Dual motor direct drive Trx4/Trx6 I had a idea for a while for a dual direct drive trx4 or trx6 so far I was able to connect the driveshafts to the motor so next I would have to find a L shaped motor mount I've also thought of some benefits of this Since if you go dual esc you can make a overdrive or underdrive profiles without the gears One downside to it that there is no transmission or pinion so I might have to use a gear reduction to get more torque One advantage is there is less braking parts Another advantage is that the truck is lighter so maybe more trx4 comp crawlers? The last advantage I can think of is more torque compared to one motor Also the reason why there is tape over the motor is because its brushed and I wanted to make sure I don't destroy it in mud or water.https://uploads.tapatalk-cdn.com/202...8fa8578e96.jpg Sent from my SM-G986U using Tapatalk |
