Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: Amazon yfgxfxf lcg build
Old 03-15-2023, 08:39 PM   #1
Default Amazon yfgxfxf lcg build
amazon yfgxfxf lcg "budget" build. pic dump for now, full specs to follow.
waterchestnut.jpg is offline   Reply With Quote
Old 03-15-2023, 08:43 PM   #2
Default Re: Amazon yfgxfxf lcg build
**updated with links and rounded up prices**
$40 - amazon carbon lcg rails https://www.amazon.com/dp/B0BJF2LBP2...roduct_details
$5 - g speed titanium spacers x4 https://gspeedchassis.com/products/g...3bd0b738&_ss=r
$80 - 2 speed with rear freewheel and dig https://www.amazon.com/dp/B0BLC8Y1MB...roduct_details
$15 - ally gear cover https://www.ebay.com/itm/392566107235
$15 - plastic gear cover https://www.amainhobbies.com/axial-t...0078%2fp200042
$35 - steer servo https://www.amazon.com/dp/B09VBFZ9KW...roduct_details
$15 - amazon chassis servo mount https://www.amazon.com/dp/B0B67RKDY3...roduct_details
$65 - aux servos https://www.amazon.com/dp/B0BLSKZ64D...t_details&th=1
$30 - brazin pro skid https://www.brazinscalerc.com/compon...7b9vx09fvbb0an
$20 - stainless links 1 says 324 wb, but as mine sits its at approx 313 https://www.amazon.com/dp/B0BLSCPHZV...roduct_details
$20 - stainless links 2 says 324 wb, but as mine sits its at approx 313 https://www.amazon.com/dp/B09DFFX7M4...roduct_details
$75 - previa shell https://supergdrift.com/store/produc...astics-previa/
$80 - transmitter https://www.amazon.com/dp/B07CL43JWQ...roduct_details
$90 - fusion se 1800 https://www.amainhobbies.com/hobbywi...04317/p1464186
$30 - 3s lipo x2 https://www.amazon.com/dp/B013I9SYC0...roduct_details
$40 - injora te37x copies https://www.injora.com/products/4pcs...40522170990640
$50 - crawler innovations dual stage - sourced set locally https://crawlerinnovations.com/lil-n...er-soft-outer/
$45 - jconcepts ruptures - sourced set locally https://jconcepts.net/ruptures-19-pe...ling-tire.html
$25 - desert lizard 100mm front - sourced pair locally https://www.amainhobbies.com/yeah-ra...-100bk/p632373
$20 - desert lizard 90mm rear - sourced pair locally https://www.amainhobbies.com/yeah-ra...-090bk/p529823
$80 - traxxas stock trx4 portals with working lockers - sourced pair locally
$free - home designed and printed sliders, front + rear combo trays, front + rear bumpers/rail end caps
$free - front and rear driveshafts from my cross JT4
Old 03-16-2023, 08:20 AM   #3
Rad. I seen a 1:1 of these crawling in Sand Hollow on the 'gram and looked awesome.
Goro Majima is online now   Reply With Quote
Old 03-16-2023, 09:07 AM   #4
Go Buckeyes!
B-MOW71's Avatar
Cool build! This is the first one I've seen built like this!
And the first I've seen the family van body used on an LCG build!
B-MOW71 is online now   Reply With Quote
Old 03-21-2023, 09:57 AM   #5
heck yeah, following this
DarthBacon101 is offline   Reply With Quote
Old 03-21-2023, 02:16 PM   #6
Slow is the new Fast
smog's Avatar
Ha, killer body dude. Totally in on this build. I would like to build up a "Ching Chong" chassis, to quote our own legendary member White Trash. Look forward to seeing where this goes
smog is offline   Reply With Quote
Old 03-21-2023, 02:34 PM   #7
Where did you get that body?
DRED805 is offline   Reply With Quote
Old 03-21-2023, 11:30 PM   #8
updated with parts list and bp prices.
short test run vid
https://www.youtube.com/watch?v=nuz4...=waterchestnut
Old 03-22-2023, 06:22 AM   #9
Toyota Previa mini van crawler nice!
surfishjoe is offline   Reply With Quote
Amazon yfgxfxf lcg build - Similar Threads
Exocaged Amazon Type of Build Stomp General Crawlers 7 11-24-2022 09:01 AM
in the planning stages of an LCG build... AXLES? ericfx1984 General Crawlers 9 03-31-2022 08:15 AM
First LCG build, advice please. Oh How Original General Crawlers 3 03-09-2022 01:23 PM
