06-15-2019, 10:19 PM | #1 |
RCC Addict Join Date: Aug 2013 Location: Calgary - in the Great White North
| VW Bus
Don't know what's going under this body yet but it's going to be a panel van and not a Kombi with windows. Gotta love having access to a laser cutter. Made cutting the styrene a breeze. |
06-15-2019, 10:40 PM | #2 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
| Re: VW Bus
Wow that is awesome man! I'm going to be following along with this. Fish Sent from my SM-N960U using Tapatalk |
06-15-2019, 11:12 PM | #3 |
| Re: VW Bus
Sheeeeiiiiiit. Love me a 21 window van. In for the build regardless. |
06-15-2019, 11:24 PM | #4 |
Rock Crawler Join Date: Apr 2014 Location: Portland
| Re: VW Bus
Looking good. Nice VW matching wheels too. I have a RC Hardbody about that size.. Lil Narrow tho. |
06-16-2019, 06:44 AM | #5 |
Pebble Pounder Join Date: Sep 2018
| Re: VW Bus
Nice shell dude!! You thinking crawler or road chassis?? Sent from my ONEPLUS A6003 using Tapatalk |
06-16-2019, 07:33 AM | #6 |
Rock Stacker Join Date: Mar 2015 Location: N.Wales.
| Re: VW Bus
Definately watching this one, and expectining results as your others. By the way which body is thar?
06-16-2019, 07:41 AM | #7 |
| Re: VW Bus
I think it’s a Maisto 1/10.
06-16-2019, 07:46 AM | #8 |
| Re: VW Bus
@Tossedman What is the wheelbase and width of this body? Just curious as to how narrow and if it could possibly be used as a street chassis body. Found this when googling.... |
06-16-2019, 08:21 AM | #9 | ||||||
| Re: VW Bus Quote:
Ding ding! You are correct. Come up and collect your prize! Quote:
I’m thinking it might end up on an MST CMX chassis. Something like this. First thing though is to finish filling in those windows. Cheers eh, Todd Last edited by Tossedman; 06-16-2019 at 08:29 AM. | ||||||
06-16-2019, 08:33 AM | #10 |
| Re: VW Bus
This one's also going to have a 3D printed engine. And probably sound too.
06-16-2019, 09:46 AM | #11 |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
| Re: VW Bus
I am right in for seeing this build progress. Your builds are always inspiring and I have wanted to build a VW bus for some time |
06-16-2019, 10:48 AM | #12 |
| Re: VW Bus Last edited by Tossedman; 06-16-2019 at 12:05 PM. |
06-16-2019, 10:51 PM | #13 |
| Re: VW Bus
Here’s a real one. Now waiting for glue and primer to dry. Filling in windows. Sanding coming up. |
07-24-2020, 06:37 PM | #14 |
| Re: VW Bus
Well, I'm on my usual timeline for a project, it's been over a year since I've updated this van project. I'm making a panel van out of the window van. I started by filling in the windows and the using a sheet of 0.10" styrene to cover them. I then tried to putty it all up and make it flat. After messing with Bondo and other putties I just couldn't get it flat. I spent the last 3 weeks screwing around sanding and filling and sanding and filling and sanding and then two evenings ago said this sucks and ripped it all off. I've replaced the 0.10" styrene with 0.40" sheet and it seems to stay flat. Now I just have to blend it in at the ends. I'm much happier. I'm using some Proflex Flexible Finishing Putty, made for automotive use. So far so good. Here I've put on too much. Sanding again. Time for another coat of primer and then more sanding. And with primer all flaws are revealed. Need a bit of glue and a bit more sanding. Stay tuned, more to come, in between building CrawlerBug II, my teardrop trailer, rebuilding a Slash and getting out crawling and bashing. Last edited by Tossedman; 07-24-2020 at 10:21 PM. |
07-24-2020, 07:02 PM | #15 |
| Re: VW Bus
Oh, boy. If it’s just a fraction as cool as the Bug it’ll still be great.
07-25-2020, 09:24 AM | #16 |
Quarry Creeper Join Date: Apr 2013 Location: San Diego
| Re: VW Bus
As cool as this looks like it will become, I can't stop thinking it would be even better looking as a mudder truck with the trans dropped and lifted.
07-25-2020, 07:01 PM | #17 | ||
| Re: VW Bus Quote:
Here's the chassis it'll sit on, an MST CMX with a 242mm wheelbase. The smallest wheels I have are these 1.55" wagon wheels with RC4WD Mickey Thompson MTZ tires Now to figure out the ride height and a way to mount the body. Do I need to make the wheel openings bigger? Fender flares perhaps? | ||
07-25-2020, 07:29 PM | #18 |
| Re: VW Bus
Front wheel wells will be hard to pull off and keep the door seam. Maybe add flares but then the rear wheel well won’t be as accurate. Flares could pull off bigger tires though. Maybe a rounded one in the front and some of those Jeep ones in the back.
08-04-2020, 10:00 AM | #19 | |
| Re: VW Bus Quote:
Or, you could do like the rear door seam like on a jeep xj where the wheel well attaches to door and is two pieces for door to open. By cutting front wheel well a little higher, you could raise rear well higher and still look scale. Just a couple of more options.. Looking great though! | |
07-30-2021, 04:49 PM | #20 |
| Re: VW Bus
Well, it's been a while since I've done anything on this project. I've redone the panels and windows three times to get them right(ish). Used thicker styrene and didn't take any pictures during the process. Sorry about that. It was just more of the same though. Picked out some colours for the project. Now to figure out wheels and such and how to mount this chassis. Also need to look at windows. Nice thing is that they're all flat. Question. Do I hinge out the front windshields? Easier to break and harder to make. Also need to figure out a simple interior. Maybe a 3D printed dashboard? Anyone seen an STL for one of those? |
VW Bus - Similar Threads | ||||
Vw bus | kalifkid | Non Crawler RC's | 1 | 10-12-2014 02:20 AM |
Bus Driver? | BJoe | Chit Chat | 8 | 03-08-2014 01:29 PM |
GMC bus | skl1cent | Non Crawler RC's | 16 | 04-12-2011 02:10 AM |
