09-02-2021, 06:59 PM | #161 | |
RCC Addict Join Date: Mar 2011 Location: easton
| Re: G-Speed Rigs Only Quote:
I’m planning on using a builders kit 2 for my v3 build as well. I was debating on 10.3 portals but the element route just seems a lot better to do specially after seeing the one topher did Sent from my iPhone using Tapatalk | |
09-12-2021, 04:51 PM | #162 |
Newbie Join Date: Apr 2021 Location: Frederick
Howdy everyone, been lurking on the forum for a little while now and thought I'd post up my current build after watching this thread and the awesome builds you all have done. I've never done a comp rig so I thought why not do a C2 just for fun and try the comp side. mine goes like this: V3 carbon element package (others were sold out at the time) Hardcore titanium HC links G-LD servo mount TGH FMM with 15% t-case TGH t-case adapter SSD pro44 rear stock ar44 front with aluminum link mounts (alum or brass c hubs and knucks if needed for weight) Boom racing HD topshaft Gspeed AR44 panhard mount things to get: dravtechs (have traxxas BB's on a 10.2 custom wanted to try something different) HH revolver or puller pro stubby (see how I like the noise) Mamba micro X body will most likely be the tamiya 350 body.. though I've always liked the clod... Hardbodies appeal a lot more to me than lexan and im willing to sacrifice some performance for points super shafty drive shafts. debating between HH servo or ShiftRC. servo winch Cookee |
09-12-2021, 05:07 PM | #163 | |
RCC Addict Join Date: Nov 2017 Location: 3rd rock pile on the right
U got a good start there. Im buildin a c1 using the f350 body. Love my v3 rig though. Cant wait to see more of this one come together Sent from my SM-A516V using Tapatalk | |
09-15-2021, 04:30 PM | #164 |
Pebble Pounder Join Date: Dec 2008 Location: Close
G-speed's kickin' ass... |
09-15-2021, 06:10 PM | #165 |
Pebble Pounder Join Date: Jun 2014 Location: Central Texas
| Re: G-Speed Rigs Only |
09-27-2021, 10:00 AM | #166 | |
Looking forward to seeing more! You should consider making a build thread for this build! | |
09-28-2021, 09:25 AM | #167 |
Another project that I have been slowly working on for the past few months. A GSpeed V3-C3. I stole the axles out of my Axial Capra and decided to use the TGH 2.Low E.B.R Edition trans that I picked up earlier in the year. No build thread started yet, but may sit down and throw one together when I get time. Hoping to jump back on this build soon to get it finished up. Also need to get back on my V1-C1 (B-MOW's GSPEED V1-C1 Mojave Class 1 Build) build since @indybama re-lit the fire to get it done! |
09-30-2021, 12:39 PM | #168 |
Pebble Pounder Join Date: Aug 2018 Location: US
I finished my first G-speed build the other day. Ended up going with some AR45Ps that came up for sale instead of the Element axles I originally started the build with. I can't wait to get it out and see how it performs! |
10-01-2021, 06:30 AM | #169 |
10-02-2021, 05:06 PM | #170 |
Went to Cheaha State Park this mornin. Had a good trail run n then disaster hit lol. A buddy asked 'how fast will it go?' So i was gettin a vid for him n tryin to watch the truck on the phone. Hit a rock head on at full throttle. Thankfully the only thing damaged was the front driveshaft. But i think that was more from the full throttle at a dead stop than the hit, due to the center section being twisted. Time for incision driveshafts... I added a few scenic pics too. To bad i cant add vid too Sent from my SM-A516V using Tapatalk |
10-03-2021, 09:18 AM | #171 |
10-06-2021, 12:11 AM | #172 |
Newbie Join Date: Sep 2018 Location: UK / South Wales
Guys what's the advantage of using Element Stealth X trans over stock SCX10 II trans? Only reason I can think of is having overdrive but this can also be achieved with SCX10 trans by changing gears in the axle? Seen couple of rigs with Element Stealth X trans here but none with SCX10. |
10-06-2021, 01:56 PM | #173 |
Newbie Join Date: Mar 2010 Location: Germany
Hi, i need more Information about @Thedesertplumber an the clod buster from Thread #32 The look of The clod is very nice. I need more Photos from this comp. Can everybody help me ?? Thanks |
10-06-2021, 08:43 PM | #174 |
Newbie Join Date: Nov 2017 Location: Az
[QUOTE=ciechan;6094891]Guys what's the advantage of using Element Stealth X trans over stock SCX10 II trans? Only reason I can think of is having overdrive but this can also be achieved with SCX10 trans by changing gears in the axle? Seen couple of rigs with Element Stealth X trans here but none with SCX10.[/QUOTE One possibility is more overdrive with ft ring/ pinion od + stealth od. I run the 2low trans. and keep the stock r/p. |
10-10-2021, 01:59 PM | #175 |
Made it to cheaha again this weekend. Had a few mishaps but they were easy fixes. Got the front driveshaft in a bind a couple times n it popped apart. Headed back to the truck to leave n the panhard came loose from the axle. I seen the screw was out a bit, but it wouldnt turn, so i ran it lol. On the 2nd batt in the v3 n it backed out itself n got into the tire. Thankfully no damage to anything. Love goin up to cheaha! Pulpit rock is a better spot than Bald rock imo... Found bigfoots liquor rock too lol Sent from my SM-A516V using Tapatalk |
10-10-2021, 02:05 PM | #176 |
These here are goin back to the truck to leave. Thats a steep hill u have to go down goin in n up goin out Sent from my SM-A516V using Tapatalk |
10-10-2021, 04:28 PM | #177 |
Rock Crawler Join Date: Dec 2012 Location: Utah
Awesome scenery |
10-10-2021, 04:59 PM | #178 |
10-11-2021, 08:31 AM | #179 |
10-11-2021, 02:30 PM | #180 |
| Re: G-Speed Rigs Only Its a fun spot for sur OSRC. Its a bit steep, but the challenge is worth it. Wish i could run into some others that trail there. Ive seen chaulk lines from gates over at bald rock, n ive only seen 2 people with crawlers there 1x
G-Speed Rigs Only - Similar Threads | ||||
TF2 Transmission: R3 2-speed vs R3 single-speed vs R4 single-speed | Panther6834 | RC4WD Trail Finder 2 | 9 | 11-05-2019 12:40 PM |
tf2 with 2 speed transmission and 2 speed transfer case | Teasley4Crawlers | RC4WD Trail Finder 2 | 9 | 12-02-2014 10:34 AM |
F350 3 speed to single speed conversion, tips/ideas needed please | neo | 1.9 Scale Rigs | 10 | 02-11-2010 02:49 PM |
single speed setup vs. speed control | traxxas junky | Electronics | 18 | 08-28-2007 11:28 PM |
