05-03-2019, 06:24 PM | #1 |
Newbie Join Date: Apr 2019 Location: Puyallup
| Vaterra suburban issue
Alright ascender gurus. Im having a problem with my sons vaterra suburban. Everything is all stock and runs great. Im running a 2s 5200mah battery in it and it runs good until the battery gets to about 7v or lower. After it gets that low after we fire it up it and run it full speed it will go for a few seconds normal speed then it will stop. Steering is still responsive but no throttle til tou release the trigger and go again. After that it will only go about 3/4 speed. I swapped his motor and esc out for the one that came in vaterra k10 which never had this issue and still the same result. Ive also installed a castle bec no change. Im starting to think its the transmitter or reciever. Thought id throw this on here to see if anyone else has had this problem. Any help is appreciated.
05-03-2019, 08:40 PM | #2 |
| Re: Vaterra suburban issue
Ok so 7v is considered low. Im new to the rc world and just assumed that i should be good til about half the battery. Thank you for your help
05-03-2019, 09:31 PM | #3 |
Rock Crawler Join Date: Jan 2019 Location: Calgary
That's definitely low voltage cutoff. Pull trigger, voltage sags, lvc is triggered. Voltage stabilizes, pull trigger, sags again, lvc triggered again. I remember first time I used lipos, had the same reaction as you, feels fugged up. |
05-03-2019, 09:38 PM | #4 |
Alright makes me feel better knowing its not messed up. Guess ill just have to keep them fully charged .
05-04-2019, 06:07 AM | #5 |
Pick up a small checker/ balancer. You can check your cells easily in the rig using the balance port. https://www.google.com/shopping/prod...:1,prmr:1,cs:1 Hang up and Drive |
05-09-2019, 07:50 PM | #6 |
Quarry Creeper Join Date: Sep 2015 Location: Bakersfield
| Re: Vaterra suburban issue Don't keep them charged. Only charge them when you plan on using them. Lipo's don't like to be charged or low. They are stable around 3.8v/cell. Charge them, use them, then use the storage charge function, on your charger.
Vaterra suburban issue - Similar Threads | ||||
Vaterra 72 suburban | Kennyray | Newbie General | 4 | 02-23-2019 10:33 PM |
IN STOCK the NEW Vaterra RC 1972 Chevy Suburban Ascender RTR! | RPP Hobby | RPP Hobby | 0 | 11-16-2018 03:04 PM |
OPEN for PRE-Order Now the NEW Vaterra RC 1972 Chevy Suburban Ascender RTR! | RPP Hobby | RPP Hobby | 0 | 09-27-2018 01:51 PM |
Some issue with my Vaterra K5 kit | eddieaim | Vaterra Ascender | 3 | 01-16-2018 10:59 AM |
