Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: Ssd beadlocks and proline super swamped tsl
Old 11-05-2020, 08:16 PM   #1
Default Ssd beadlocks and proline super swamped tsl
Not sure what the heck I'm doing wrong. I can't get my beadlocks seated properly inside the tire. It seems like the inner ring won't allow it to work.
Sent from my SM-N975U using Tapatalk
talltee9 is offline   Reply With Quote
Old 11-05-2020, 10:35 PM   #2
Default Re: Ssd beadlocks and proline super swamped tsl
Well after a bit of a struggle I finally got them to fit. Was certainly not expecting the challenge it was. But after it got the first it was a breeze
Old 11-05-2020, 10:36 PM   #3
Good to hear you got them on
Update us after a few runs with the TSLs, I’m stil trying to find my perfect tire for my terrain.
ScaleLifeNewbie is offline   Reply With Quote
Old 11-05-2020, 10:38 PM   #4
Thanks! I definitely wasn't prepared for battle lol. But I love the tsl's I had a set on before hand. Thats why I went back with them.
Old 11-05-2020, 10:45 PM   #5
What’s your terrain like?
Old 11-06-2020, 06:22 AM   #6
twade984's Avatar
The last picture you posted looks like the front and rear wheel halves aren’t lined up properly. You have to keep rotating the front or rear until the 6 hub screw holes and all d-window holes line up. Also it is normal for it be a little difficult getting the screws started. You kind of need three hands to compress the wheels together and start a screw.
twade984 is offline   Reply With Quote
Old 11-06-2020, 07:10 AM   #7
Mostly dirt, mud. Not a whole lot of rocky areas in LA
Old 11-06-2020, 07:10 AM   #8
After much trial and error I got them on! Not having them lined up was definitely an issue
Old 11-06-2020, 10:34 AM   #9
octigonwallrus's Avatar
next time you mount tires on bead locks put the tires in the freezer overnight.
it stiffens them up and makes them way easier to mount. also on those squeeze type beadlocks like that use one long bolt then switch it out when you get the others started.
octigonwallrus is offline   Reply With Quote
Old 11-06-2020, 11:29 AM   #10
Ok next time I will for sure do that. And the longer bolts would have definitely helped. I have some more bolts coming today. A couple of them stripped out
Old 11-06-2020, 11:50 AM   #11
I ordered the brass inners with my SSD wheels and use the Proline SS tires. Went on pretty easy, you could always look into those especially if you want to add weight with out the brass look. Just an option even though you already got your tires mounted haha
xtreme4x2 is offline   Reply With Quote
Old 11-06-2020, 12:20 PM   #12
Proline ss? I'll have to check them out
Old 11-06-2020, 12:29 PM   #13
Ssd beadlocks and proline super swamped tsl - Similar Threads
Proline XL tires on SSD beadlocks Danger Close Tires and Wheels 3 04-17-2019 11:24 AM
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
