02-12-2019, 02:26 PM | #101 |
RCC Addict Join Date: Dec 2014 Location: So Cal
| Re: 1st gen Durango IFS TRUE SCALE (you're going to want to see this)
I broke somewhere around 10 axles on my Bomber before coming up with the current program. At least you are 1.9s, less strain on the driveline. How you getting from the r/p to the axle stubs? Something already available with cups and a long shaft?
02-12-2019, 02:37 PM | #102 |
Pebble Pounder Join Date: Jul 2008 Location: Orem
yes and no, the tt02 drive cups I've got are the closest things I have found so far. They have a round 5mm shaft with flat spots on both sides, the R/P needs a 4.3mm flat spotted shaft so I'm going to turn the set I have down on my lathe.
02-13-2019, 05:49 PM | #103 |
What do you guys think of the new spindle and top arm design? Also i'm thinking about changing the steering again |
02-13-2019, 07:41 PM | #104 |
Upper joint is off axis with the lower. You just lost your steering angle, if the axles would allow for it, right? If not, give me the part number for them so my Bomber can get an upgrade over Traxxas rod ends.
02-13-2019, 09:21 PM | #105 |
no talent hack Join Date: Feb 2007 Location: Redwood City
Yeah max steering is now equal to the deflection of the rod end. That’s not going to be very good
02-14-2019, 09:03 AM | #106 | |
| Re: 1st gen Durango IFS TRUE SCALE (you're going to want to see this) Quote:
Its supposed to be off axis. Also, I have a theory that the rod end will be able to swivel in the spindle allowing the steering to still have the max angle the CVD will allow. | |
02-14-2019, 09:18 AM | #107 |
Swivel in the spindle? Won't that jack the caster up or be the first part to wear out, especially being a 3D printed part?
02-14-2019, 09:47 AM | #108 |
| Re: 1st gen Durango IFS TRUE SCALE (you're going to want to see this) The SLS nylon is pretty wear resistant, it's hard to even sand it down. The caster wouldn't be affected because its just pivoting in the same axis as the ball. IF we say the rod end is fixed and doesn't move then, there are two options here either more travel or more steering angle. I think more travel is better than steering angle, considering this is built for a scale look and not performance.
02-14-2019, 12:37 PM | #109 |
How do finished SLS pieces look? Do they print fairly smooth or does it take the acetone vapor bath or evercoat to smoothen them out?
02-14-2019, 12:51 PM | #110 |
| Re: 1st gen Durango IFS TRUE SCALE (you're going to want to see this) They are very smooth, if you have curved surfaces you will see the stepping of the layers, but the layers themselves are quite thin. They also hold a tolerance of 0.0015" which is really nice for repeatability.
02-14-2019, 01:02 PM | #111 |
Wow, very impressive, using how large of a filament? Do you print your own or farm out to something like Shapeways? Also, is the SLS a hard material or something more like a RPM flexible product?
02-14-2019, 01:12 PM | #112 | |
"Typical applications of the material are fully functional parts with high-end finish right from the process, which easily withstand high mechanical and thermal load." data sheet: https://www.shapeways.com/rrstatic/m...strongflex.pdf Last edited by jonnywachter; 02-14-2019 at 01:15 PM. | |
02-14-2019, 03:05 PM | #113 |
I wanna be Dave Join Date: Feb 2009 Location: Detroit
I use shapeways for all of my printing needs. even brass. I am a little curious as to why you didn't design something to use a twinhammer knuckle? you would get a few more mm of a arm clearance to the ground. |
02-14-2019, 03:14 PM | #114 |
| Re: 1st gen Durango IFS TRUE SCALE (you're going to want to see this) The Twin hammer knuckle isn't really the scale look I'm going for. It looks really good though. Most 1:1 trucks have a knuckle with ball joints similar to my design.
02-14-2019, 10:38 PM | #115 |
Servo mount done (almost) Skid plate mounts done. Steering finalized. rear bracing, there. (may change it) |
02-14-2019, 10:48 PM | #116 |
Gotcha. Full scale apearence. What trans do you plan on running? Sent from my LGMP260 using Tapatalk |
02-14-2019, 11:00 PM | #117 |
| Re: 1st gen Durango IFS TRUE SCALE (you're going to want to see this) Yes, that's been the goal from the beginning. There are much better IFS rigs out there that will out perform this no matter how well I make it. Its always been an appearance-first goal. I have the SSD trans, the Bracket is modeled into the sub-frame so it will bolt right up.
02-15-2019, 06:58 PM | #118 |
I ordered some Xtra speed aluminum rod ends and they have just a little more throw which is great, but they are also a lot shorter and smaller diameter. The problem is they are way better for this application but they are not an axial part and the parts are designed around these rod ends. The specific holes they fit in, the depth of the holes, most of the components have to change to make these work, but it works better.
02-16-2019, 12:18 PM | #119 |
RCC Addict Join Date: Oct 2014 Location: UK
Aluminm rod ends usually have very sloppy balls
02-16-2019, 10:00 PM | #120 |
| Re: 1st gen Durango IFS TRUE SCALE (you're going to want to see this) The rod ends I got are not the most precise but id take the tiny bit of slop over the soft, short angle axial ends, At this point with recent comments in the thread I think ill design it the way I want and go forward with the aluminum ends.
1st gen Durango IFS TRUE SCALE (you're going to want to see this) - Similar Threads | ||||
IFS Durango from 1.9 section | Joshs4x4toyz | Chit Chat | 97 | 03-11-2019 06:45 AM |
