![]() | #21 |
![]() | #22 |
Rock Crawler Join Date: Jul 2004 Location: OC, Oregon
Damn, Looking better already ![]() I always had a thing for the hilux bed aswell, its ugly as hell but different. |
![]() | #23 | ||
Sinking with the ship ![]() ![]() ![]() Join Date: Mar 2005 Location: El Capitan...sole survivor and sinking fast
| ![]() Quote:
![]() Quote:
Thanks TJ, its a great base so it should be to hard to get it up to par. | ||
![]() | #24 |
Rock Crawler Join Date: Apr 2005 Location: Upland
Nice build. Looks great!
![]() | #25 |
Rock Crawler Join Date: Oct 2006 Location: England, Where the birds fly backwards.
![]() | #26 |
Newbie Join Date: Nov 2005 Location: San Jose
The Dampers were an optional hop up for the Hilux. They were the same dampers that were sold with the Sand Scorcher and rough rider. They are a horrible damper and will leak oil constantly. It looks like you have a good truck to start with, these are a classic and deserve to be built up properly. |
![]() | #27 |
![]() | #28 | |
| ![]() Quote:
Thanks shodog, I assure you itll be built right ![]() | |
![]() | #29 |
The ones you made look pretty good. it might be just as easy to pick of a set of used SRB dampers. Another little scale trick is to use the rubber bellows from the bruiser dampers. ![]() |
![]() | #30 |
| ![]() Ah! i saw thise on ebay for #4 which is about $8. Just say if you want me to find the link again!
![]() | #31 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
Did you paint the hubs black? Looks good. If you want some beater plastic hubs, a guy sent me some so-so resin copies and I since got some identical repro's off Ebay. |
![]() | #32 |
Thanks for the pictures shodog, I have some extra Bruiser shocks somewhere, Ill probably end up stealing the boots from...did the same thing on my clone and when there painted white with a red rancho sticker look perfect ![]() ![]() ![]() |
![]() | #33 |
Made some rear shocks and got them mounted ![]() Then found my rear hubs to look like this ![]() ![]() ![]() ![]() Gotta love old tamiya pot metal ![]() ![]() O and I attacked the dash too ![]() ![]() its currently in 3 pc and I am starting to work on the gage cluster. Thanks for looking -Mike |
![]() | #34 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
Wow buddy thanks for showing us how it is done. What is next teacher? ![]() |
![]() | #35 |
I wanna be Dave Join Date: Apr 2007 Location: clarksburg
You Sir Are A Scale Master Keep The Pics Commin Thanks For Sharing.
![]() | #36 |
I joined the Band! Join Date: Aug 2007 Location: mission b.c canada
nice build cant wait to see it finished
![]() | #37 |
Wow, were the hubs really all cracked up like that? I never even noticed them.
![]() | #38 | |||
| ![]() Quote:
![]() ![]() Quote:
![]() Quote:
![]() | #39 |
Hevent updated this in some time, mostly because I hadnt had time to work on it. I got my new hub parts, and some cool "Warn" style covers for the front from some dude on ebay. I then came home from the GFs last night at like 12 and headed down into the basement till 3 which really was only 2 and got some more dashboard work accomplished 1st I finished the heater ducts, then I started on the glove box latch opener. On my last interior I glue a small circular piece of styrene to the dash with a "latch" glued to that piece however that wasnt the way it really is. The knob/latch is actually recessed and the opening to it is beveled. So after using a combination of 4 different drill bits by hand to get the contour correct, I then had to flip the dash and grind it down so the latch would be so far in and closer to flush. I then glued a piece in from the back side and cut a small piece of styrene rod to use as the knob/latch part ![]() ![]() I think next time I am also going to try to make the heater duct look more realistic...we will see...I always try improve each time I do one a new one. I knew I had kept that camaro interior for a reason, got my self my heater controls (not exact but beats making them) and a full blown REAL heat duct ![]() ![]() ![]() Next up I need to make the column, other controls, another CB radio, lower gage cluster,make my CD deck and Ipod ![]() Stay tuned -Mike |
![]() | #40 |
I lost my vendor privileges Join Date: May 2006 Location: TOP OF THE HILL
looking good Mike.
