06-17-2008, 09:02 AM | #1 |
Rock Crawler Join Date: Dec 2005 Location: Tulsa, Oklahoma
| Shaun Goes Scale....
I'm starting on my first scale rig, a Jeep Rubicon. I plan on doing and interior some some scale goodies on the outside. Here is what I have planned. Mocrawler soft top AX-10 axles Clocked wheelyking trans TSC wheel nut covers A crappy 2ch radio I have laying around. Moped ESC JR ST126MG servo, mounted on chassis Proline eight shooter black beadlocks Axial Rock lizards RC4WD 90mm dual spring scale shocks 35T motor For color I'm going with the same colors as our old TJ, red with black fender flares, and a black soft top. I don't have to much yet, I have the body, dash, and a head full of ideas. This is the dash so far, I know it doesn't look very good :( It looks weird in the picture, it looks nothing like that in 1:1 view. I'm going to be painting that body as soon as the bad weather stops and I can get the el camino out of the garage. Here are the plans for seats, rear bumper, and chassis. I can't really plan anything else till I get my chassis cut. All really simple stuff. Imagine the chassis with 1/2 inch added to it, and the center bar across the top gone. Sorry for the crappy shackles, lol. And the crappy seats. Thanks for looking |
06-17-2008, 12:20 PM | #2 |
Pebble Pounder Join Date: May 2008 Location: Florida
no offense but you write like a 5 year old looks like a good start |
06-17-2008, 12:33 PM | #3 |
06-17-2008, 12:42 PM | #4 |
Rock Crawler Join Date: Feb 2007 Location: Bridgeport
06-17-2008, 01:23 PM | #5 | |
I'm left handed, its hard as hell to write. | |
06-17-2008, 01:34 PM | #6 |
06-17-2008, 01:37 PM | #7 |
Adilynsdad too! Join Date: May 2004 Location: G ville
I thought Mocrawler quit making tops?
06-17-2008, 01:58 PM | #8 |
He did. |
06-17-2008, 02:07 PM | #9 |
L-u-c-k-y
06-17-2008, 02:57 PM | #10 |
sooo your building a truck around a dash? lol thats the last thing i usually work on |
06-17-2008, 03:51 PM | #11 |
I have been planning the truck for a little while. I didn't have my chassis built yet, so I started the dash. I'm working on the seats now. And my chassis supplies are about to arrive. I'm going to try and go to hobby town tomorrow and get some paint. I don't have the money for the axles right now, so I can't do links or anything. I have the trans clocked Dash done seats need to be shaped and have the fabric put over them. It really sucks being broke :( |
06-17-2008, 07:41 PM | #12 |
The seats, of course they look like crap IMO. I can't do anything right :( |
06-18-2008, 08:54 AM | #13 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
Those aren't bad at all, maybe you could figure out some way to stitch them up like a real one!
06-18-2008, 04:44 PM | #14 |
Newbie Join Date: Oct 2007 Location: Scappoose Oregon
06-18-2008, 05:11 PM | #15 |
I know thats what I should have done, the way I did it was the simplest way I knew, just use styrene for the back, foam rubber for the foam and shave it down. I wanted to do the foam on the sides, but then I would have had to get glue to glue the fabric to the foam. I just used hot glue on the backs of the seats. I might make another set later, these took nearly 4 hours to make though so I really don't feel like redoing them. Also, you will barely be able to see these inside the truck. |
06-18-2008, 07:21 PM | #16 |
Rock Crawler Join Date: Dec 2007 Location: USA
06-18-2008, 08:07 PM | #17 |
Rock Crawler Join Date: Aug 2007 Location: Orlando
ya, ill are trail areas are ether in the woods, in water, or a pile of dirt:-(
06-19-2008, 12:59 PM | #18 |
I got the chassis drawn out. Trans clocked, and got bored so I polished up the motor mount. You gotta squint to see the chassis. After I get the chassis cut tonight I'll be able to mount the body, paint, and finish the interior. The way its looking I might have it going by our next comp. Last edited by Shaun; 06-19-2008 at 01:07 PM. |
06-19-2008, 10:16 PM | #19 |
Quarry Creeper Join Date: Jan 2008 Location: fair oaks nor-cal
i know its not on the subject but cool micro t and for seats that i mabe i just got foam board foam from a old set of inserts "axials" and hot glued it and put cloth from a bandana over it ,they are camo |
08-07-2008, 11:26 PM | #20 |
Thanks Here it is, I have only been working on it a few hours and this is everything that got done, Hope fully my axles will arrive tomorrow night, I'm cutting everything really close, seeing as we have a comp on Saturday, and my comp rig still needs some attention before then. I can if I believe I can I guess. Right now, I'm not paying to much attention to detail(except on the body) I'm just trying to get it running. After the scale run I'll tear it all down and build it up the right way Here is the work I got down in a few hours tonight, I would like to thank mississippirocs for the frame rails and servo and DARKHORSE for the Rubicon body, and Rockedup Ricky for the tires. I still need to add a few decals Tomorrow night my TLT axles should be here. I still have to find a body mounting solution |
