02-05-2019, 12:46 AM | #81 |
Pebble Pounder Join Date: Jul 2008 Location: Orem
| Re: 1st gen Durango IFS TRUE SCALE (you're going to want to see this)
This thing is getting complicated, so many parts packed into this little area, also I started the flares and they were a lot easier to draw than I had first imagined. |
02-05-2019, 11:16 AM | #82 |
RCC Addict Join Date: Dec 2014 Location: So Cal
Looking at the last pic, simply print a couple blocks (like 2 rod ends sticking out the front), use some m3 all thread for the rack. Allows you to use jam nuts to keep the "drive" lever off the rack's shaft secure, and a short tie rod or flat stock to the servo. Prototype. Ideally add a tab to shaft stock that has been threaded on the ends. I'll sketch you a picture so you can make sense of my ramblings...
02-05-2019, 11:39 AM | #83 | |
| Re: 1st gen Durango IFS TRUE SCALE (you're going to want to see this) Quote:
02-06-2019, 07:20 AM | #84 |
Newbie Join Date: Apr 2017 Location: South Africa
Getting my Slippers out pulling up a comfortable chair Yes, thats right fat boy sit down relax, get the popcorn out... Can not wait so see the end result. |
02-10-2019, 07:41 AM | #85 |
Pebble Pounder Join Date: Aug 2012 Location: Baltimore
Very nice work! Wish I had those kinds a CAD skills. The only addition that I would make is to add a connecting link from the bottom rear cross member back to the horizontal part of the chassis. That would help to keep the whole assembly from wanting to rotate under load, and help to keep it from hanging up if you need to back up. I will be keeping an eye on this one.
02-10-2019, 02:55 PM | #86 |
Come on bro, its been 5 days...... nada. Really? I am soooooo looking forward to seeing a working prototype, as are countless others here. So lets be seeing it. Life seems to always get in the way somehow, we just need another update of your CAD skills.
02-11-2019, 05:17 PM | #87 |
| Re: 1st gen Durango IFS TRUE SCALE (you're going to want to see this) LOL I'm sorry I've kept you guys waiting, to be honest I've been waiting for parts to show up so I can continue, so there really hasn't been much progress yet. I also decided to take a road trip to Cali and attend the King Of Hammers race, I'm sure a lot of you are familiar with. Going to get back on the computer tonight and make some progress with the new parts I got in tho! So stay tuned |
02-11-2019, 05:18 PM | #88 | |
02-11-2019, 05:21 PM | #89 |
What do you guys think I should do for skid plates? Originally I was thinking is to have standoffs extruding from the main sub-frame that would be in the correct orientation to mount a piece of thin aluminum to.
02-11-2019, 06:58 PM | #90 | |
Sounds good to me. | |
02-11-2019, 07:00 PM | #91 |
Well its funny how things work out, I purchased some Yeah Racing adjustable CVD's for a TT02D, got them modeled up and fitted in the assembly. I'm messing around with the lengths and 48mm (center to center of the swing shaft ball ends) seems to be the right length. Well now that I know the correct length I research 48mm CVD's and an axial yeti Jr CVD comes up. I cant find any measurements online so if there is anyone out there that could confirm these are 48mm it would be great to stick with axial products. My only issue with the yeti jr shafts is the axle part and how is attaches to the wheel. What are your guys opinions on this? |
02-11-2019, 07:12 PM | #92 |
I don’t think the YJr would be a good choice. It’s discontinued for 1, 2-it was never popular, 3-it was more of a 1/18 with a 12mm hex.
02-12-2019, 12:45 AM | #93 |
I redesigned the front spindle for a more scale appearance and now the full suspension travel can be utilized, the rod ends were causing a lot of limited travel and binding before this design. Also, another update, the front end had somehow grown to be 0.1" per side wider than the rear end so I had to go in and shorten everything up. That effected the axle length which means they are now 46mm swing shafts. If anyone had any info on a readily available 46mm CVD, please advise! (the dog-bone end had to be the smaller 6mm ball) Last edited by jonnywachter; 02-12-2019 at 12:53 AM. |
02-12-2019, 03:23 AM | #94 |
| Re: 1st gen Durango IFS TRUE SCALE (you're going to want to see this) |
02-12-2019, 05:29 AM | #95 |
Newbie Join Date: Aug 2012 Location: Philadelphia
Wow, I can't wait to see how this turns out! The Solidworks modeling looks excellent!
02-12-2019, 08:13 AM | #96 | |
| Re: 1st gen Durango IFS TRUE SCALE (you're going to want to see this) Quote: | |
02-12-2019, 09:38 AM | #97 |
Pebble Pounder Join Date: Mar 2007 Location: Northern Ontario
| Re: 1st gen Durango IFS TRUE SCALE (you're going to want to see this) I think I would have just made narrower hexes for the front to correct it. (or wider hexes in the rear)
02-12-2019, 10:13 AM | #98 |
| Re: 1st gen Durango IFS TRUE SCALE (you're going to want to see this) Wider hexes in the rear would make the track width wider than stock and the hexes in the front are as narrow as they can be. The idea has come up a few times to build off this kit and possibly make a "long travel" version that would be wider, also a 2wd version where the front end would have better ground clearance.
02-12-2019, 01:01 PM | #99 |
Have you actually put the front diff together to really know the diff width and therefore true axle lengths? Is your axle selection going to be strong enough if it comes from a smaller, lighter vehicle?
02-12-2019, 01:26 PM | #100 |
| Re: 1st gen Durango IFS TRUE SCALE (you're going to want to see this) Currently, the diff that is modeled up is the exact dimensions of the diff I have, everything theoretically is going to work just fine. I ordered the SSD pumpkin but the size of the holes for the axle tubes are too small to utilize the same design that I have for the other diff. My main focus is on getting this preliminary design finished and printed so I can have a working prototype. Ill be able to get a much better idea of the direction I want to go after that. As far as the CVD axle strength, I doubt there will be any issues considering the parts are way overbuilt for their application, but there will be lots of testing to confirm this anyway.
1st gen Durango IFS TRUE SCALE (you're going to want to see this) - Similar Threads | ||||
IFS Durango from 1.9 section | Joshs4x4toyz | Chit Chat | 97 | 03-11-2019 06:45 AM |
