #38 |
| Re: Hardcore Sami
Great looking truck! I still love the stance of this thing.
08-14-2019, 12:21 PM | #39 |
| Re: Hardcore Sami
Perfect little motor for a perfect little truck... I have the older model standard Revolver, but it's powering a much heavier rig. Your choice of using only black and white logos on the body really suites the overall look! |
08-14-2019, 12:49 PM | #40 |
| Re: Hardcore Sami
Thanks, Any experience with water or sand using the Revolver? That was the main concern I had (I miss the speeda little bit too it handled so well for such a small setup) |
Hardcore Sami - Similar Threads | ||||
Hardcore 69 action | 1tonscout | Non Crawler RC's | 1 | 06-19-2013 03:46 PM |
Hardcore photographer | constantmotion | Chit Chat | 9 | 08-22-2011 02:03 PM |
Hardcore Crawlin' | JoeMotor | Videos! | 6 | 05-28-2009 10:02 PM |
