Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vanquish Products VS4-10 Origin
Thread: Crazy Builds a VS4-10 Black.
Old 03-22-2019, 03:05 PM   #1
Default Crazy Builds a VS4-10 Black.
So it begins.
First things first RTFM!!!
CRAZYACE63 is offline   Reply With Quote
Old 03-22-2019, 03:25 PM   #2
Go Buckeyes!
B-MOW71's Avatar
Default Re: Crazy Builds a VS4-10 Black.
Congrats! Prepare yourself for a fun build.
B-MOW71 is offline   Reply With Quote
Old 03-22-2019, 04:03 PM   #3
Everyone getting these at the great sale price? I'm so tempted to get one but I almost don't want to stray from the TRX4 for fear of change.
But one of these with a Holmes Revolver or something would be absolutely money.
jessedacri is offline   Reply With Quote
Old 03-22-2019, 06:36 PM   #4
I am going to use my TRX-4 for a good running rig and use this as the get to the trail rig. It will be the one pulling a trailer with the TRX on it. I’m gonna baby this thing like no ones business.
Old 03-22-2019, 06:37 PM   #5
Anyone had a problem with the rear axle outer cap not fitting? Mine is having a little trouble sliding on. The left side slipped on and screwed down nicely. This one won’t even get to the screw holes.
Old 03-22-2019, 06:51 PM   #6
Thanks man. I am right at the third page and it hit a snag. But I will contact VP and see what they say.
Old 03-23-2019, 01:41 PM   #7
Mine was pretty tight. It's was a pain to get on but everything lined up nicely once it was positioned properly
crawlnyc is offline   Reply With Quote
Old 03-24-2019, 12:57 AM   #8
Well took two days to get the axles finished. Main reason was I didn’t have the correct wrench to tighten the diff cover bolts. Other reason was one of the rear axle end caps just didn’t want to fit. A little persuasion and it lines up.
Old 03-24-2019, 02:59 AM   #9
Update #2
Got a little ahead of myself and was in the zone so I missed a few internal pics of the trans. Plus I needed to figure out the updated brace while following the manual. This is the step I’m on now. Suspension tomorrow.
Still haven’t decided on motor and ESC. So I will update when I make up my mind.
Thanks for checking her out and if anyone has tips or tricks on the build I can do or I can go back and do let me know.
I really love building kits like this. I may like building them more than driving.
Old 03-24-2019, 09:55 PM   #10
Tip dont hit anything or wreck it at all if you run it into a foam pit you will bend the frame rails so becareful heres before with stock rails and after with the new rails
Sent from my SM-G975U using Tapatalk
anrjch is offline   Reply With Quote
Old 03-24-2019, 11:48 PM   #11
Dang man that was a solid hit. At least it’s back up and running true.
Old 03-24-2019, 11:53 PM   #12
Update #3
Got the suspension installed and am working on the side rails and then to the wheels.
I started on one wheel and they are not the easiest to install the tires on. Just can’t keep the beads in the grooves. May have to predrill all the holes so they are easier to start.
Might just get a new set of rims and tires. Or use the same ones I have on the TRX-4.
Old 03-25-2019, 06:11 AM   #13
Go Buckeyes!
B-MOW71's Avatar
Build is looking good so far.
Here is a quick tip for the top shock mounts. I installed a small o-ring to take up the space beside the shock cap mount so that the shock would not move side to side. Here is a pic. If you look close, you can see the o-ring.
Old 03-25-2019, 08:08 AM   #14
Thats just it i never hit hard it was a first run on it and turned it over on a slight hill nothing i havent done several times with a scx10 or a rc4wd
Old 03-25-2019, 02:15 PM   #15
Cool thanks for that. I’ll double check mine and get an o-ring if needed.
Old 03-25-2019, 02:23 PM   #16
Moderator
JatoTheRipper's Avatar
Congrats on picking up this sweet truck! Good start to your build.
Old 03-25-2019, 04:13 PM   #17
Thanks. It’s been an adventure. So gonna pick up new wheels and tires. These just aren’t doing it for me.
Started test fitting the accessories and they add so much to the body it’s great. Now to find some Rigid Q series lights for the front.
Crazy Builds a VS4-10 Black. - Similar Threads
VS4 for the 1.9 noob mikemcE Vanquish Products VS4-10 Origin 137 04-09-2020 10:01 PM
Tekin Builds - VS4-10 Origin Black Ty@Tekin Vanquish Products VS4-10 Origin 21 06-20-2019 11:24 AM
looking for prerunner builds. post builds here wcdfmt510 General Scale Talk 19 06-27-2013 09:48 PM
crazy video and pictures of a slash vs airbag crazy josh hayes Non Crawler RC's 8 07-01-2009 02:56 PM
