02-02-2019, 12:25 AM | #61 |
Pebble Pounder Join Date: Jul 2008 Location: Orem
| Re: 1st gen Durango IFS TRUE SCALE (you're going to want to see this)
Basically at this point its an entirely new truck minus chassis rails. Last edited by jonnywachter; 02-20-2019 at 09:08 AM. |
02-02-2019, 09:00 AM | #62 |
RCC Addict Join Date: Dec 2014 Location: So Cal
Take a bellcrank setup and have it 90 degrees off axis, horizontal so they swing down. Have the tie bar on the opposite side of the tie rods (normal location), servo drive rod could hook there as well. Not scale, but you can prove your theory and would allow for infinite theoretical tie rod mounting locations to minimize or even eliminate any bump steer. Plan B makes me think of Traxxas Summit suspension, done with prop rods. That may be the better option as I invent your build in my head.
02-02-2019, 11:46 AM | #63 |
I didn't really like the idea of the 90* bell cranks because of the inherent issues with bump steer, the ball height changes as the bell crank moves so basically the bump steer is always changing as the wheels are turning. I went ahead and designed it anyway and fought with it for the last couple of hours with no prevail. I'm going to work on a sliding type of mechanism next. This will be a lot more consistent, my only worry is dirt getting into it and binding up. |
02-02-2019, 12:00 PM | #64 |
Dirt binding the sliding bar is a very valid concern. Twin hammers has that arrangement and it is a constant issue.
02-02-2019, 01:42 PM | #65 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: 1st gen Durango IFS TRUE SCALE (you're going to want to see this) |
02-02-2019, 01:55 PM | #66 |
02-02-2019, 04:59 PM | #67 |
Twin chassis mounted servos with a link between the arms? Same idea, more torque, and...something else... I would personally move the moving bits to face the back to hide it some. Would any of the Twin Hammers aftermarket steering ‘fixes’ be use? |
02-02-2019, 05:47 PM | #68 |
| Re: 1st gen Durango IFS TRUE SCALE (you're going to want to see this) LOL, adding two servos would probably complicate things more than it will help. I considered moving everything to the back but that takes away from the scale appearance IMO
02-02-2019, 06:41 PM | #69 | ||
| Re: 1st gen Durango IFS TRUE SCALE (you're going to want to see this) Quote:
Ok, I don't have a math/geometry back ground but have been building custom trucks on here for a number of years. I don't know if any of it will help you but here is a thread that has a whole new IFS I put together for my Hammer. It has a bell crank system and next to no bump steer. No big deal if you poo poo it, but hoping it will give you a little insight for your design. What you're doing is very cool and I envy your drawing skills. Codyboy" TwinHammer rebuild V2 Ernie | ||
02-02-2019, 06:46 PM | #70 | |
02-02-2019, 10:41 PM | #71 |
Seeing that you will 3d print everything, print a shock body that has a thru shaft, mini rack. Pull off one side to the servo. Shock shaft length to match the appropriate pivot points. Problem solved. Big servo will drive that all day long.
02-03-2019, 01:34 AM | #72 |
After 12hrs of designing 10 different possibilities this is the best I've got so far. The steering angle is less than desirable but there is virtually no bumpsteer. I'm on the right track! |
02-03-2019, 06:37 AM | #73 |
Granted this is a Yoder, I just saw this ad and thought it could be of some use to this project. http://board.marlincrawler.com/index.php?topic=103556.0 |
02-03-2019, 07:12 AM | #74 |
Not hydraulic, but a mini rack. No piston, just o rings on either side, like the bottom of a shock body on each side. Use one of the sides as a common end and use some flat bar to connect to the servo, making it a cms. Print mounting tabs on the "rack" body. Keeps dirt out of the rack that way. Doesn't need to be very long either. A linear guide if you will. Found now???
02-03-2019, 11:16 AM | #75 | ||
Anyway I woke up with an epiphany and got right to work. Last night I kept making the spindle arms longer to change the geometry and in turn I was just making a longer lever that had to move further to accomplish the angle I wanted. So I went back the opposite direction and kept shortening it. Ended up with a setup that gets more steering angle than the CVD will allow which is what I ultimately wanted. This angle is over 90* of total movement now. Now I just need to figure out where the servo will fit. | ||
02-03-2019, 01:50 PM | #76 |
Cvds only get about 35 degrees of angularity. Steer shaft woes, tap and die set, or singularly, and cut your own threads on the length desired. I just hope 3d printed parts will handle the abuse for your sake.
02-03-2019, 03:24 PM | #77 |
| Re: 1st gen Durango IFS TRUE SCALE (you're going to want to see this) Not all CVDs are created equal.... I’m very familiar with the SLS nylon I want to use. I’m confident it will hold up to the task.
02-04-2019, 07:51 PM | #78 |
Drew up the wheels and tires and "brake" hubs to get a better idea of the clearance of things and im lucky I did because its very close. Check it out! Also I wanted to show how compact the steering ended up turning out, nothing hanging out in the way at all. What do you guys think of the servo position? Will it be in the way there? I cant really find a better place for it. |
02-04-2019, 08:23 PM | #79 |
Pebble Pounder Join Date: Mar 2007 Location: Northern Ontario
Nice. Looks like you could spin the servo 180 degrees so the output shaft is facing backwards. Then instead of a servo arm you can run a printed gear and make it rack and pinon. |
02-05-2019, 12:37 AM | #80 |
| Re: 1st gen Durango IFS TRUE SCALE (you're going to want to see this) OH I definitely thought about it, I don't think the 3D printed gear could hold up to any sort of torque though. |
1st gen Durango IFS TRUE SCALE (you're going to want to see this) - Similar Threads | ||||
IFS Durango from 1.9 section | Joshs4x4toyz | Chit Chat | 97 | 03-11-2019 06:45 AM |
