02-24-2021, 12:22 PM | #1 |
Rock Stacker Join Date: Mar 2020 Location: SPRINGFIELD
| 4 Wheel Steering
Hi guys, I have a question. How do I go about setting up 4 wheel steering? I've bought two complete front portal axles, extra steering link, rear mounted servo/bumper mount, and extra servo. I think that's all the parts that I need???? If not please let me know. What I'm having a problem with is figuring out how to make it all work. I assume there's either some sort of module I need or a certain way to wire all in to my receiver. Can someone give me a link to a thread that will explain it to me or just explain it please? Also I guess I can't figure out how to search for threads??? When I touch the magnifying glass and type in what I'm looking for (4 wheel steering) it says something about only aloud to make a search every 30 secs or something and I have to wait before I can make another search. I've tried looking for several different things but always get the same results Sent from my SM-G970U using Tapatalk |
02-24-2021, 01:28 PM | #2 |
| Re: 4 Wheel Steering
The search function has been screwed up forever now. I don’t use it because of that. In google type: site: Rccrawler........ search word. For 4ws you either need a 3 position switch on your radio, or Im pretty sure you can mix it to work with your 2nd channel. Otherwise you can buy a servo splitter/reverser. This will most likely require a BEC. |
02-24-2021, 02:43 PM | #3 |
| 4 Wheel Steering
First off you need the proper Tx/Rx combination. For example my Futaba mixes the steering on two channels and is controlled by the switch I set. This is a 4 channel radio. If you have a 3channel you can get an adapter that will allow your steering . Al here at RCC runs HeyOK and he has one. Bastiens also sold one, don’t know if it’s available still. https://www.freewebstore.org/heyok-p...2_8019645.aspx Hang up and Drive Last edited by mikemcE; 02-24-2021 at 02:46 PM. |
02-24-2021, 02:44 PM | #4 |
The setup will depend on what radio/receiver you use. I just setup a Spektrum radio with 4WS, front servo goes to the steering channel rear servo uses one of the aux channels. Then in the radio settings I selected 4WS and selected which aux channel is used for rear steering, created drive modes (FS, RS, 4WS and crab mode) then set their order. Theres a lot of little details for setup and all of that will depend on what radio you use. Check the manual for 4 wheel steering setup, if it supports this it should have a section for setup. HeyOk makes solution for 4WS https://www.freewebstore.org/heyok-p...2_8019645.aspx I think this is aimed at radios that may not have all the options required to fine tune 4WS. My Spektrum setup uses a 3 position switch but gets 4 or more functions out of it. |
02-24-2021, 09:43 PM | #5 |
You guys are awesome thank you so much!! I plan on ordering a dx5 rugged and after reading up on it it has a 4WS mode on it. Thank you for explaining to me how to hook it up and giving me a couple different options Sent from my SM-G970U using Tapatalk |
02-25-2021, 06:19 AM | #6 |
Rock Crawler Join Date: Apr 2020 Location: Drums
| Re: 4 Wheel Steering |
02-26-2021, 01:00 AM | #7 |
One thing that wasn't explained well with the Spektrum 4WS setup was the drive modes. This video helped me out: https://www.youtube.com/watch?v=T4DE...ature=youtu.be |
03-04-2021, 08:10 PM | #8 |
Rock Crawler Join Date: May 2012 Location: Minneapolis
Looks like you have a bunch of feedback on 4WS. If you can find one, the best radio out there is the airtronics MT4 or MT4s. they have a lever by the left thumb that is perfect. Sadly they stopped making them. The best way i've found to search for stuff on rccrawler is to type this into a google search. type your subject here site:www.rccrawler.com for example 4ws site:www.rccrawler.com |
03-04-2021, 09:01 PM | #9 | |
| Re: 4 Wheel Steering Quote:
Sent from my SM-G970U using Tapatalk | |
03-04-2021, 09:03 PM | #10 | |
4 Wheel Steering - Similar Threads | ||||
Four Wheel Steering | Ecranu | General Scale Talk | 1 | 01-02-2017 12:25 AM |
need 4 wheel steering help | creaturecrawler | Axial SCX-10 | 2 | 09-23-2012 05:14 PM |
4 Wheel Steering | dtmcnamara | HPI Wheely King | 16 | 08-27-2007 08:45 PM |
M8 steering wheel | BeadLock | Electronics | 3 | 09-12-2005 09:57 AM |
