VS4-10 Phoenix/AD GroundFox Build Happy new year, citizens! I started converting my Vanquish VS4-10 Phoenix into an Artful Dodgers Design GroundFox V2. First time ranking performance over scale appearance for a build, and I can't wait to get it done and go see what's up. Couldn't quite let go of scale appearance: Body choice right now is a Pro-Line Metric, I'm opting for a build that can be changed between Class 1 and Class 2 spec. There are no C1 comps around.. but I like smaller tires and will try to keep the portals as low as possible. Here we go: https://uploads.tapatalk-cdn.com/202...48bdece126.jpg https://uploads.tapatalk-cdn.com/202...454d6744d2.jpg https://uploads.tapatalk-cdn.com/202...4fd4a0912d.jpg I went CF! https://uploads.tapatalk-cdn.com/202...55c6957fdf.jpg The kit was missing one M3x20 set screw for the rear links, but I luckily found the only one available in town. https://uploads.tapatalk-cdn.com/202...5420aa6497.jpg https://uploads.tapatalk-cdn.com/202...e341e8a21f.jpg https://uploads.tapatalk-cdn.com/202...37d61e5c18.jpg Beautifully machined aluminum parts! https://uploads.tapatalk-cdn.com/202...5c4d30fd26.jpg https://uploads.tapatalk-cdn.com/202...ff17752097.jpg (panhard bar mounted wrong; should be behind the bracket) Had a really good time building! Contemplating different stuff now; wheels and tires, body setup mostly. And the hardest of them all: color choices! |
VS4-10 Phoenix/AD GroundFox Build https://uploads.tapatalk-cdn.com/202...e7855c1714.jpg I bought the Faif brass covers when this was a hardbodied Phoenix. Don't know if I'll actually gain any advantages from them here, but the body is a bit big compared to all the Powerwagons and Cliffhangers, so I'll try them out and see. https://uploads.tapatalk-cdn.com/202...15a3eb3b0b.jpg https://uploads.tapatalk-cdn.com/202...c89e84cabc.jpg Everything is in place, but not tightened down completely yet. https://uploads.tapatalk-cdn.com/202...d70f39fd42.jpg These 1.7 RC4WD wheels (don't worry about the thread, just testing) are great and honestly I love the tire size - but thinking I'll at least go to 4.19" to not waste the opportunity to crawl over more stuff. https://uploads.tapatalk-cdn.com/202...8851c0961f.jpg These 4.45 pitbulls are about as big as I'm willing to go with tires. Probably using the Phoenix cage https://uploads.tapatalk-cdn.com/202...8ded724aa1.jpg Looking like a damn Final Form Honcho in the making!Also considering 2.2 rims because it would let me run higher offset and tuck the portal covers inside the backspacing. ProBuilds would be the optimal choice. Working on it, thanks for looking! |
Re: VS4-10 Phoenix/AD GroundFox Build Thats lookin great man! The phoenix cage with the metric body works nicely together. Those brass portal cover will help keep the front end down, eventually im goina get the ones VP recently released. Kinda like those rc4wd wheels with the metric body, but those pro builds are a good choice too. Definantly goina watch this build come together. Keep up the good work dagg |
Re: VS4-10 Phoenix/AD GroundFox Build Should look pretty badass once you're done! |
Re: VS4-10 Phoenix/AD GroundFox Build Cool build! I've been wanting to get the GroundFox chassis kit. I do like the Rock Beast on the 2.2 ProBuilds. Looks great! Following along to see more! |
VS4-10 Phoenix/AD GroundFox Build Thanks you guys! I may have caused a little confusion with all these wheels.. hehe the 2.2 is a Gearhead wheel, and I stretched a class 1 Hyrax tire on it. I only have one of those rims. The Rock Beasts are sitting on 1.9 Vanquish Methods.. and the RC4WD Racelines are 1.7, with Baja Claws. I had to repair one of the shocks, and then did some bobbing: https://uploads.tapatalk-cdn.com/202...dad309963a.jpg https://uploads.tapatalk-cdn.com/202...576e534ef9.jpg https://uploads.tapatalk-cdn.com/202...41e410a39c.jpg |
