01-29-2019, 02:26 PM | #21 | |
Pebble Pounder Join Date: Jul 2008 Location: Orem
| Re: 1st gen Durango IFS TRUE SCALE (you're going to want to see this) Quote:
01-29-2019, 02:29 PM | #22 |
| Re: 1st gen Durango IFS TRUE SCALE (you're going to want to see this) I browsed the forum for a couple of days before I posted anything and I saw quite a bit of interest in a scale IFS kit. It seems although it's not going to give you the most flex, its similar to the leaf spring trucks id say, just a scale factor.
01-29-2019, 02:40 PM | #23 |
Rock Crawler Join Date: Jun 2017 Location: Land of burning couches
| Re: 1st gen Durango IFS TRUE SCALE (you're going to want to see this) correct, and some of us aren't incredibly worried about having mega flex, but more of a trail truck vibe. Me in particular, I would be looking for a semi trail, but mostly shelf queen Raptor for my office that looked scale. I'm a Ford/Lincoln Sales Manager.
01-29-2019, 03:20 PM | #24 |
Some inspiration I have looked at. |
01-29-2019, 03:38 PM | #25 |
Rock Crawler Join Date: Nov 2014 Location: Dells
Front wheels are still attached. Not scale |
01-29-2019, 04:35 PM | #26 |
Pebble Pounder Join Date: Mar 2007 Location: Northern Ontario
| Re: 1st gen Durango IFS TRUE SCALE (you're going to want to see this) |
01-29-2019, 06:57 PM | #27 |
The idea I had was to use a pumpkin from the after market axles I got and design new tubes to be the right length, I want it to be offset so one will be longer than the other. That’s all fine and easy.
01-30-2019, 12:49 AM | #28 |
Got the diff pumpkin drawn up and roughly mocked up in the chassis tonight, I didn't have much time to work on it but I wanted to get something done. looks like it will fit nicely, the driveshafts on the other hand may be a little short. Once I get the drive shafts in, ill be able to mock those up and we will have a better idea. I'm also looking into getting the SSD transmission/ transfer case to use with this and be ready for the second stage of the build which will be the interior and engine bay. |
01-30-2019, 08:40 AM | #29 |
Like a Zook Sidekick front setup. Offset solid axle center with equal length CV axles. |
01-30-2019, 09:10 AM | #30 |
Yea basically, similar to how my 4x4 Durango is also, the diff is on the other side, but oh well.
01-30-2019, 10:43 AM | #31 |
On another note, I want to put a set of flares on the Durango body, I was going to design my own but before I decide to tackle that, does anyone know of some good flares for a smaller 1.9 tire that are only 15mm wide? So far I have bought two sets and they are way bigger than I expected. I found some "injora" rubber Cherokee flares that look nice, they state they are 317mm.. I have no clue what that measurement refers to though. |
01-30-2019, 11:33 AM | #32 |
Those appear to be Axial Bfg's so you are looking at a 4.65" tire covered by the flares...
01-30-2019, 01:03 PM | #33 |
RCC Addict Join Date: Dec 2014 Location: So Cal
What are you planning on using for a front diff? Will the upper be an A arm, J arm or camber link? Axles may also be a hard find item, perhaps something plunging with cvds to fit the "scale" part (you only get about 30-35 degrees out of the cvds)? FYI, you only get about 30 degrees or less out of most rod ends, looking at you lower arm and pulling 30 mm travel out of it. Loving the idea you have here, look forward to seeing you pull it off. Lifted sky high, this rig looks sick!!! Keep'r rolling.
01-30-2019, 01:23 PM | #34 | |
Also, with the length of the front arm, and the axial rod ends and balls, the front end has 37mm of travel. Edit: thinking about it now the top arm will be shorter and affect the total travel. Last edited by jonnywachter; 01-30-2019 at 01:47 PM. | |
01-30-2019, 02:25 PM | #35 |
Scroll down and there’s some cheap-Os to possibly use for experimenting. https://m.banggood.com/search/cvd%20drive%20shaft.html |
01-30-2019, 03:55 PM | #36 |
OK, I've done some searching and it seems like the losi rock rey front axle would have a really good chance of being able to work, unfortunately, they are pretty expensive at $50 an axle. what other independent front ends are out there with a similar telescoping front axle. |
01-30-2019, 04:05 PM | #37 |
Slash 4x4
01-30-2019, 04:17 PM | #38 |
01-30-2019, 04:21 PM | #39 |
Quarry Creeper Join Date: Feb 2018 Location: East otis
Yeah you can cut down the plastic slash rear axles. They are like 10 bucks each. Can find take offs for 15 a set, but they go fast Sent from my SAMSUNG-SM-G920A using Tapatalk |
01-30-2019, 05:53 PM | #40 |
How long do the axles need to be, joint to joint? Traxxas is cheap, maybe Bandit sized cvds will work. Slash 4x fronts will be a no go, inner bearing is too big for 1.9s. U-joint "offset" will now determine your pivot locations, spindle and chassis, making you have to edit your drawing, no big deal there other than you may end up too wide for your body. Its easier to engineer that way with axles in your hands. Another cool thing is being able to change the arc of the upper arm to change camber if you need to.
1st gen Durango IFS TRUE SCALE (you're going to want to see this) - Similar Threads | ||||
IFS Durango from 1.9 section | Joshs4x4toyz | Chit Chat | 97 | 03-11-2019 06:45 AM |
