09-24-2019, 05:04 PM | #41 |
Quarry Creeper Join Date: Apr 2017 Location: Melbourne Australia
| Re: Chopped and Dropped Class 2 D90
Got it swapped around to left offset and on the jacks for a poser photo! I have been designing running boards and inner fenders. I'm waiting on my trans, rear axle and gears for the transfer case before I go further. I do need to cut the body, but I'm honestly a little daunted by this!! Sent from my LYA-L09 using Tapatalk |
09-24-2019, 05:11 PM | #42 |
RCC Addict Join Date: Aug 2005 Location: Oceano, CA
nice work on the offset tubes. i may have missed it, but what front axle shafts are you planning to run?
09-24-2019, 05:13 PM | #43 |
| Re: Chopped and Dropped Class 2 D90 |
09-24-2019, 05:30 PM | #44 | |
| Re: Chopped and Dropped Class 2 D90 Quote:
I was thinking of designing and printing a few guides that I can clamp to the body while I make some of the cuts. I've been leaning more towards using fine toothed saws over a cutting disc since the discs tend to melt things as they cut. Now I'm wondering how a oscillating tool might fair? It would need a guide for sure but they can do plunge cuts that a normal hand saw couldn't. The offset axle looks nice | |
09-24-2019, 05:33 PM | #45 | |
Going to do some practice cuts first to see how it goes. Sent from my LYA-L09 using Tapatalk | |
09-24-2019, 05:49 PM | #46 |
Oh I forgot about that method, I've never tried it. I might test it out too.
10-13-2019, 07:01 PM | #47 |
So got the transmission all assembled! Can't believe that I nailed the gear mesh first time! Sent from my LYA-L09 using Tapatalk |
10-13-2019, 07:15 PM | #48 |
RCC Addict Join Date: Jun 2010 Location: Australia NSW
Seems I missed a few of these updates. Looks like ur smashing out some of these details. Your axle tubes give my ideas for my build. I can see yours are printed but it makes me wonder if ar60 tubes would work over the top of ar44 housings for an offset pumpkin to suit my Jeep projects. Keep ur progress rolling |
10-15-2019, 03:17 PM | #49 | |
Got the skid finalised and trans mounted. Now I need to get to design the front LNC mount and dual servo plate. Sent from my LYA-L09 using Tapatalk | |
10-16-2019, 04:55 PM | #50 |
Got my rear links setup. Using 90mm icons for mockup. It looks like to me I could benefit from making the top shock mount higher so that I can get more up travel. Haven't done a build like this before so input would be appreciated. Sent from my LYA-L09 using Tapatalk |
10-16-2019, 05:33 PM | #51 |
I'd base the up travel on tire size and the wheel opening at the body. So put the body on and judge it? |
10-16-2019, 06:22 PM | #52 | |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
Ernie | |
10-16-2019, 07:13 PM | #53 | |
While I agree with you, if the shocks bottom to the frame then the body will have to be higher relative to the frame which will raise center of gravity. I personally prefer the body to be at a realistic position relative to the frame and then mod arches and travel to suit. I guess this is the difference between my preference to realism, vs a competitive vehicle. Suspension wise, I've always aimed to get the bottom of the shock body appropriately level with the bottom of the frame and then choose shock length and then top mounts based on how much articulation it requires. | |
10-16-2019, 08:29 PM | #54 | |
Ernie Last edited by CODYBOY; 10-16-2019 at 08:45 PM. | |
10-16-2019, 11:13 PM | #55 |
Haha, its like the two voices in my head. I can see merits to both arguments. In reality the body will end up being the the limiting factor for this particular build. even with my agressive chop. Body sills are going to be sitting on the sliders. So I think as Klampy suggested, im going to get the body mounted (daunting!) and then work on shock placement. Thanks for the both input. |
10-17-2019, 08:22 PM | #56 |
Ok so got the wheelbase basically right (might need to pull the front in 5-10mm) Got the body mocked up in 4.75 tyres. I think it's sitting too high personally. So I think 4.45" tall Pitbulls Rock Beasts will be better. Last photo shows the rear shock length at this ride height. Sent from my LYA-L09 using Tapatalk |
10-17-2019, 09:56 PM | #57 |
Like!!! |
10-18-2019, 02:35 AM | #58 | |
I typically run shocks around 30/70 with more droop than uptravel. Hope that helps | |
10-19-2019, 12:27 AM | #59 |
Yep also going to order some shock keys to kick the shocks back/forward on angles to get more up travel. Played around with mounting the LMC trans. Im tossing up if its too high to be a performance modification. Technically the motor in this position is higher than if I used a 3 gear trans. But it's a good chunk of weight up front. Photos of the different positions available to me. Sent from my LYA-L09 using Tapatalk |
10-19-2019, 12:47 AM | #60 |
I try and aim to put the motor shaft where the crank would go in the real engine. For me, it creates the most realistic weight balance. For example, I've just picked up an scx10.2 for my xj project. I'll be spinning the stock trans and placing it in the position the auto would go, and then the motor will be on the back of a planetary reduction, and then connect to the strains via the spur shaft. |
Chopped and Dropped Class 2 D90 - Similar Threads | ||||
I hate seeing early broncos chopped up. So I chopped up my Wraith. | daign | Axial Wraith | 17 | 11-13-2011 07:35 PM |
dropped and chopped MRC | Etype R | Losi Mini-Rock Crawler | 31 | 01-22-2010 09:11 PM |
TLT All Chopped Up for 1.9 class | SVEN | Tamiya TLT Crawlers | 25 | 12-06-2008 09:17 AM |
