03-11-2008, 09:13 PM | #1 |
Quarry Creeper Join Date: Nov 2007 Location: barre
| hendrix motorsports 2.2
started this post in the wk section and decided to move it here since i plan on making it a scaler first time doing so so any comments or advice is welcome. I found hendrix motorsports great tube chassis, so i decided do kind of do my on interpritation of one of there chassis for a project so heres what i have so far, parts list ax10 trans wk trans integy 55t motor wk axles losi rock claws(not very scale i know) tq3 radia and reciever(just starting out in this hobby and it was cheap) stock wk esc(hope to get a cc sidewinder soon) and for some pics i want to try and use both trannys if possable any help would be appreciated |
03-11-2008, 10:30 PM | #2 |
Rock Crawler Join Date: Dec 2007 Location: buckeye,AZ
it looks nice, cant wait to seen it done
03-11-2008, 10:33 PM | #3 |
RCC Addict Join Date: Feb 2005 Location: Minnesota
That's looking good! Nice and clean looking. Can't wait to see more progress...
03-12-2008, 01:55 AM | #4 |
Nope.. Join Date: Aug 2005 Location: Whiteland, Indiana
Looks good! You're gonna have a hell of a reduction with those two trannies.
03-12-2008, 07:16 AM | #5 |
Quarry Creeper Join Date: Feb 2006 Location: Angier N.C.
I like your work. Very nice and clean. Your bends and joints are amazing! Keep it up and you'll have an awsome rig!
03-12-2008, 08:57 AM | #6 |
I joined the Band! Join Date: Aug 2007 Location: Paso Robles
| Plans?
Were can a person go to take a look at the plans you used for design? Are they available from Hendrix Motorsports? I would be interested in takinga look at those myself. Thanks |
03-12-2008, 09:02 AM | #7 |
RCC Addict Join Date: Mar 2006 Location: MUSE, PA
looks real good. but if you wanted to make it look REALLY scale, you should make it the right size to use a bruiser fram under it, like a real F-toy....
03-12-2008, 12:15 PM | #8 | |
its actualy the x chassis i do like the f toy but the nearest home depot or any sotre that carrries more than brake line is 30+mile frome me thancks for the comments guys yeah the two trannies will be one heck of a reduction but i think by the time its done its going to weigh a ton so it will help out Last edited by frsttimer; 03-12-2008 at 12:18 PM. Reason: post change | |
03-13-2008, 07:59 AM | #9 |
thanks for the link. i am going to use that to get plans for an F-toy cage....
03-13-2008, 09:22 AM | #10 |
Rock Crawler Join Date: Aug 2007 Location: Tucson
very nice fabrication work
03-13-2008, 11:27 AM | #11 |
thanks guys i should have more pics of progress sometime today ran out of tubing lastnight so had to get more about 15 feet into it got 10 more today also got a new plan might get a gd600 to use instead of the two trans. want to get something under the hood and keep room in the cockpit for sone interior i have a plan for the ax10 trans to keep space open anyone got any good places to get scale engines ive been looking but help would be appreciated thanks again for the comments
03-13-2008, 03:49 PM | #12 |
some progress pics i thik the carrier peice on the bottom is a bit too deep might change that one with some axles under it now for the hard part suspension setup but its getting there Last edited by frsttimer; 03-13-2008 at 03:52 PM. Reason: change post |
03-19-2008, 03:04 AM | #13 |
Quarry Creeper Join Date: Jul 2007 Location: Holland,OH
Figured I'd follow this thread to it's new home. Looks like you're almost there. Still watchin........ so keep it up Waiting to see it finished.
03-19-2008, 03:39 AM | #14 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
Nice tube work, very clean. I think it would look better if the lower portion of the frame was shorter in height too. |
03-20-2008, 10:03 AM | #15 | |
ty for the compliments cleaning joints as i go this time instead of waiting till all the tubes are all in place alot easier, and the lower section where the links attatch is shorter now and more centered should have some pics of things soon | |
03-20-2008, 04:04 PM | #16 |
Rock Crawler Join Date: Sep 2007 Location: Denmark
You still amaze me |
03-20-2008, 04:32 PM | #17 |
Quarry Creeper Join Date: Feb 2007 Location: Fresno
Looks great man. Makes me feel like crap for not finishing mine a year or so ago, but your skills are WAAAAAAAYYYYYY better than mine. Back when I was toying with the same idea, I was thinking of putting the motor and one trans in the engine compartment, and running one drive shaft down to another trans in the middle. Cutting the second input shaft short, and hooking the drive shaft from trans 1 onto the newly shortened input shaft of trans two, eliminating the spur/pinion on trans 2 all together and just using it as a transfer case. Though I was looking at an R2 up front with 10 or 12 cells and a stealth in mid, or an RD400 up front and Stealth in mid on like 7-10 cells. I was also leaning towards the Bruiser chassis/ F-toy build, with the servo in the chassis next to the motor with the steering linkage set up like a sprung bruiser, do a long version of the F-toy with the battery under the rear seat, and the RX in a "fuel cell". I just got so frusterated with my lack of ability I gave up. Another motor option is a brushless mounted to the "firewall" can forwards with the drive shaft poking through the firewall spinning a Pede shaft down to the altered input shaft on only one trans using it as the T-case. Someone (Ryan?) had a 2.2 with 2 brushless outrunners, and no trans at all, which is where I stole that idea. I thought about it alot, just lacked the skill to make it happen. Last edited by lunchbox; 03-20-2008 at 04:40 PM. |
03-20-2008, 05:44 PM | #18 | |
thanks for coments suggestions are also appreciated as i am still learning and need some guidence | |
03-20-2008, 05:46 PM | #19 |
03-20-2008, 05:53 PM | #20 |
| thats good So whats next .... do you have pics of the new bottom "link mount" ? Regards SnoopMaxx Last edited by SnoopMaxx; 03-20-2008 at 06:05 PM. |
