02-09-2019, 05:30 PM | #1 |
Rock Crawler Join Date: Jun 2009 Location: UK
| Just a Power Wagon for some Fun!
As much as I love my 2 Hilux builds, I miss a really capable truck. So, when Axial announced their builders kit, I decided to build up a Class 2 truck. The premise of this build is 1) Capable, and 2) Simple. Having looked at a lot of build threads on forums and Instagram I decided to go for a Proline Power Wagon body. I think I'm going to paint it inside and out, but more on that later in the build. I went with some SSD Pro44 axles, and I have a spare GCM scale transmission so decided to use that for 2 reasons. 1) to keep things low so I can get a simple interior in, and 2) to get overdrive to the front axle. Here's how the truck looks loosely assembled. So, I set to work on a simple rear cage. That's where I'm up to so far. Next up will probably be some sort of simple front bumper. I'm going to add a fairlead just in case I want to add a servo winch at a later date. |
02-09-2019, 05:32 PM | #2 |
Pebble Pounder Join Date: Sep 2018
| Re: Just a Power Wagon for some Fun!
That cage looks awesome dude!! Sent from my ONEPLUS A6003 using Tapatalk |
02-09-2019, 05:35 PM | #3 |
| Re: Just a Power Wagon for some Fun! |
02-09-2019, 07:05 PM | #4 |
Quarry Creeper Join Date: Mar 2018 Location: Indonesia
Cleanest welding job I've ever seen on an RC. Heck, that would be a very clean welding job on a 1:1 if it was scaled up. Would you be willing to share with us how you manage it?
02-09-2019, 09:28 PM | #5 |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
I really like the clean design of your cage. Look forward to seeing th bumper. Thanks for sharing, iit’s cool!
02-09-2019, 10:59 PM | #6 |
Newbie Join Date: Feb 2019 Location: Anderson
*wipes drool off lip* yep that a purty rig rig there. Looking forward to seeing this progress... Sent from my iPhone using Tapatalk |
02-09-2019, 11:38 PM | #7 |
Your garage it too clean, where does all this work happens? Nice brazing/soldering. is it sand blasted afterward, or what secrets do you use, have for flux removal?
02-13-2019, 04:24 PM | #8 | ||||
| Re: Just a Power Wagon for some Fun! Quote:
I don't sand blast, just use a wire wheel in my pillar drill and sometimes sand paper to clean on the joints. I think the trick is to have super clean, tight joints to start with, and then use the minimum amount of flux possible. The more flux you use, the more cleaning up you'll have to do | ||||
02-17-2019, 12:37 PM | #9 |
Newbie Join Date: Jan 2019 Location: DEER PARK
Oh man I think I’m getting the itch for another build!
02-17-2019, 12:37 PM | #10 |
I love the cage work
02-17-2019, 12:54 PM | #11 |
Looking very nice indeed and I like the whole premise of the build. Agree with the others on the cage work as well - stellar!
02-18-2019, 04:46 PM | #12 | |
| Re: Just a Power Wagon for some Fun! Thanks. I always look at other builds, and think "I must do one of those"! Thanks very much Quote:
I've spent the last few evenings getting the chassis finished. I installed the GCM Scale Transmission, driveshafts and SSD axle weights. I also stripped and rebuilt the Proline shocks. I discovered that I needed to modify the lower bar on the cage hoop as at full compression it just fouled the driveshaft. Now, I know that it'll probably never compress both shocks together, but I just like things to be right, so I chopped it up a little. I'd decided that the front part of the cab would be mounted with velcro, which was easy enough to do. However, the rear part was causing me a little more of a headache. I didn't want long posts to the roof as that would probably end up fouling the interior. So, after much deliberation I can up with this. It works great, is easy to put the body in place and keeps the body tight. The green fuel tubing is just for the mock up. I'll replace it with black on the final assembly. And lastly, I've made a start on the front bumper. I think I'm going to go for a simple looking stinger with a fairlead just in case I decide to add a servo winch at some point in the future. Next up will be the final part of the front bumper, once I've decided what it'll be. Thanks for looking. | |
02-18-2019, 06:29 PM | #13 |
Everything you do is so clean! And your brazing or welding skills are top notch!
04-10-2019, 07:50 PM | #14 |
Newbie Join Date: Aug 2018 Location: Portland
I love this so much. I am working on something similar currently. The cage I got from a guy on fb but I'm not super happy with it, so I bought a bender and am going to try to solder my own. Your work is very inspirational.
04-10-2019, 08:55 PM | #15 |
Quarry Creeper Join Date: Apr 2016 Location: Canada, Ottawa/Gatineau
Nice tube work, very clean. |
05-23-2019, 05:12 PM | #16 | ||
Thanks very much. | ||
05-23-2019, 05:16 PM | #17 |
I've had a complete change of heart with this build. After driving my TRX4 and being so impressed with how capable it is, I decided to move the Power Wagon on to a TRX4. For now, the Ford F-100 body is awaiting another TRX4, and with the UK G6 looming I'm using the chassis from the Ford. The premise of the original Power Wagon build was to be as capable as possible, while still being a great trail truck. As I was under a tight time schedule for the G6, and this was a quick build, the pics move along fairly fast. First job was to cut some more off the chassis rails to further improve the departure angle. Trim the body and work out the look I wanted. Rear chassis trimmed, and shock brace added. I wanted to avoid using body clips, but the rear was awkward to mount. So, I used some clips, then hid them in a tool box. I'm not a big fan of heavily weathered trucks, but I wanted this to look like the Cab had been used, but that a new hood and rear bed had been fitted. So I did a small amount of weathering on the cab only (my first attempt, so go easy...) Playing with some ideas for the naked space on the rear bed. Don't think the cooler suits this truck.though. I hate wires showing through the wheel wells so I made some inner fenders using some RC4WD lexan fenders for the 4Runner. Quite a lot of trimming needed, but managed to get them to look quite good. And here it is, all ready for the G6 this weekend. I made some hidden sliders using some 8mm Delrin rod. I didn't want big sliders sticking out, so I'm hoping these will protect the bottom of the body as well as sliding well on the rocks. And lastly, I added a few rock lights. That's all for now. Unfortunately time ran out on me before I could build an interior, so that will be after the G6 now. I'm also going to braze up a more appropriate from bumper (so this can go back on the Ford), as well as adding a servo winch. A quick test this evening was reassuring. This truck is very capable. More pics to come from the G6. Thanks for looking, as usual. |
05-23-2019, 06:44 PM | #18 |
Pebble Pounder Join Date: Aug 2005 Location: Gilbert
Another great build by you!
05-24-2019, 05:12 AM | #19 |
Badass.
05-24-2019, 06:35 AM | #20 |
It looks great as always! Do you think the front shock tower brace is necessary? I know the TRX-4 shock towers are quite beefy as far as plastic goes. |
Just a Power Wagon for some Fun! - Similar Threads | ||||
From this , to that ! Power Wagon ! | Frank211 | 1.9 Scale Rigs | 20 | 05-19-2019 01:10 PM |
Project B.A. Power Wagon (Bad A** Power Wagon) | freetimecrawler | 1.9 Scale Rigs | 1 | 12-30-2018 07:19 AM |
1964 Dodge Power Wagon Town Wagon | bodean | 1.9 Scale Rigs | 32 | 05-29-2015 11:02 AM |
Project 2.2: Diesel Power-Wagon beater fun truck | Desert Rc | 2.2 Scale Rigs | 33 | 07-30-2014 06:52 PM |
60 in a 73 power wagon | losikid | Chit Chat | 13 | 10-10-2011 08:27 PM |
