Re: Bananaclip’s 4door Trail Rig Nice work travis! I need to get some styrene n stuff n give it a go myself. I see alot of members do fantastic work with it. Cant wait to see it progress further |
Re: Bananaclip’s 4door Trail Rig Quote:
Absolutely…. Styrene is super easy to work with. Sherwin Williams, had a gallon of real MEK not the MEK substitute. I would recommend sourcing the real stuff if it’s still available. No updates other than a possible suspension redesign…….. https://uploads.tapatalk-cdn.com/202...6015726f3e.jpg https://uploads.tapatalk-cdn.com/202...5b95bcf9cd.jpg Tossed on some 4.19’s and man I am digging the overall look. I am planning on running the original rear flare in a slightly different position than currently mounted. The front fenders will get some type of treatment. I can’t do the wide front flare. Sent from my iPhone using Tapatalk |
Re: Bananaclip’s 4door Trail Rig Alright. This is what I came up so far for fenders. I had an extra set of axial og flares. I couldn’t take the width of the provided front flares. So I ended up running rear flares front and rear. Mounted…https://uploads.tapatalk-cdn.com/202...46219ba6b4.jpg https://uploads.tapatalk-cdn.com/202...b8d5e14006.jpg Trimmed and shaped https://uploads.tapatalk-cdn.com/202...0f17daa66b.jpg Oh….. SSD C Hubs finally https://uploads.tapatalk-cdn.com/202...8e714ea940.jpg Sent from my iPhone using Tapatalk |
Re: Bananaclip’s 4door Trail Rig This is like watching a scaled-down version of Fab Rats YouTube channel - A very cool customized Jeep is being created! Killer fender work..."thumbsup" I have a set of discontinued RC4WD aluminum add-on fenders with an attached quarter panel that I have been searching for a body to install on - I, too have 2 pair of the same except I believe mine are fronts all 'round. I believe they were originally meant for the Axial Jeep Rubicon body, but I want to go a different route, and have a couple potential options - going to have to test them out and see which will be the eventual winner. https://cdn3.volusion.com/7z62e.xvk6...che=1597768542 |
Thank you my man. I went with the OG axial Jeep flares to cut weight overall. I was considering some smaller diameter rod with aluminum or thin steel inlay. I guess that’s still a possibility. I’m not 100% sold on the current set up. Yeah I have a set of fronts to durok. If you removed the complete panel and attached the aluminum fender recessed. https://uploads.tapatalk-cdn.com/202...43227336c8.jpg I ended up ordering some of the ultra short Drav’s to match my current 90mm versions on hand. https://uploads.tapatalk-cdn.com/202...029c860dda.jpg Ended up shaving a set of the rcfabtabs shock mounts to accommodate the shorter Drav’s and lack of room in the rear. https://uploads.tapatalk-cdn.com/202...13be62d12c.jpg Fronts are set up pretty well as is. I need to burn them in. https://uploads.tapatalk-cdn.com/202...361f3468e4.jpg The tire size has been determined. I’m going with the 4.75 Krawler. The larger tire just fits the long body IMO. I think a 4.50 tire would be perfect but I don’t have any on hand and I just dropped some coin on some more suitable wheels. I’m really starting to fall for this build now she is standing on its own. The stance is pretty nasty [emoji40] https://uploads.tapatalk-cdn.com/202...5e00a48c92.jpg https://uploads.tapatalk-cdn.com/202...828367831c.jpg https://uploads.tapatalk-cdn.com/202...30fb36ce8d.jpg Sent from my iPhone using Tapatalk |
Re: Bananaclip’s 4door Trail Rig Yes, it looks pretty awesome! I hate to be that guy, but I really wish a few select tires were offered in a 4.5-4.6” size. Km3’s, krawlers, mtr’s… Sent from my iPhone using Tapatalk |
I appreciate it twade and you are correct. There isn’t much out there in the 4.50 range. I couldn’t just leave it alone with new wheels for this build. I ended up pulling the trigger on a set of the KM2 BFG offered by rc4wd. This tire is 4.56 I believe and I used them on a recent 4Rnr build I did. I really liked how they worked on that build so……. Mail man delivered last evening. https://uploads.tapatalk-cdn.com/202...d9ff3884b3.jpg Couldn’t wait so I watched some football and went to work. https://uploads.tapatalk-cdn.com/202...b0df62df74.jpg I’m thinking this combo will help dial in that iconic trail Jeep look. Filled the tires with some Dual stage CI foam and vented the sticky rubber properly. Need to work on body mounts next. Sent from my iPhone using Tapatalk |
