10-11-2007, 11:10 AM | #1 |
Rock Crawler Join Date: Apr 2007 Location: Nor*Cal
| Echodawg's F-350 Truggy
Specifications: Body: F-350 cab with custom truggy rear end and rock sliders Chassis: K2-5 Motor: Crawlmaster 3014-1000kv Trans: RC4WD R2 ESC: Mamba Max Tires: Rock Crushers Wheels: Createacrawlers Axles: TLT Front: 303 steel axle, aluminum 2 piece knuckles Rear: straight axle adapter with straight axle After tearing down my last build, selling some and saving the rest, I decided to start another build. I wasn't going to bother with another build thread but wtf. I just got started so there isn't too much to see yet. Assembled the front bumper and just had to go with some more scaleoffroad emblems. Started the chassis work so I'll get some photos up soon. Last edited by Echodawg; 07-25-2008 at 11:29 AM. |
10-11-2007, 12:05 PM | #2 |
Rock Crawler Join Date: Jan 2007 Location: Do I look like a freaking people person?
Done yet?? lol Looks like you're off to a good start. |
10-11-2007, 12:08 PM | #3 |
God I want a set of those wheels so bad! Looks like a good start, looking forward to more. |
10-11-2007, 02:45 PM | #4 |
I joined the Band! Join Date: Aug 2007 Location: mission b.c canada
| f-350
awesome ..just waiting for mine to arrive,purchased from rcp crawlers, they were cheapest place that had stock ..any build issues to speak of or is it pretty straight forward.i will be watching this thread for your build pics |
10-11-2007, 05:22 PM | #5 |
Got some more work done on the chassis. The cab is going to be left a primered gray but I wanted most everything else black. So I'm using a stealth black MFM chassis, to which I mounted a black R2 and of course a Crawlmaster. I also got the links all setup. Messed around with the rear shocks until I was finally happy with their configuration. |
10-11-2007, 05:28 PM | #6 |
I lost my vendor privileges Join Date: May 2006 Location: TOP OF THE HILL
clean job. did you just win those shocks off evilbay? i was watching those.lol
10-11-2007, 05:57 PM | #7 |
10-14-2007, 05:00 PM | #8 |
After two days of constant tinkering I finally got my links correct. It is amazing how subtle adjustments can really alter the articulation one way or the other. I must have atleast eight hours into messing with the links. I also removed those darn servo mounts off the axle. I feel they just kill the scale look. Anyway, onto the photos. I cleaned up the mount for the rear shocks with better bushings. Still need to shave that axle. I got a battery tray mounted, low and over the front axle. Tranny mounted on homemade mount. Had to be mounted standing up to lower driveshafts and to clear the links. Link setup, as close to parallel as possible. Link stand-offs to clear frame during flex. Front servo chassis mounted. Weighted front wheels. Last edited by Echodawg; 10-14-2007 at 05:03 PM. |
10-14-2007, 06:37 PM | #9 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
You have half of the stuff that I want to use for a build right there! lol Looking good man, how high does the motor/tranny stan above the top of the frame? It doesn't look like its that tall. Did you widen the frame at all?
10-14-2007, 06:53 PM | #10 |
Rock Crawler Join Date: Oct 2007 Location: richmond, va
how did ya do the rear top shock mounts
10-14-2007, 09:05 PM | #11 | |
Pretty simple, I just drilled out the crossmembers and ran the screws with some rubber bushings from the hardware store. Once I get some tires on I'll post some flex shots. | |
10-15-2007, 04:55 AM | #12 |
thanks |
10-15-2007, 02:55 PM | #13 |
The electronics are in. Started working on filling in those holes on the body that aren't needed. |
10-15-2007, 09:29 PM | #14 |
Since I won't be running a bed I wanted to fix the lower back wall of the cab near the doors and how it just ends abruptly. Out came the styrene. It's not sanded yet but you get the point. |
10-15-2007, 09:40 PM | #15 |
RCC Addict Join Date: Aug 2006 Location: ****, SL,UT
looks like you gonna make a flat bed. am i right? the bod's looken great. |
10-15-2007, 11:50 PM | #16 |
10-16-2007, 12:53 AM | #17 |
| f-350
nice truck ..im inspired
10-16-2007, 05:09 PM | #18 |
10-16-2007, 05:17 PM | #19 |
10-16-2007, 05:26 PM | #20 |
