Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: How would cover the gap between the cab and bed
Old 04-15-2019, 11:41 PM   #1
kgb424's Avatar
Default How would cover the gap between the cab and bed
I have a GCN 4 Ten chassis with a Tamiya Toyota cab and when I was looking thru my RC stash for parts, my broken 3D Printed ABS Plastic Trailer fell off a shelve and broke the trailer tongue off and I then decided too use it as a bed for the GCN, I made it so the bed is sitting between the rear shock mounts, and then centered the so the wheels are covered by the fender evenly and when you do that it creates a huge gap between the cab and bed, and would like ideas how to make the gap less noticeable ??, I was thinking a fuel cell, or maybe length the bed, but never have worked with printed ABS, so not sure, anybody have other ideas how to hide it or make it less noticeable, I 'm open to suggestions
kgb424 is offline   Reply With Quote
Old 04-16-2019, 12:23 AM   #2
Default Re: How would cover the gap between the cab and bed
You could put little roll cage in-between an put few scale bits in gap!!
Sent from my ONEPLUS A6003 using Tapatalk
robbark34 is offline   Reply With Quote
Old 04-16-2019, 12:43 AM   #3
Build a headache rack to fill the gap
Rickleo is offline   Reply With Quote
Old 04-16-2019, 05:03 AM   #4
Shorten the wheelbase.
Brake Weight is offline   Reply With Quote
Old 04-16-2019, 05:57 AM   #5
Stretch the box, not too terribly difficult with sheet styrene.
mikemcE is offline   Reply With Quote
Old 04-17-2019, 03:08 AM   #6
kgb424's Avatar
I like this much better, I bought this 6th scale trailer, it's a Marx from 1979 and if I flip it backwards and add a little space between the cab and the bed the rear wheels are centered in the rear fenders, I have to make spacers too level the bed and thinking about using some thin aluminum plate and use Velcro to mount the bed instead of screwing the bed to the chassis, I don't like the look of what is now the tailgate cause the end of the trailer is tapered and just doesn't look right, I have a RC4WD TF2 spare tire mount and I could cut the tailgate out and mount the spare tire so it sticks out pass the end of the bed, still figuring it out cause I have too cut the bed for the rear shock mounts and that effects the spacing of the tire mount and how I mount the bed too the chassis
Old 04-17-2019, 03:26 AM   #7
Do not intervene technically, the model looks right. If you visually do not like the empty space, you can visually remove it with paint or additional parts. If you plan to change the frame will spend a lot of time and not the fact that the technical part will be in decent condition.
Liam659 is offline   Reply With Quote
Old 04-17-2019, 07:49 AM   #8
valheru's Avatar
A back rack (with a recovery winch if it fits) or shorten the box a bit and fit a DIY styrene cross-over stowage cabinet.
https://www.emisales.net/winch.html
https://www.buyersproducts.com/produ...set-floor-3184
Cargo Tool Boxes | Truck, Semi, Trailer, Diamond Plate, Aluminum
D
valheru is offline   Reply With Quote
How would cover the gap between the cab and bed - Similar Threads
Bed cover help rag6 Paint and Body 0 09-08-2016 07:23 PM
Vinyl Bed Cover :D sixshooterstang 1.9 Scale Rigs 0 10-13-2012 08:40 PM
A cover for the battery in back? plate that will cover the rear bed? davidq19 Axial Wraith 7 01-28-2012 11:24 PM
RC Jeep 1/2 doors and bed cover ford381stroker General Crawlers 1 02-19-2006 06:55 AM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
