10-30-2020, 05:14 PM | #21 |
I wanna be Dave Join Date: Feb 2009 Location: Cowtown, USA
| Re: VP VS4-10 Origin by JUSTINART24
A few pics from a outing to the bridge spot in Marysville, WA on 6/13/2020. |
10-30-2020, 05:15 PM | #22 |
A few pics from Boxcar Park in Everett, WA on 7/7/2020. |
10-30-2020, 05:15 PM | #23 |
A few pics from a trip to Edgewater Beach Park in Mukliteo, WA on 8/6/2020. |
10-30-2020, 05:15 PM | #24 |
A few pics from a trip to Cap Sante Park on 8/22/2020. |
10-30-2020, 05:16 PM | #25 |
Here is a video of the installation of the 21% transmission overdrive gears. Website Link: https://www.vanquishproducts.com/vfd...case-gear-set/ |
10-30-2020, 06:00 PM | #26 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
real nice build and and some great shots in here. Thanks for sharing.
10-31-2020, 06:15 AM | #27 |
Great looking Origin! Cool to see another OG VS4-10 build thread! It brings back great memories when I was building mine a couple years back. Your scale garage looks awesome! Mr. Miyagi applying wax is a nice touch! I’ve been subscribed to your YT channel for awhile now and enjoy watching your videos. Thanks for sharing and look forward to seeing more! Sent from my iPad using Tapatalk |
10-31-2020, 03:54 PM | #28 | ||
| Re: VP VS4-10 Origin by JUSTINART24 Quote:
Thanks! I am getting back to forums, been using FB and IG and it's are to track your build. I missed having one single thread to go back on to for references stuff when I rebuild. Quote:
10-31-2020, 03:55 PM | #29 |
I am going through the axles a bit and put in a front Hot Racing overdrive gear set. I also spend some time inspecting the axles for wear or issues and all seems well. I use this truck a lot for monthly WARCRC SORRCA Scale Comps and etc, and glad to see no issues yet. Hot Racing OD Gear Set: https://hot-racing.com/?partnumber=SCXT9278;c=1020 View more details about the fron VS4-10 Currie axle here: https://www.vanquishproducts.com/cur...lear-anodized/ You can now buy just the VS4-10 VDI universals, view them here: https://www.vanquishproducts.com/inc...di-universals/ I mainly use the VP grease, works well I think, view that here: https://www.vanquishproducts.com/rc-...ase-rock-lube/ You got to have some fun jack stands, view them here: https://store.rc4wd.com/Chubby-Mini-...ds_p_2792.html Threaded VP axle inserts: https://www.vanquishproducts.com/cur...d-axle-insert/ VP Kingpin screws: https://www.vanquishproducts.com/inc...lder-screws-4/ For knuckles, I am using the VP SCX10.2 ones but in grey: https://www.vanquishproducts.com/axi...gray-anodized/ |
10-31-2020, 03:55 PM | #30 |
A few more pics after going through the front axle. |
10-31-2020, 05:56 PM | #31 |
Quarry Creeper Join Date: Jan 2008 Location: Hollister
Very nice build.
10-31-2020, 06:43 PM | #32 |
Rock Crawler Join Date: Apr 2020 Location: Northern MN
Fantastic build! Your rig is gorgeous and your trail/build pictures are incredible. The iPhone on the shop bench waiting to get something dropped on it (like pretty much every shop I’ve been in) and just the over all 1:1 replication is awesome. Everything is great! Excellent thread!!!!!! |
10-31-2020, 08:45 PM | #33 | |
| Re: VP VS4-10 Origin by JUSTINART24 Thanks! Quote:
10-31-2020, 08:45 PM | #34 |
I spend some time on the rear axle of the VS4-10, bearings looked good. It has pretty minimal scratches on the diff compared to how much driving this thing gets, taller 4.75" tires help I think. I finally had some time to install the new VP under drive gear in the rear. Now to do some testing to see if the transfer case OD gears, front axle OD gears an the rear UD gears are too much. Website Link: https://www.vanquishproducts.com/ar4...ar-set-33t-8t/ |
10-31-2020, 08:46 PM | #35 |
And a few pics of the rear axle back assembled, now to go through the shocks and mount the axles. |
11-01-2020, 10:00 PM | #36 |
Here is a little update on my Vanquish Products VS4-10 build, went through the shocks to check for issues and found an o-ring I might have not installed right, so I replaced it. Luckily I had a shock rebuild kit on hand (IRC00212). These are the 90mm version and I am pretty happy with them, pretty smooth. They also make a 80mm version I am pondering getting for some other tiny tire builds, not many other 80mm shocks out there to pick from. VP 90mm shocks: https://www.vanquishproducts.com/inc...-scale-shocks/ VP 80mm shocks: https://www.vanquishproducts.com/inc...-scale-shocks/ Shock rebuild kit: https://www.vanquishproducts.com/inc...k-rebuild-kit/ |
11-02-2020, 06:28 AM | #37 |
Rock Crawler Join Date: Mar 2008 Location: Plainfield
Killer thread, awesome pics bro! Lou |
11-02-2020, 10:37 AM | #38 |
| Re: VP VS4-10 Origin by JUSTINART24 |
11-02-2020, 10:38 AM | #39 |
Got some new tires for my Vanquish Products VS4-10, I went with the Proline 1.9 KM3's with the predator compound. The compound is pretty soft, excited to see out it does at the next WARCRC SORRCA Scale Comp. I am not sure I am going to run upgraded foams just yet, the truck is pretty like and I have been running much more stiffer foams then I wanted to before with my previous setup. I will see how it goes this weekend and order some foams if need bed. The details on these tires, along with other tires on the market now a days are just over the top, the amount of details they can get on the sidewall is pretty impressive. Now to get them mounted up and some testing in! ;) BFGoodrich Mud-Terrain T/A KM3 1.9" Rock Terrain Truck Tires https://www.prolineracing.com/tires/...ruck-tires.asp Last edited by justinart24; 11-02-2020 at 10:40 AM. |
11-03-2020, 01:09 AM | #40 |
Another update on my Vanquish Products VS4-10, mounted up the Proline KM3's on some 1.9 Method wheels. I used some LockedUpRC scale hardware and some acorn nuts that attach the SLW style hubs. 1.9 Stainless Brake Disc Weights https://www.vanquishproducts.com/1-9...-disc-weights/ Method 1.9 Race Wheel 105 Clear/Black Anodized https://www.vanquishproducts.com/met...lack-anodized/ 1.9 Original Beadlock Clear Anodized https://www.vanquishproducts.com/1-9...lear-anodized/ 1-64 x .25 Scale Hex Bolts (30) MC Zinc https://www.lockeduprc.com/1-64-x-25...nc-_p_387.html 4-40 x .25" Acorn Wheel Studs (2 - FLANGE https://www.lockeduprc.com/4-40-x-25...GE_p_1284.html Last edited by justinart24; 11-03-2020 at 01:14 AM. |
VP VS4-10 Origin by JUSTINART24 - Similar Threads | ||||
B-MOW's VS4-10 Origin Limited | B-MOW71 | Vanquish Products VS4-10 Origin | 40 | 09-15-2023 06:18 AM |
VS4-10 Origin Conversion to Pro | randallboone | Vanquish Products VS4-10 Origin | 2 | 03-07-2020 09:05 AM |
VS4-10 Origin kit | dna930 | Vanquish Products VS4-10 Origin | 11 | 01-14-2020 09:56 AM |
