12-26-2020, 05:53 PM | #21 |
| Re: G-Speed Rigs Only
Thanks Topher, this place (Crater Nation) goes in for miles and miles. We haven’t even scratched it!😈 The line in the video, (Jetro’s Crack, B Line) is one of the lines we discovered a just a few weeks ago and so far the two rigs in the video are the only two to have conquered it. Lots of fun! 😆 |
01-21-2021, 11:23 PM | #22 |
Newbie Join Date: Jun 2007 Location: las vegas
C3, TKO XR wides, 2.2 narrowed XOR's. TZ motor mount & t-case. |
01-22-2021, 05:19 PM | #23 |
| Re: G-Speed Rigs Only |
02-07-2021, 02:05 AM | #24 |
Newbie Join Date: Nov 2009 Location: spain
my G-Speed from spain: -Proline power wagon custom body -Tgh-hh motor mount -Traxxas 2660 shocks and mini-t springs -Custom 3d printed low profile servo mount -Samix titanium links -Sdi Propeller Shafts -Ar44 axles whit overdrive -Hh revolver v2 subnose 1800kv -Mamba micro x crawler -Mob 45kg servo -Custom 3d printed batery holder -650mah 3s tatto lipo |
02-19-2021, 02:31 PM | #25 |
What wheel base do you guys use?
02-19-2021, 06:56 PM | #26 |
Quarry Creeper Join Date: May 2019 Location: Knoxville
Though I haven't measured, mine should be right at 12.3. I run a MST JP1 body that fits quite well.
02-25-2021, 12:26 AM | #27 |
Pebble Pounder Join Date: Dec 2020 Location: Seattle
What length shocks are you guys typically running with this chassis?
02-25-2021, 08:23 AM | #28 |
I used some Element Enduro 90mm shocks, now using Traxxas GTS shocks that I think are 90mm. Depending on your build, you could use something from an 80mm to around 100mm.
02-26-2021, 01:29 PM | #29 | |
| Re: G-Speed Rigs Only Quote:
I just got a capra to scavenge axles from and a few other parts as well. It came with element enduro shocks (bronze body) and if they work I will use them on this build. I do have a TRX and could use those shocks as well. @Lashlee, just curious as to why you switched from one shock to the other? Do you like the traxxas ones better? I will be posting pictures in the near future as I am still gathering some parts for the build, that being said I will probably have some more questions for you all in the near future! Thanks! | |
02-26-2021, 03:07 PM | #30 |
Honestly, it's a long story but I had the GTS shocks on the Capra and in the process of buying parts, I had nearly enough parts to build a Capra axle based Sherpa and an Enduro based G-Speed. I later found a set of AR45p axles so I decided to swap to the GTS shocks and build the Enduro back as a hard body trail truck. If I buy another set of shocks it will be the Enduro bronze ones.
03-01-2021, 10:58 AM | #31 |
Rock Crawler Join Date: Mar 2008 Location: Plainfield
Here is the latest revision of my CF V3 build... Lou |
03-05-2021, 09:07 AM | #32 |
Newbie Join Date: Mar 2020 Location: Chandler AZ
G speed v3
03-05-2021, 11:28 PM | #33 |
RCC Addict Join Date: Mar 2019 Location: Hemet
Good looking rig desertplumber, I’ve got family in chandler, next time I go I guess I’ll be bringing my rig lol! Sent from my iPhone using Tapatalk |
03-06-2021, 06:16 AM | #34 |
Than you very much! Anytime your around message me and I’ll text with you. Lots of stuff around here to go do. Sent from my iPhone using Tapatalk[/QUOTE] |
03-10-2021, 06:42 PM | #35 |
Class 1 I’m working on
03-10-2021, 08:54 PM | #36 |
Great looking rig!
03-15-2021, 10:15 PM | #37 |
03-23-2021, 11:11 AM | #38 |
SORRCA Committee Member Join Date: Dec 2008 Location: Parkston, SD
| Re: G-Speed Rigs Only I'll play.....AR44 based Gspeed V3 carbon. Specifications: -V3 Carbon chassis -GLD servo mount -R2j Kustoms Delrin skid -R2j Kustoms Delrin lower links -R2j Kustoms Delrin chassis spacers -TGH FMM motor mount -TGH Creeper T -Traxxas big bore shocks -Axial WBHD drive shafts -SSD Diamond Pro44 front axle -Axial AR44 rear axle -SSD D hole wheels -Proline BFG Krawlers -Crawler Innovations comp cut Lil Novas foams -Salinas printed flat bed -Proline Power Wagon -HPI Mini Trophy interior -Locked Up RC scale hubs and wheel hardware -Brood Riot SS 2100kv revolver -Castle Micro X esc -Reefs 777 servo -Spectrum radio gear |
04-01-2021, 01:11 AM | #39 |
Newbie Join Date: Jan 2017 Location: Santa Barbara
G-SPEED V3 VFD transmission AR45 axles |
04-01-2021, 05:54 AM | #40 |
Bruh, that VFD set up is slick AF. Good job! Lou |
G-Speed Rigs Only - Similar Threads | ||||
TF2 Transmission: R3 2-speed vs R3 single-speed vs R4 single-speed | Panther6834 | RC4WD Trail Finder 2 | 9 | 11-05-2019 12:40 PM |
tf2 with 2 speed transmission and 2 speed transfer case | Teasley4Crawlers | RC4WD Trail Finder 2 | 9 | 12-02-2014 10:34 AM |
F350 3 speed to single speed conversion, tips/ideas needed please | neo | 1.9 Scale Rigs | 10 | 02-11-2010 02:49 PM |
single speed setup vs. speed control | traxxas junky | Electronics | 18 | 08-28-2007 11:28 PM |