Re: VS4-10 Phoenix/AD GroundFox Build Busy week, but got some tinkering done. Working on some slider tops, just black styrene. Also went and got some EVA foam, love that stuff for filling gaps under a body, might even make inner fenders. Luckily had a friend of mine, the great Tommy S; print some parts from Knight Customs for the body. Aiming at second gen Tacoma, 2011 style grille and light buckets.. sanding and puttying incoming. Meanwhile, color choices are impossible as usual. Have a good weekend, crawler peeps! https://uploads.tapatalk-cdn.com/202...4510388662.jpg https://uploads.tapatalk-cdn.com/202...53b141e47b.jpg https://uploads.tapatalk-cdn.com/202...7217bcf004.jpg https://uploads.tapatalk-cdn.com/202...f80a9453f4.jpg https://uploads.tapatalk-cdn.com/202...523a74c7ba.jpg https://uploads.tapatalk-cdn.com/202...f243a23cd5.jpg https://uploads.tapatalk-cdn.com/202...a591262278.jpg |
Re: VS4-10 Phoenix/AD GroundFox Build Slow progress here, but pretty hyped on the 3D printed parts so far. The body can hopefully sit pretty low on the chassis, had to find a way to lower the front bumper. Dodger cab mount serves as a brace and lowering mount for now https://uploads.tapatalk-cdn.com/202...ec26859693.jpg https://uploads.tapatalk-cdn.com/202...3a68561ac6.jpg |
Re: VS4-10 Phoenix/AD GroundFox Build "thumbsup" |
Re: VS4-10 Phoenix/AD GroundFox Build I’m happy with my groundfox. Although I built mine before they offered the carbon rails or a 4-10 kit. So I have ar45 straights and a stealthX in mine. |
Re: VS4-10 Phoenix/AD GroundFox Build I'd be interested in real-world performance of the Groundfox chassis with the Phoenix drivetrain. Is there a tangible benefit to the chassis? Comparison to the stock chassis? Thanks! |
Re: VS4-10 Phoenix/AD GroundFox Build Quote:
I will report back as soon as I've tested it! The design does drop the transmission and motor a bit lower. But: With my body choice I won't quite get the ultra LCG like the comp cab builds, and also I haven't ran the Phoenix with a lexan bod to compare.. it was a heavy JKU until recently. But I'll report something, that's for sure. https://uploads.tapatalk-cdn.com/202...53b53689ef.jpg |
VS4-10 Phoenix/AD GroundFox Build Update: slow cook on this one, but I've got some stuff done. First: got the body painted. Translucent red over Bright Gun Metal, backed with black. Candypaint for rock crawling?! Yes, mom. Made a floor/slider piece out of sheet styrene and a piece of a TRX-4 part. Then made some front inner fenders out of EVA foam. https://uploads.tapatalk-cdn.com/202...385bb584a6.jpg https://uploads.tapatalk-cdn.com/202...be3f61e404.jpg https://uploads.tapatalk-cdn.com/202...aa94264aa6.jpg https://uploads.tapatalk-cdn.com/202...d084b34c20.jpg https://uploads.tapatalk-cdn.com/202...6b721ce71e.jpg The grille is just sanded. Aluminum tape is still a hero in this hobby. https://uploads.tapatalk-cdn.com/202...6f8be10e6f.jpg Used Kyosho Micron tape for panel lines, it's really freakin good for that. Love these headlights! https://uploads.tapatalk-cdn.com/202...2db9d88bdf.jpg Like I'm gonna afford a 5th wheel... Peace! |
Re: VS4-10 Phoenix/AD GroundFox Build Nice progress! Color and details look great!"thumbsup" |
Re: VS4-10 Phoenix/AD GroundFox Build Looks like this is turning out real nice! |
Re: VS4-10 Phoenix/AD GroundFox Build Loving how this is coming together. I like that foam method for the fender liners! |
EVA foam is a treasure when you need something flexible and super light! i'm thinking about making seats from it. Thanks for the encouragements, guys. Got kind of a busy weekend, but I'm constantly thinking about tuis little guy https://uploads.tapatalk-cdn.com/202...8634450394.jpg https://uploads.tapatalk-cdn.com/202...ed796200e2.jpg More impossible choices... I really like both Sent from my iPhone using Tapatalk |
Re: VS4-10 Phoenix/AD GroundFox Build Heeeeeello. Having some issues with some kinda noise/binding in the transmission - but I think I've done all I can for now. Finished my homemade sliders and inner fenders, got the Phoenix interior painted up and paired with a LC70 dash.. hybrid moments. My homie is printing a rear bumper and I'm still thinking about fender flares. Salut! https://uploads.tapatalk-cdn.com/202...6a9aa854e1.jpg https://uploads.tapatalk-cdn.com/202...8604feaf4a.jpg https://uploads.tapatalk-cdn.com/202...24eaf8d5d9.jpg https://uploads.tapatalk-cdn.com/202...e6a0846600.jpg |
Re: VS4-10 Phoenix/AD GroundFox Build That's a damn fine-looking rig ya got there, man! Gorgeous red paint, killer wheel and tire selection on the last pic. Grille and bumper are SO clean..."thumbsup" |
Thanks man! Hoping it'll be all sewed up this weekend |