Re: Bananaclip’s 4door Trail Rig Wanted to show you guys the end stance of this thing. I still need to burn in the body mounts on the frame, figure electrical routing and paint. The Jeep is sitting just right imo and is nearing a test run. Pics. https://uploads.tapatalk-cdn.com/202...e4a678c19e.jpg https://uploads.tapatalk-cdn.com/202...030ed8f41c.jpg I unbolted the license plate bracket and all of its overhang. I found this hole right behind it that needs addressed. https://uploads.tapatalk-cdn.com/202...04b477e858.jpg And a little flex or lack their of. https://uploads.tapatalk-cdn.com/202...af27d9c693.jpg https://uploads.tapatalk-cdn.com/202...a7272284a4.jpg https://uploads.tapatalk-cdn.com/202...9a7887ecd4.jpg Lots of stuff with no rub. Sent from my iPhone using Tapatalk |
Re: Bananaclip’s 4door Trail Rig Very cool. I’ve seen a few of the trucks you’ve built, they all have a distinct style that I appreciate [emoji1360] Sent from my iPhone using Tapatalk |
Re: Bananaclip’s 4door Trail Rig Dang travis, the jeep is lookin good! I dont have much patience for body work lol. Guess im goina have to learn. Think ive got an idea for the C1 build... |
Re: Bananaclip’s 4door Trail Rig I'm liking how this Jeep is looking so far!"thumbsup" Great job on build! Tube and cage work looks excellent! Following along to see more! |
Twade I appreciate the kind words. I guess I do have a style now that you mention it. Most likely the tunnel vision I have with Offroad builds. Sent from my iPhone using Tapatalk |
Adam I’m starting a C1 hardbody build after I wrap this one up. I have the goodies I just can’t decide what body to go with. I love those yotas and Jeeps the same I guess. Keep us posted brother. Sent from my iPhone using Tapatalk |
Thank you kind sir. I haven’t spent much time on the build lately. I did manage to complete the body mounts. I still need to do a little clean up but they turned out. I placed them so they could be adjusted with spacers or washers to adjust the ride height. Body mounts. https://uploads.tapatalk-cdn.com/202...9332f91771.jpg https://uploads.tapatalk-cdn.com/202...8efab3981c.jpg https://uploads.tapatalk-cdn.com/202...8fbeea0e89.jpg They hold nicely https://uploads.tapatalk-cdn.com/202...ebc33a7777.jpg The build is coming along. I need to fill the license plate delete and go over the entire thing with a lighter grit paper. Then knock out some inner fenders. Paint is going to be tricky. It’s blue cold here in WV. I have a heated shop but I don’t like to spray with the doors shut. I will get that part figured out last. Sent from my iPhone using Tapatalk |
I bought a set for my ascender because 4.8s just look cartoonish on it. I thought because of the tread pattern I might give up a little performance for the sake of a more scale look. I gotta say that I have been thoroughly impressed with the performance of those tires on trails, and especially on the rocks. |
Re: Bananaclip’s 4door Trail Rig Damn nice work my friend! love the stance! "thumbsup" |
I’m happy to hear this. I ended up running a set of them with the same CI dual stage foam I put in this set. They hooked up great! I prefer the smoother tread pattern on the rocks all day. The knobby tread tires cause a natural bounce/ separation at the point of contact. The smoother tire just spins and bites. Sent from my iPhone using Tapatalk |
Thank you kind sir. I’m loving the stance to. Nothing hits and everything cycles butter smooth. Sent from my iPhone using Tapatalk |
Re: Bananaclip’s 4door Trail Rig I made a bit of reportable progress. I managed to get the interior and cage painted. The interior turned out well enough. It will require some cargo and detail work. The cage turned out the part. https://uploads.tapatalk-cdn.com/202...45696ffb5a.jpg https://uploads.tapatalk-cdn.com/202...9d536e25fa.jpg The body. Oh this thing has been rubbed on. I am very close to paint. The license plate bracket deleted well https://uploads.tapatalk-cdn.com/202...dc6740bfbc.jpg I have one little spot that needs a drop of liquid plastic. The rest of the jk is paint ready. https://uploads.tapatalk-cdn.com/202...5845f02e64.jpg https://uploads.tapatalk-cdn.com/202...06c2d500cc.jpg Next warm day it will have a different look. Sent from my iPhone using Tapatalk |
Re: Bananaclip’s 4door Trail Rig Dang travis, youve made some good progress brother. Interior looks great. Cant wait to see some color on the body |
