![]() | #41 | |
Quarry Creeper Join Date: Jul 2006 Location: Northglenn
| ![]() Quote:
![]() Just put your mind to it and with your talent you can make it happen. ![]() | |
![]() | #42 |
I had the hottest girlfriend at the MSD Nats Join Date: Dec 2006 Location: Hecho en Tejas
ahh so thats how you did it huh? i looked and looked at that to figure it out. sounds good so ill give it a try, and that toolbox is really clean looking, is that diamond plate tape or just painted diamond plate?
![]() | #43 |
The Diamond plate is styrene... and I just learned that instead of paint if you use house hold Aluminum Foil and clear it. It will look much more scale looking, however it is really fragile until you clear it.
![]() | #44 |
Pebble Pounder Join Date: Dec 2006 Location: wood lands of no were to important
howde you biuld the storage box?
![]() | #45 |
I joined the Band! Join Date: Mar 2007 Location: Santa Rosa
That is PERFECT... Beautiful.. I love it, you have the bodylines every thing is exact.. Im hopin for when I get mine to do an '80's Suburban.
![]() | #46 | |
| ![]() Quote:
The basic shape was like the roof on a house and tapers down. | |
![]() | #47 |
thanks, and uh whats styrene?
![]() | #48 |
plastic.
![]() | #49 |
i got a big question, i have finally saved enough for an R2 and i need to know which is a good pinion to run for a trail rig with wheel speed the priority here. i was looking at the dimensions and my frame rails are exactly as wide as the R2! go figger!! i didnt even plan it out like that just like the body ride height. it just fits. so... what pinion do i need? i got a 55t integy with it.
![]() | #50 |
Ultimate RC Decals Join Date: Aug 2005 Location: San Antonio
great build but i think you should mount the rear shocks just like the real trucks. one in opposite direction from the other..
![]() | #51 | |
| ![]() Quote:
![]() | #52 |
i see, it will be a six cell stick so maybe a 12t?
![]() | #53 |
I wanna be Dave Join Date: Jun 2006 Location: Ukiah
Nice work! I wish I had the time to do that type of body work. I barely have time to paint nowadays. I can appriciate the tim eyou have into that. ![]() |
![]() | #54 |
RCC Addict Join Date: Jul 2006 Location: Johnston SC
![]() | #55 | |
Quarry Creeper Join Date: May 2006 Location: SLC
| ![]() Quote:
I have an R2 tranny in my comp 2.2 buggy. I put the 8 tooth pinion on it when i got it with my 55 turn motor, and it was very slow. Had no wheel speed to hop up over anything when needed. So I changed to a 15 tooth pinion and I really like this setup, it still has plenty of tourque, and it also has plenty of wheel speed for me now. So I would suggest that you start with at least a 15 tooth pinion on the R2 and see how that works! | |
![]() | #56 |
cool will do, i got one on the way! hoping it will be here by the middle of next week, i gotta make a few trips to the LHS as well so youll see some updates after my fullsize rig is ready to go.
![]() | #57 |
I joined the Band! Join Date: Mar 2007 Location: Cardboard Box behind Wal-Mart
What size square tubing did you use for the frame? How did you cut it so straight?
![]() | #58 |
yup 1/2 inch. i used a bender to bend it first then i used a bandsaw right down the middle.
![]() | #59 |
damn I did good then because I left and got the same thing for my 'burb and portaband or just bandsaw? If you don't mind can I copy your frame design? If so do you have to scale pics or like measurments I can use? One more thing can you make resin casts?
![]() | #60 |
well i just eyeballed it really. its too long for a burb but uhhh resin wouldnt be as good as steel IMO. have at it, i copied the fram design from chevrolet so i guess its not a problem! lol if it cuts like a hacksaw youre in good shape. heres a link on chassis specs you could use. its pretty handy, i didnt use it but its very close to what mine is like. http://chuckschevytruckpages.com/framespecs.html |
