05-13-2018, 01:03 PM | #1 |
I wanna be Dave Join Date: Feb 2009 Location: Detroit
| Cheap ford f150 trail truck
This build will be my simple trail rig/ waiting for parts to finish other rigs project. Just passing time with this build. Dont expect to much progress on this one. K2 reign rails Lnc trans with forward motor plate Bomber rtr km2 tires reduced to 1.9 Tamiya blackfoot body. On to some pictures. Last edited by CM9000; 05-15-2018 at 05:49 PM. |
05-13-2018, 03:00 PM | #2 |
| Re: Cheap ford f150 trail truck
Cut the trans plate. Drilled some holes. Countersunk the trans mount holes. Threw on some 55mm spacers. Plan on making a new motor plate. Or might just cut a spare up. Im going to put the highest turn motor possible with the smallest pinion possible. Might help the gearing out lol. As im working with what i already have. Total cash in the build so far... $15. And thats for the rails. Everything else has been acquired either through trade or for free. Last edited by CM9000; 05-15-2018 at 05:50 PM. |
05-18-2018, 10:48 AM | #3 |
6 suspension brackets and some tlt link mounts later.. These highlift axles are done! 3 link with panhard front and rear. Also picked up a axial 55t brushed motor. So now i have to cut up a spare lnc trans motor plate to keep the fwd motor mount. Sent from my LGMP260 using Tapatalk |
05-18-2018, 10:58 AM | #4 |
RCC Addict Join Date: Jan 2012 Location: Vancouver
Sweet another Blackfoot bodied rig. It seems to be making a surge again. Ill be watching.
05-18-2018, 12:27 PM | #5 | |
| Re: Cheap ford f150 trail truck Quote:
This build is going quicker than i thought. All that is left is links, chassis servo mount, and i have to pick a battery and esc. Sent from my LGMP260 using Tapatalk | |
05-19-2018, 11:25 AM | #6 |
Spare motor mount cut, drilled, countersunk, and fitted up. I think i have room to add a gru and lower the motor without hitting the front driveshaft at full compression. Last edited by CM9000; 05-19-2018 at 01:06 PM. |
05-19-2018, 12:52 PM | #7 |
| Re: Cheap ford f150 trail truck for a 'throw back' build !
05-19-2018, 12:54 PM | #8 |
Rock Crawler Join Date: Dec 2012 Location: Utah
If you find the trans to be geared too high for ring and pinion axles, Ive seen it paired with a hammer tcase and it worked great with good reduction and alot less motor heat. Good looking ford body |
05-19-2018, 01:10 PM | #9 | |
thanks for the thumbs up guys. and this ford body was suprizingly never ran. it collected dust in my buddies closet. he gifted it to me for rebuilding his Subaru motor. if I had a Tamiya highlift trans.. that might have found its way in this build. but for now im going to stick with what I got. this is gonna be a sweet backpacker. | |
05-26-2018, 11:21 AM | #10 |
Decided to go narrower on the chassis. This should help with link geometry. But not with space for electronics haha. Going to sketch up a servo mount with room for a servo winch! And going to also sketch up a battery plate and maybe a esc plate. I think im getting into this build a little more than i should. Cant keep it simple i guess lol. Sent from my LGMP260 using Tapatalk |
05-26-2018, 11:58 AM | #11 |
RCC Addict Join Date: Feb 2016 Location: Princeton, North Carolina, USA
| Re: Cheap ford f150 trail truck |
05-26-2018, 07:49 PM | #12 |
I know the feeling. Lol Chassis is looking good tho and still watching. |
05-26-2018, 08:41 PM | #13 | |
ive got these dromida 2s batteries for my xl I never fly. I think they are 2200 mah? so I could mount them on the outside of the chassis rails because they are so slim. I could easily bend up some aluminum to guard them on the trail. | |
05-27-2018, 07:59 AM | #14 |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
Looks nice and clean, small trucks and smaller tires FTW! |
05-27-2018, 10:03 AM | #15 |
05-27-2018, 11:23 AM | #16 |
I wanna be Dave Join Date: Dec 2016 Location: san diego
| Re: Cheap ford f150 trail truck Datsun?? Oh I cant wait to see that!!! And for the servos did you do them side by side longitudally? That's how mine fit on my ascender with room to spare on both sides. Stuck my rx up there too. |
05-27-2018, 12:43 PM | #17 | |
05-28-2018, 02:40 PM | #18 |
3 links front and rear done. Found cracks in my axle housings... And the esc and motor plate. Trying to keep the rails as rigid as possible. Last edited by CM9000; 05-28-2018 at 02:51 PM. |
06-07-2018, 04:42 PM | #19 |
hmm.. no pictures... anyways, ive had no luck getting new housings on here or getting an order through the hobby shop. im going to have to wait for some to show up through various orders through various online crawler shops and ebay stores.. till then. |
06-07-2018, 05:11 PM | #20 |
You upload from tapatalk?
Cheap ford f150 trail truck - Similar Threads | ||||
79 Ford Custom F150 truck goes trailing under some trees | straightshooterjeeps | Scale Videos! | 0 | 11-24-2016 06:33 PM |
Tamiya TA01/TA02 79 F150 Trail Truck | Xporter | Non Crawler RC's | 6 | 02-03-2016 06:36 PM |
79 Ford Flatbed Dually Pulling/Trail Truck | thisdougsforu | Axial SCX-10 | 6 | 01-13-2013 06:24 PM |
New to micro and built a Ford F150 Trail Trekker | AKbash57 | Micro Scale Rigs | 4 | 05-12-2012 11:49 PM |
cheap trail truck | cammok5 | Chit Chat | 7 | 10-01-2007 06:51 AM |
