12-18-2019, 06:20 AM | #1 |
Newbie Join Date: Nov 2018 Location: joppatowne
| hard body
how do you install a tf2 body on a vs410 chassis
12-18-2019, 06:38 AM | #2 |
Rock Crawler Join Date: Jan 2019 Location: Calgary
| Re: hard body
Your best bet is to search the forums and read some builds mate. That's a tough question to answer any other way.
12-18-2019, 06:41 AM | #3 |
I wanna be Dave Join Date: Aug 2008 Location: cape crud... will you be my friend
| Re: hard body
Pins, screws, velcro, strips of wood, styrene elastic bands, pixy dust.... Yes yes there's a million ways. |
12-18-2019, 08:24 AM | #4 |
| Re: hard body
Rare earth magnets are a clean, effective way.
12-19-2019, 10:46 AM | #5 |
Newbie Join Date: Dec 2019 Location: USA
| Re: hard body I've just done exactly that using these: https://www.ebay.com/itm/Body-Shell-...wAAOSw3YJZWFO~ Because the VS4-10 chassis uses the same skid-plate/trans mount location holes as an SCX10, you can use any Trailfinder body mounting brackets for an SCX10. The ones in the link above have a series of mounting holes so you move the cab fore-aft / up & down to centre your wheel-arches over the front axle as desired - although if you're running 4.19s or bigger, you'll probably still have to trim some of the arch (or mount the body really high) as the VS4-10 has a lot of travel. You'll also need to forfeit the VS4-10 sliders and/or stock battery tray unless you want to get creative with a Dremel. Hope that helps... |
01-09-2020, 06:52 AM | #6 |
Newbie Join Date: Dec 2019 Location: Overthere
| Re: hard body
Nice find.
