06-06-2022, 01:16 PM | #21 |
Newbie Join Date: Jan 2022 Location: SW Ontario
| Re: Jon's Baja Bug |
06-14-2022, 06:28 AM | #22 |
| Re: Jon's Baja Bug
So I've been out with the Spektrum Firma 2 in 1 - 2300 Kv motor a few times now, and I have to say I like it. Other than the speed increase (about 28%) I haven't noticed any difference in how it works compared to the Fusion 1800. I picked up an 11 tooth pinion gear to replace the stock 14 tooth, and the ratio between those is roughly 27%, so with that installed my Firma 2300 runs pretty much exactly the same as my old Fusion 1800. Sorry, I forgot to take a picture of the 11 tooth while it was apart. One of the other positives about the Firma is my local hobby store (where I bought it) will handle any warranty claims directly - apparently with Hobbywing you need to deal directly with them, the LHS can't get involved. I mounted the power switch for the Firma up high this time - 3D printed a new cover plate for my voltmeter (which sticks up in the back - you can see the battery voltage through the back window). Hopefully this will help keep the motor running longer. The voltmeter is a simple little voltage meter I got off Amazon, along with a 3D printed bracket/case for it. I connect it to the balance plug on the battery, and it gives me a nice real-time voltage level reading while I'm out on the trails. |
Jon's Baja Bug - Similar Threads | ||||
Jon's SCX24 Rock Buggy | JonHylands | Micro Scale Rigs | 26 | 03-30-2022 04:59 AM |
Baja Bug 2.2 | JCO245 | Axial SCX-10 | 5 | 07-14-2013 01:58 PM |
