![]() | #1 |
Newbie Join Date: Jan 2023 Location: London
![]() | #2 |
So it needs a bit of rearranging and tiding. ![]() It runs the amazon dig gearbox converted to 32dp with the biggest Kimbrough Spur I could fit with a 9T Pinion and a micro servo in an adaptor plate. Clearance is close with the front shaft which leads me on to my main issue... ![]() The front shaft is stuck on and I've broken countless drill bits trying to get it off, one day it will be removed! ![]() The front bumper was modded by me to be barely class 2 `22 legal and incorporate a fairlead for a kenetic style setup I made up as DSM wont ship to me ![]() ![]() ![]() ![]() AR44 axles with some brass added are on at the moment. It Runs a prototype battery tray I designed that also has guides for the kenetic setup and a rock light mount. ![]() Now its printed and installed I can see there is room to go lower and still clear the links so it will get a redesign at some stage, possibly incorporating a dig servo mount and anything else I can get moved to the front along with it. Speaking of lights, I also have some emergency lights I velcro to the inside of the roof for the midnight emergencies ![]() ![]() First of the new mods was to try some tread trimming for my first time on my pretty worn krawlers before they get binned for somthing else, excuse the dog hair ![]() ![]() Anti Foams are on the inside ![]() I've not driven with this yet, but I've stuck a link riser on to test with ![]() Next up will be to cut and drop the bed and rework the front axle with some Beeftubes, stay tuned! |
![]() | #3 |
So I got some parts together and built me a new axle ![]() ![]() Only things that came from the old axle are the diff cover, knuckles and the overdrive gears. The knuckles (10.2) requred some reworking and the XR10 axles are extra wide so I had to also mod the SSD wraith C hubs to make everything happy and work together. Now I need to work out if I should get some kind of panhard mount or go 4 link, which would open up SOA options. |
![]() | #4 |
Got things back together, with a few temp links, nearly ready for a test run. Ended up moving all the electronics from the sliders to the front and mounting the dig servo directly to the chassis rail. Now balanced with a 50/50 side weight front and rear, and looks a little more tidy. Also stuck a set of tuning rounds in the wheels to test with. ![]() Once it been run in this config i'll decide what's next, but I have options to add even more weight to the front axle and remove some elsewhere. |
![]() | #5 |
Latest update, Overdrive upped from 20 to 30% and Ruptures added ![]() Going for another change up on this rig though. Only going to run it once or twice like this then the front axle and wheels will come off to be donated to another comp style rig I have planned. This will then go back to the stock width ar44 front axle, some smaller rubber and this ![]() No plans on colours or themes yet, its a wide open canvas right now ![]() |
![]() | #6 |
Rock Slayer ![]() Join Date: Jul 2008 Location: Fox Valley WI
I love seeing these custom builds and all the creative ways people get random parts to work together. I just finished my V3 build not too long ago, good times! Pics in the 1.9 gallery. black and yellow "Murder Hornet".
Ascender refresh | tgh117 | Vaterra Ascender | 21 | 09-12-2019 10:12 AM |
refresh 1.9 | Jslick | Losi Mini-Rock Crawler | 4 | 10-12-2012 09:40 PM |
Classified section refresh? | oitz | Newbie General | 1 | 07-24-2010 02:35 PM |
Monitor refresh rate help | twisted | Chit Chat | 0 | 07-19-2010 09:36 PM |
