Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: Topher builds a TGH/G-Speed V3
Old 06-16-2020, 05:34 PM   #41
Tiny Truck Hoarder
HumboldtEF's Avatar
Default Re: Topher builds a TGH/G-Speed V3
Originally Posted by Topher Builds View Post
Didn’t DLux buy Dravtech to keep the shock line alive?
That I dont know, It would be nice.
HumboldtEF is offline   Reply With Quote
Old 06-16-2020, 05:58 PM   #42
Eric made lathed big bores before he carried dravtechs. I have a set on my Bullyll. Dravtechs are pretty, springs are finicky by weight,(limited between dravtech and mini t’s they work fantastic on lighter rigs though.
Dravtechs on my 2 I’m right on the edge spring wise, would like a bit more though
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 06-16-2020, 06:15 PM   #43
What is considered light? I’ve heard nothing but good things about the dravtechs, just curious.
Lou
TK421 is offline   Reply With Quote
Old 06-16-2020, 07:12 PM   #44
Lou
I would say eight pounds is all you can use with mini t springs. mY SCX10ii is a bit heavier now with dig,
Hang up and Drive
Old 06-16-2020, 07:18 PM   #45
Hang up and Drive
Noted. I’m hoping to keep my 10.2 based GSPEED below 6...
Lou
Old 06-16-2020, 07:30 PM   #46
Lou
That’s a sweet spot for tuning....
Hang up and Drive
Old 06-16-2020, 07:49 PM   #47
Good to know :-) thanks,
Topher, I hope I’m not hijacking your thread. I’ve been looking at a performance based “comp style” rig for a bit. Your build threads are the most informative I’ve read. I appreciate you taking the time to answer all my questions.
Lou
Old 06-16-2020, 08:27 PM   #48
Gold Star Baby!
Topher Builds's Avatar
No problem at all, I appreciate the interest.
Topher Builds is offline   Reply With Quote
Old 06-17-2020, 10:16 AM   #49
I'd say both are good options but If you want Dravtechs grab them soon because they're closing down but there's still stock out there.
The Dravtech shocks aren't going anywhere. Dlux took over production and distribution of the shocks back in late 2018 and has been in charge of them ever since.
Dlux fab is closing?!
Lou
Dlux fab is not closing
VMGontheRocks is offline   Reply With Quote
Old 07-07-2020, 08:02 AM   #50
If you have a minute, can you give me an eye to eye length of your front links? I think mine are too long. I'm using the V3 chassis, AR44's and the aluminum pan hard mount. My track bar is hitting the upper link mount of the axle and my shock doesn't clear the pan hard mount to get full compression. Thanks!
Lou
Old 07-07-2020, 09:21 AM   #51
Gold Star Baby!
Where’d ya get your links from? Can you post some pics?
I’ll get a measurement for you at some point today.
Old 07-07-2020, 09:28 AM   #52
I ordered the links from Intheworksrc. I can post pics when I get home from work this afternoon.
Lou
Old 07-07-2020, 09:30 AM   #53
These are from last night. I have since moved the PH mount forward one hole and it lines up better but I can only use one screw to attach to the chassis. I was looking at your pics this morning ans saw that the front axle sits way further back than mine. I'll measure my WB and get some better pics after work. Thanks for your time bro.
Lou
Old 07-07-2020, 09:48 AM   #54
Gold Star Baby!
Are your links set up like this?
Longest to shortest
Rear lower
Rear upper
Front lower
Front upper
I’ve had similar issues with his links before, and the replacement links I got didn’t help either but when I got a different set they worked perfect. My fronts were too long also.
Old 07-07-2020, 10:03 AM   #55
I think that's where I'm at but I'll verify when I get home. Thanks!
Lou
Old 07-07-2020, 11:20 AM   #56
Gold Star Baby!
Hope this pic helps. Rough measurement puts the front lower around 120mm. Maybe a tad more.
Old 07-07-2020, 04:06 PM   #57
Should also point out that the panhard mount topher is running is the TGH panhard and the panhard you are running is the aluminum from the v3 carbon combo ( I also have this combo currently taped to the cardboard it was shipped in haha), which is exactly why I have yet to order links from either hardcore RC or intheworksRC because I have yet to hear if either/neither/both will work with the gspeed aluminum panhard mount and I dont want to buy a nice link set and have to jimmy rig the panhard.
DukeMinnix is offline   Reply With Quote
Old 07-07-2020, 04:58 PM   #58
Gold Star Baby!
Yes Duke is correct. I’m running the tgh mount. I don’t think it would solve his problem though because the tgh mount is in the same relative location on the chassis, it just allows for a longer panhard bar. Which translates to less axle swing. Lou’s problem looks to be too long of front links which wouldn’t allow him to connect the panhard properly. The multi platform panhard might work a little better?
On hardcore RC, the “wertymade” option is the on the that comes with the kit, and the same as the aluminum one gspeed just put out if that’s what you’re referring to.
Old 07-07-2020, 05:39 PM   #59
That’s good to know. I also wasn’t sure if your tgh Mount was more low profile to allow for more shock clearance also, which he indicated as being an issue
Old 07-07-2020, 07:43 PM   #60
I just measured all my links. I ordered the SS/ aluminum hybrid link set. The lower links are Stainless and those measure 135mm and 124mm. The three aluminum links all measure 120.5mm. I’m gonna try the 120’s up front and see how that shakes out... I’m not to confident that they will line up though...
Lou
Topher builds a TGH/G-Speed V3 - Similar Threads
topher builds a TRX10.2 Topher Builds Traxxas TRX-4 60 01-05-2021 07:59 PM
Topher Builds a SCX10.3 Topher Builds Axial SCX10 III 81 06-11-2020 02:23 PM
topher builds a Capra Topher Builds Axial Capra 100 03-16-2020 08:03 AM
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
