Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: Samil 20 4x4 utility Truck
Old 06-24-2019, 01:41 PM   #1
Default Samil 20 4x4 utility Truck
The Samil 20 is a legendary military truck in South Africa. These things puts a smile on my face every time I see one.
With it being such a simple cab design I decided to attempt building one. I will use recycled abs sheet in 2mm and 0.9mm thickness. Scaled to about 1/8.3 to allow for tucked tires on ar44 axles. This will be a slow build, hopefully to be completed December...
Still deciding on a gearbox. Will design the chassis around whatever I end up getting.
The Samil 20 in all its glory:
Started chopping some abs already:
Scale print on a D90:
Parts Update December 2020:
Axles - HG P802.
Transfer case - Generic 2:1.
Gearbox - Generic 5:1.
Beadlocks - GRC Military.
Tires - Generic Military 116mm.
Servo - JX PDI-HV5523MG straight off 2s.
Motor - surpass branded generic 3slot 20t 550.
ESC - 1060 I had lying around.
Chassis:
Main rails was 50x25 alu tube with 2mm wall. I cut it down to get 25x8 c channel.
Braces and gearbox mount is normal old 21x21 u channel. All other bits was stock lying around.
HugoBiermann is offline   Reply With Quote
Old 06-24-2019, 02:57 PM   #2
Default Re: Samil 20 4x4 utility Truck
Subbed.
Brake Weight is online now   Reply With Quote
Old 06-24-2019, 11:56 PM   #3
Awesome truck, drove many a Samil in the bush.
Eager to see how this progresses!!
JMass SA is offline   Reply With Quote
Old 06-25-2019, 04:24 AM   #4
This is going to be excellent! Cant wait!
coffeeaddict17 is offline   Reply With Quote
Old 06-30-2019, 10:28 AM   #5
Got some more of the cab done today:
Doors and wind shield next.
Old 07-08-2019, 03:22 PM   #6
Another small bit done.
Old 07-14-2019, 07:33 AM   #7
Old 07-14-2019, 08:47 AM   #8
Gold Star Baby!
Topher Builds's Avatar
Looking very good! Nice fab work.
Topher Builds is offline   Reply With Quote
Old 07-14-2019, 10:13 AM   #9
Thanks!
Got a bit further
Tools thats building this
Old 07-17-2019, 05:16 AM   #10
Awesome work so far
Oh How Original is offline   Reply With Quote
Old 07-27-2019, 03:39 AM   #11
Got a 1:5 planetary on order. Triton transfer case should be here next week.
Going with basic military style 1.9 tires and will run these glue ons till I find something nice thats a beadlock:
Old 08-02-2019, 11:01 AM   #12
Should get some more abs work done over the weekend. Seats are a bit if a challenge for me, but should have two done.
Correction about the transfer case, it the hammer t case. Leaf springs are also en route. Getting closer to having the parts to be able to finish the chassis cad.
Old 08-02-2019, 02:38 PM   #13
Zukiiholic's Avatar
cab is looking good.
Nice work..
Zukiiholic is offline   Reply With Quote
Old 08-05-2019, 02:00 PM   #14
Got some of the interior done
Those seats pushed my abilities over the edge.
Old 08-13-2019, 01:37 PM   #15
Got a bit further with the abs.
The transfer case also rocked up. Gave it some proper grease and thread lock.
Old 08-15-2019, 12:17 PM   #16
Got the leafs today. Now trying to figure out the mounting. Will also be using 75mm internal spring shocks.
Its my first leaf build. They are a lot bigger than I expected.
Here is what I came up with so far:
Any better ideas?
Old 08-15-2019, 02:09 PM   #17
Moderator
JatoTheRipper's Avatar
That looks great. Nice modeling.
The transfer case hangs low and that will hinder performance if you are worried about that.
You are mounting your leaf springs on the outside of the chassis which will work, but the mounts look like they'll be prone to bending. You could do it like the Sawback does it which is how most RC leaf spring rigs do it. The shackles straddle the frame.
Oh and the Sawback leaf spring shackle and mount kit is sold separately here: https://www.rpphobby.com/product_p/gma52304.htm
More photos here: Gmade 1/10 GS01 SAWBACK - JunFac
Old 08-16-2019, 05:03 AM   #18
Thanks Jato. The only reason its on the outside at the moment is because of the stupid long shackles. Think I might just make some smaller ones.
These are 25mm eye to eye. Will shoot for 12mm.
Old 08-16-2019, 07:39 AM   #19
Had a go at the cad again. Will DIY me some shackles and a u-bolt mount.
Old 09-08-2019, 03:19 PM   #20
Just need to put some mounts on the body still, then start priming and sanding.
Color will be Rustoleum Cammo Sand.
Samil 20 4x4 utility Truck - Similar Threads
TRX-4 6x6 Military Utility Truck robysoldtamiya Traxxas TRX-4 14 09-11-2019 01:06 AM
A TF2 Jeep truck/utility/comp rig jigger..... delux 1.9 Scale Rigs 33 02-15-2015 07:29 AM
Torque RC "Practichaul" Trailer/Truck Utility Tool Box (TRC30) tycoonman Scale parts 0 07-16-2014 01:34 AM
