Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: The 'Zuki
Old 11-29-2022, 06:25 PM   #1
Default The 'Zuki
I recently got a 3d printer and ive started working on a Suzuki Samurai for a backyard crawler to play around with. I found the files on thingiverse ( can't remember who made them) and I plan to run it on a 380 motor and will use 1865 cells for power. Prints aren't perfect but I was planning on having to fill and sand.
https://www.flickr.com/photos/193603...7720304076486/
Not sure how to get the pics to show here
Newderelict is offline   Reply With Quote
Old 11-29-2022, 07:21 PM   #2
Default Re: The 'Zuki
cool mang
go mang go
ferp420 is online now   Reply With Quote
Old 11-29-2022, 11:41 PM   #3
Zukiiholic's Avatar
Can't go wrong with a Zuki.
What scale is that going to come too?
Truer 1/10th?
Zukiiholic is offline   Reply With Quote
Old 12-01-2022, 06:26 PM   #4
Truer tenth. I haven't check the actual wheelbase yet but it's pretty short when compared to an scx10.
Old 12-01-2022, 07:10 PM   #5
Just measure the body, it's 5.5" wide with a 8.25 wheelbase.
Old 12-01-2022, 07:25 PM   #6
What chassis/axles do you plan on running? The Boom Racing BRX70s would be a good choice IMO.
ScaleLifeNewbie is offline   Reply With Quote
Old 12-03-2022, 04:46 PM   #7
The designer had made a chassis and scale axles to match the body. I had to split it into 4 parts to print it but it looks solid enough for some light crawling. Thinking of pairing it up with some portal axles I found off Ali express(wpl units I think).
I'll try to get a image posted of them tonight.
Old 12-03-2022, 05:03 PM   #8
Durability. Pla Pro, Tough Pla (just avoid black if you live where it gets hit during the summer). The joints, don't rely on glue. Use some to hold the body together then plastic weld them all together. A decent 3d pen or just some filament and a raw soldering iron tip or wood burner, weld on the inside making sure the melted filament penetrates the body pieces well.
Sent from my SM-S906U using Tapatalk
tigris99 is offline   Reply With Quote
Old 12-03-2022, 09:22 PM   #9
Just using a standard PLA from overture. Results have been consistent with it. I was thinking about taking the soldering iron to some of the joints, wasn't sure about fumes if any.
Got some photos of the chassis and the axles. Axles were a bit smaller than I remembered and will need to be adapted from 5mm to 12mm hexes.
https://www.flickr.com/photos/193603...posted-public/
The last pic is just showing the wpls compared to the 3d axles. I like the smaller size of the diffs on the wpls.
The 'Zuki - Similar Threads
ZUKI 1:6 scale sellenk Large Scale Rigs 71 02-23-2015 04:57 PM
Zuki topless sellenk Scale Videos! 4 07-10-2013 09:18 PM
Zuki Sammi kunas 1:1 Full Size Vehicles 4 04-11-2013 08:15 PM
My New(to me) Zuki Shaun Chit Chat 39 09-23-2010 10:14 AM
Stu-zuki microgoat 1.9 Scale Rigs 45 07-26-2010 02:00 PM
