11-25-2022, 12:04 AM | #21 |
Rock Crawler Join Date: Jan 2022 Location: st louis
| Re: RocHobby 1/10 'Mashigan' RTR - Wrangler YJ
The body set up is nice, hopefully the drive train quality is decent though their design guys obviously were a little too drunk when it came to setting up the steering and such up front. Sent from my SM-S906U using Tapatalk |
11-25-2022, 12:34 AM | #22 | |
Pebble Pounder Join Date: Dec 2020 Location: USA
| Re: RocHobby 1/10 'Mashigan' RTR - Wrangler YJ Quote:
broken the servo arm though; it looks to be made of brittle instead of flexible plastic like every other hobby grade (Futaba, etc) servo horn. Been waiting for a better-than-Tamiya Jeep for a long time and the 1/6 Jimny is a good substitute, just wasn't crazy about the Jimny and the scale. P.S. I think I stand corrected. This crawler is purportedly named after the designer off the YJ Jeep: Chuck Mashigan At least that seems more than 95% plausible. I guess it is their way of getting around the Jeep licensing and somehow paying homage to the designer. Nobody knows Chuck Mashigan though so this is a bit dubious. Should have just named it "Michigan" or "Adventurer". | |
11-25-2022, 02:21 AM | #23 |
Quarry Creeper Join Date: Jun 2015 Location: France
Before throwing a rock at the stock servo horn almost everyone will anyway be prone to change for aluminum before even getting the car ... winter is coming ... with its usual cohort of broken plastics ... Can't wait to get mine ... I haven't swapped the chassis between the Jimny and the Willys but might do with this one ... at least to give it a try. Last edited by tuxstang; 11-25-2022 at 03:11 AM. |
11-25-2022, 08:29 AM | #24 |
I wasn't even referring to the servo horn, that is what it is. The 4 link with chassis mounted servo. That was a very dumb overly drunk or hung over moment cause even FMS should have known better. Sent from my SM-S906U using Tapatalk |
11-25-2022, 10:30 AM | #25 |
It's still, with maybe a few minor evolutions, the same chassis and axles since the Willys ... which had a Panhard bar ... but as it looks like they plan selling a leaf spring upgrade kit, they used the Jimny engine layout that moved the servo on the wrong side ... making the Panhard mount on the axle unuseable ...
11-25-2022, 10:51 AM | #26 |
| Re: RocHobby 1/10 'Mashigan' RTR - Wrangler YJ Tamiya CC02 is the same design, it's flat terrible. From a company that overdesigns everything, it's a huge flaw imo.
11-25-2022, 12:20 PM | #27 |
I LIKE chassis mounted steering servos with all their quirks and bump-steer and other sub-optimal issues--it is "just like the real thing". By that I mean a real YJ has a steering box, tie rods, rack and pinion or whatever it is and it is independent of the axles. I'm ignorant in this area; Is an axle mounted servo really the only answer? I've seen people fix the bump steer though, with a better "drag link" or linkage. And yes, the original product description states an optional leaf spring kit and "turksandjerps" shows where they attach to the chassis. Now all the major high subscriber Youtube channels have their Mashigan and have submitted review videos right on cue. One guy has even done a full repaint and detail to replicate what looks like a Wrangler 'Sahara Edition'. |
11-25-2022, 03:07 PM | #28 | |
Now the video mentions putting the steering servo on the other side which is a US thing in 1:1, that person doesnt fully comprehend how suspension works either.. The servo can be on the side it's on now and the panhard bar is ran over from there to the other side. Want an example, jeep XJ better known as the older basic style jeep cherokee. It's 3 link with track bar (panhard bar) in the front and depending on how you look at it 3/4 link in the rear. It's 4 mounting points frame but 3 points on the axle. Fms should have done 3 link front to do it correctly instead of this mess they made which trashes performance. Sent from my SM-S906U using Tapatalk | |
11-25-2022, 09:22 PM | #29 |
Quarry Creeper Join Date: Sep 2018 Location: Denmark
I thought it looked really nice but not one to add to my collection... Waiting instead for them to make more US ww2 vehicles in 1/12 then they can just take my money
11-26-2022, 03:06 AM | #30 | |
Here's the underside of the Jimny ... the battery tray is on the way, you'll have hard times to get a proper Panhard bar geometry. On the Willys, it was a completely different layout that had all the room needed for the Panhard bar Envoyé de mon CPH2211 en utilisant Tapatalk | |
11-26-2022, 12:34 PM | #31 |
Fabulous, thanks for the photo comparison! It is difficult searching for photos of the real Jeep YJ and the Mashigan, plus the Jimny and others. You'd think they would be consistent with the linkage and suspension layout. In fact I was thinking the Jimny and Mashigan would have the exact same layout for ease of manufacture. |
11-26-2022, 01:21 PM | #32 |
I'm curious what will be in the optional leaf spring kit ... according to the manual and the Jimny, the rear inner brackets of the front leaf springs is integral to the servo/battery tray ... however, I haven't seen it on the existing videos ... on some, it even seems to have been cut from the factory ... while the front inner brackets are still there.
11-26-2022, 05:15 PM | #33 |
That's a cool little mashigan. Holy crap, just saw the 1/6 jumny is only $120 on Amazon.
11-26-2022, 09:46 PM | #34 |
| Re: RocHobby 1/10 'Mashigan' RTR - Wrangler YJ |
11-28-2022, 12:22 PM | #35 |
Some driver sizes Jimmy is 21cm/8in ... already a bit too tall for pure 1/10 and still way too small The driver (HM Armed Forces) from my Sawback is 26cm/10in ... a bit too tall No need to check with Sgt Elias from Platoon ... with his 30cm/12in, he can't fit right no matter how much you butcher him. 24-25cm should be spot-on ... With some trucks ... first 2 are 1/10, second is around 1/8, last is 1/6 |
11-28-2022, 08:50 PM | #36 | |
I watched a couple yt vids, and it appears that the Mashigan shares many parts with the 1/6 willys Last edited by Gula; 11-28-2022 at 08:53 PM. | |
12-04-2022, 09:20 AM | #37 |
RCC Addict Join Date: Sep 2010 Location: Apollo Pa
I got mine the other day, body is fantastic really really nice details! Sent from my SM-N981U using Tapatalk |
12-04-2022, 04:18 PM | #38 |
Can't even find them now, all gone since the price drop. Wish I had seen the insane price cut I would have grabbed one then. Sent from my SM-S906U using Tapatalk |
04-12-2023, 05:06 PM | #39 | |
04-12-2023, 05:22 PM | #40 |
RocHobby 1/10 'Mashigan' RTR - Wrangler YJ - Similar Threads | ||||
New EAAYRC Patrion 1/18 - RocHobby Katana "in cheap"? | donaldsneffe | Micro Scale Rigs | 28 | 06-09-2022 05:31 PM |
New RocHobby Porsche Type 87 1:12 - Kommandeurswagen, "Beetle" | donaldsneffe | General Scale Talk | 16 | 02-24-2022 01:56 AM |
1941 Jeep super scale in 1/6 RTR by RocHobby | donaldsneffe | General Scale Talk | 130 | 11-04-2021 09:12 AM |
12.3" Rubicon vs 12" Wrangler G6? What makes up the extra .3" | Savvy4.6X | Axial SCX-10 | 3 | 04-10-2015 10:51 AM |
"Must have" upgrades for SCX10 Jeep Wrangler Unlimited Rubicon RTR | Elsior | Axial SCX-10 | 55 | 04-04-2015 06:38 PM |
